More problems, head gasket mabye??
Started by BLACKDOG, January 30, 2005, 09:14:46 PM
BLACKDOG
thats kinda what I was thinkin.  wish me luck, tommorow is the day! :crossed:
              -Ronald Reagan
RUGER
i'll be over after my class so we can throw it back together.  :crossed: hope it works this time.
happy trails
rich *ruger* :usa:  :turtle:
:usa: GOD BLESS AMERICA :usa:
"the hag" 83 toy with 5" all-pro lift, marlin crawler dual case #1011 and marlin hy-steer, 35s, 5.29's, exo cage, yada, yada, yada. she's back in black.
97 F250
84 Grand Waggy
77 Scout II SS
96 Explorer Sport
20 F150
USN SEABEE 2008-2012 :usa:
run with THE PACK 4wdc of los osos
NRA life member
are you a traveling man   SMIB
BLACKDOG
me too, just gotta pick up a couple of gaskets and a knock sensor wire tommorow
              -Ronald Reagan
Willy Mammoth
I would find out what Toyota recommends for torque and go with that. Also you will feel the gasket crush under the bolt as you tighten it. It will start to tighten up then get loose and then tight again. This is were you will pull till you get the proper torque. What ever pattern you use it should start in the middle and work back and forth until you get all the bolts. Tighten it in two stages, half of the required torque and then to the final torque. Make sure you oil the threads and shoulder of the bolts or you will get an inaccurate reading. If you want you can use a silicone sealer on the threads, but do not get any on the head gasket or that will make it leak. The head gasket should go on dry except for a small amount of sealer around the water jackets if they look pitted with rust or corrosion.
Good luck
BLACKDOG
Alrght, today is the day, the sun is shining, the birds are singing... no, actually is kinda chilly and riany.  Cant see the sun, but at least is isnt raining right now.  Have to get some stuff from the dealer, then the real fun begins :thumbs:
Keep ya'lls fingers :crossed:
              -Ronald Reagan
FATB0Y
reklund5
Blackdog-
Torque to 35ft lbs and then two 90* turns.  start in the middle, work your way out crossing left to right for torque pattern (middle left, middle right, rear left, front right, rear right, front left, etc...)
As WillyMammoth said, go in 2 or three passes up to the 33 ft lbs, then one 90 on all bolts, then the second 90 on all bolts.
You may consider checking the oil cooler adaptor on the block while you've got the heads off...
Ryan
Brandon
Brandon Miller
RCRC, Sacramento, CA
www.RiverCityRockCrawlers.com
FATB0Y
#218
Me 2 I'm  :chew:  @ the bit :eek:
:toiletwait:.............................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................I can wait no longer :toilet:
BLACKDOG
didnt finish the truck today. :down: we got a late start, had to run all over town to find someone with a headgasket in stock.  we got the pass. side head completely in a otrued down, all the brackets and such bolted back up, and we got the drivers side head on, and the exhaust bolted down.  Just gotta torque down the drivers side head, and then it is on to the easy stuff :crossed: hope it works! :yupyup:  will prolly finish on sunday, have to take my sister out for her B-day tommorow
              -Ronald Reagan
Ney Ney
magnaflux  is the stuff they use to check for cracks,  it makes baby powder look like rocksalt its so fine, that why it gets in the cracks and shows up
he said you had two weak chambers,  i bet your valve guides were working loose,
BLACKDOG
actually the seats(?) had gone eggshaped, and werent sealing properly
              -Ronald Reagan
BLACKDOG
Question, hoping that the block is fine,and thatthe reason the headgasket allowed water through, would a bad t-stat lead to this?  Bob at the shop showed me where water had gotten by the headgasket, and I know a crack is still possible, but would it have to right there on the top to do that?
              -Ronald Reagan
FATB0Y
BLACKDOG
Quote from: 03HDFATBOY on February 19, 2005, 10:37:11 PM
good luck  :crossed:
thanks fatboy, does that mean you dont know the answer?  :headscratch:   or ya just getting tired of my dumbass questions??  :hammerhead:
j/k
:beerchug:
              -Ronald Reagan
reklund5
a bad t-stat could cause enough of an overheat to blow a headgasket...but oil and water won't mix at the t-stat.
Ryan
FATB0Y
Quote from: blackdog on February 19, 2005, 10:43:48 PM
thanks fatboy, does that mean you don't know the answer? :headscratch: or ya just getting tired of my dumbass questions?? :hammerhead:
j/k
:beerchug:
:rofl: :rofl2: what was the question again :headscratch:
BLACKDOG
spent 4 hours or so today on the truck, didnt finish.  I borke a couple of peices that I have to go to the dealer to replace, and We had to back track a little to get some crap out of one of the head bolt holes. (ie had to take the head back off :smack: )  So it has been a real productive day. :down:  We did get the heads back on, and the cams in, and the valve covers on, and the lover intake plenum.  All we have left is the upper intake plenum, the timing, all the hoses and lines and such, the alternator, the power steering pump, the radiator, and the fan.  wish me luck for tommorow :crossed:
              -Ronald Reagan
FATB0Y
Quote from: blackdog on February 20, 2005, 02:22:47 PM
good luck 4 2morrow :crossed:
BLACKDOG
thanks fatboy.  Jeez, this is a pain in the :moon:  I swear, I cant win :smack:  oh well, life goes on, we'll see what tommorow brings :crossed:
              -Ronald Reagan
reklund5
Well, does your pile run yet????  Inquiring minds want to know!
Ryan
Willy Mammoth
Geezeo, you have almost as many pages as me and you are only doing head gaskets boy. Well are we there yet, not to push or anything, but the suspence is killing us. Does it work, inquiring minds wan to know.
BLACKDOG
 :tantrum:  :maddest:  :wall: :censored: :wall: :censored: :rivers:  :down:  :rivers:  :down:  :maddest:  :mad:
IT WASNT THE HEADS!!!!!
Chocolate milk foam, and water in the piston yet again.  It took me 5 minutes after startin it to figure that out :down:
              -Ronald Reagan
reklund5
lets cover the basics before you go tearing into it again...
Did you:
change the oil and filter
change the coolant
check the oil cooler on the drivers side of the block for cross-contamination
run it for a few minutes and change the oil again to get all the foamy residue out of the block?
check the water pump and thermostat areas
trying to eliminate all that i can  :dunno:
ryan
waffler
ID LOVE TO KICK THAT TRUCK IN THE  :moon:   :spankbutt:  WE'LL WHOOP THAT TRUCK INTO SHAPE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
There is no cure for stupidity.  Dribble happens.
Brandon
still really weird  :headscratch:
Assuming it isn't the heads, my god that sucks you had to go through all that work and money to find the same thing you found the first time..
Brandon Miller
BLACKDOG
Quote from: reklund5 on February 21, 2005, 10:15:21 PM
Did you:
change the coolant
ryan
Changed the oil and filter, changed the coolant, didnt do the oil cooler or run it for a few minutes and change the oil again.  But I did stick a screwdriver wrapped in paper into the #4 piston, and the paper came out soaking wet.  also, my temp guage went sky high after mabye 5 minutes of the truck running :down:
              -Ronald Reagan
