Zebra 85 2wd to 4wd( The Sketchy Build!)
Started by 91 ex-cab, June 03, 2011, 09:14:07 PM
zebracrawler
haha looks good out of the garage dumb it broke i think it might be that crawl box input that broke  :willynilly: :smack:
sas 85 2wd dual cases locked rear 35s
http://board.marlincrawler.com/index.php?topic=81775.0
4x4yota
Current:
Sold:
Zs Confederate Toy
Definitly looks good out of the garage. Great work guys
ZACH
87 Rock Rat X
80 SR5 The Shady Lady
Trail Junky
zebracrawler
looks good doesn't drive so good ha-ha need to get it fixed  hope its just a input shaft into the transmission  :bowdown:
Zs Confederate Toy
Quote from: zebracrawler on October 24, 2011, 08:30:51 PM
Unmatched splines or what?
ZACH
87 Rock Rat X
Trail Junky
zebracrawler
don't know yet i have to pull the cases out
zebracrawler
im getting a wine sound from the transmission pulled the block off plate off my crawl box and no gears were moving when i put it in any gear but when you change gear the wine sound changes so i know my gears are spinning in the transmission. so ether there is something broken in the transmission or its the input. :dunno:
Zs Confederate Toy
Well that doesnt sound fun at all. Especially after just putting it up in there
ZACH
87 Rock Rat X
Trail Junky
zebracrawler
yeah drove it like 200 feet then broke i was kinda mad about that but it did drive  :driving:
Zs Confederate Toy
At least it drove. You know it worked, even if it was only for a minute lol
ZACH
87 Rock Rat X
Trail Junky
4x4yota
Hopefully you get it all sorted out so you can ho and play... I know the feeling of not being able to drive your truck for a while and bo being able too... Im sure Z does too lol
Current:
Sold:
Zs Confederate Toy
Quote from: 4x4yota on October 25, 2011, 11:57:32 AM
Oh I do all too well haha
ZACH
87 Rock Rat X
Trail Junky
zebracrawler
yeah i just want to know why it broke and if it will do it again if i fix it
Zs Confederate Toy
ZACH
87 Rock Rat X
Trail Junky
zebracrawler
91 ex-cab
If its input its either bound or we stressed it when we put it in. It felt like it spun just fine though, so I'm thinking tranny is still a possibility. Only one way to find out :flamer:
zebracrawler
89sastoyo
so i kinda read but not completly im a little intoxicated, but if your tranny makes noises through the gears but your t case is not spinning than you broke an input. This is what i do when i break my t cases. immediatly yard on the rear d-line because it will move a lot if its an output or fall and hit you in the face. If the driveline is not lose or has a lot of play it could still be the output so i pull my front and rear case shifters off plate n all and then go through the gears usually like how mine are right now the front case will spin and the rear wont so right now i either broke yet another 4.7 input or i finally took out the dual case collar that adapts the front to the rear because a few buddies have been breaking those. with that said if you havent pulled the shifters and looked which i believe i read previously than i would. and if nothing is spinning you deff broke an input or forgot a c' clip and now have a gear wehre its not supposed to be so nothing engages. boom the end ya
89 extra cab stock on 1 tons.
92 2wd DD
first gen cab
Check out the build.
zebracrawler
yep i got a forward shift t case so i pulled my block off plate on top of my crawl box and looked down it wile the truck was running and ran it through all the gears and nothing was spinning so i'm pretty sure i broke an input. my drive line didnt fall on my face because i checked that after i pulled it back up the hill and it was good.  :willynilly:
89sastoyo
yeah deff an input if you have a single case or somehting is bound did you make sure your shifter is in gear while the shifter was out that could happen as well
92 2wd DD
first gen cab
91 ex-cab
Input was the first thing I said when it happened. But the fact that it hooked up and moved for a second after it broke makes me wonder.
zebracrawler
yeah but i t wasn't like it really hooked up it just grinded in gear for a sec there could have been a bur on the broken spot or something or it was on that hill and just made me think it went in to gear
zebracrawler
well i'm starting to build a square shaft and a sweet bracket to pull my dual cases without lifting them above my head
zebracrawler
used a lath to cut off the joints worked very good i cut out some frame plates for the truck on the cnc plasma because they do not have a plate for a 2wd frame designed them in cad turn out good will put some of the finish product soon you can see one in the bottom of the picture
kiyul4130
im jealous of anyone with access to a table like that.
-kiyul-
ECV 7-11
KYOTA FOREVER
83 Crawler
Wow this thing is sweet! It looks so long tho
zebracrawler
yeah its kinda long goes from the cab body mount almost to the front spring hanger but gust thought it would make things stronger
zebracrawler
finished my square shaft just maby needs to be cut down a little bit got to put it up on the truck first to see.
zebracrawler
i cut my old drivline down but kept some of the old thin wall tubing on it and put it in the vice and made it square
