Zebra 85 2wd to 4wd( The Sketchy Build!)
Started by 91 ex-cab, June 03, 2011, 09:14:07 PM
zebracrawler
well found out where to put my bump stop on the front the steering arm hits on my leaf spring but its also hitting on my inner finder so i will need to get on the bump stops before i go wheeling i cut my rear wheel wells it seems to work good  in the picks all 4 tires are still on the ground
sas 85 2wd dual cases locked rear 35s
http://board.marlincrawler.com/index.php?topic=81775.0
yotaneck13
zebracrawler
zebracrawler
order bump stop stuff from marlin today and got some flanges that have the right whole pattern for my front drive line  so i should have this thing 4wd and ready to hit the trail soon i hope
zebracrawler
ha found some old pics of my front axle when i got it it was a little ruff haha
zebracrawler
i gesss this is what you get for $150 and get it from a field in Reno
zebracrawler
#246
front drive line on and fenders all trimmed up so she doesn't rub ill put some picks up in a little
daniresch
Quote from: zebracrawler on January 06, 2012, 11:01:36 AM
mine looked the same and had hub and brake components missing for 250. You got a good deal! tested 4wd on it yet?
zebracrawler
yep works good hubs worked great resirficed the breaks and its all good to go last thing to do before i can go out and wheel is front bump stops and some rear shocks
zebracrawler
yotacrawler1
does that front shackle ever beat up against your body mount? seemed real close to me
muddytaco
95 tacoma 5" revtek/bilstein detroit locked 9" with drilled and slotted rotors front and back, 8000# mile marker winch, 16" crager crawlers, too much other crap to mention
96 t100 2wd (soon to be sasd i hope) - dead
85 efi 4runner
01 sequoia
91 ex-cab
Quote from: yotacrawler1 on January 22, 2012, 03:17:35 PM
I dont think its near as close as it looks in that picture if I remember correctly.
yotacrawler1
oh thats good... mm and thats a hot looking driveline lol
zebracrawler
No  it doesn't toch but it gets to about 1/2 inch away it's close, yeah keeping with the green on the small pices
zebracrawler
well im kinda stuck on bumpstops just been to lazy to put them on but i got some motivation and got them tacked i just need to flex it to cheek if they are in a good spot
zebracrawler
does any one have any good ideas on how to mount bump stops to the u bolt plate
hansi530
88 custom cab: http://board.marlincrawler.com/index.php?topic=88026.new#new
shitlbuffout-A saying among 4x4 and off road enthusiasts. Its said after damage normally cosmetic to minor parts damage has occurred on there rig or vehicle. Shitlbuffout is :pokinit: will buff out as in the :pokinit: being the damage will buff as in painted over cleaned polished or "buffed" out.
91 ex-cab
Quote from: zebracrawler on February 16, 2012, 04:31:48 PM
Weld square tube to your frame and cap it and then weld poly bumps to your u bolt plates. Look at trail gears setup in the sas instructions. You can rebuild motors but you can't do bump stops haha
zebracrawler
well all i did yesterday was look at it ha ha yeah the motor was easy this is the hard part i got to find where they are going to hint and stuff yeah il gust weld them on
Red Solo Truck
zebracrawler
spc mike
^^ yes!! That video is so stupid it's hilarious!
daniresch
zebracrawler
got some stuff for you to look at!
got some bucket seats in a trade bed-lining the floor and covering the hole for the shifers going to fix my ticking valves got shocks on it and bump stops. oh and got a new welder
Red Solo Truck
zebracrawler
zebracrawler
bumper time should i do a stinger or no stinger
