Zebra 85 2wd to 4wd( The Sketchy Build!)
Started by 91 ex-cab, June 03, 2011, 09:14:07 PM
1985CRAWLER
sick truck man, and that 3.4 will make it even more badass!
zebracrawler
sas 85 2wd dual cases locked rear 35s
http://board.marlincrawler.com/index.php?topic=81775.0
zebracrawler
cut the crossmember up to make it work where i want it to forward and t case up in the cab more
zebracrawler
twistedtoy92
zebracrawler
yep in for the last time ill post more pictures soon
zebracrawler
Just doing final stupid wiring stuff and fuel stuff. Im getting close to firing it up. I still need a power steering pump adjustment bracket and the small pig tail that goes to the coolant temp sensor, If anyone has one of those it would be a great help.
zebracrawler
zebracrawler
before i cut it and rotated it away from the frame after
zebracrawler
also had time to cover my dash pad with some vinal not perfect but a lot better then before.
after covering
zebracrawler
zebracrawler
so got the engine all plumed up and wired ready to start but didn't have spark. I have injector pulse i have power to the coils, coils are all good, not the crank sensor. I'm thinking my computer is bad because I have no trigger coming from it. just wondering if anyone has had a problem like this
twistedtoy92
zebracrawler
ok plugged the edu in to a tacoma of the same year and it started it so edu is not the problem. umm  :smack:
zebracrawler
zebracrawler
any one with a 3.4 having problems with cooling on hot days running the 3.0 rad
John Doe
No problem here, except when trying to go 75mph the whole way up I-80!
zebracrawler
i only have problems on 85 degree + days when i am going up hill in low or low low for more than a hour
redneckcustoms13
Do you have the 3.0 rad that is all metal or do you have the one with plastic tanks? I strongly recommend the all aluminum welded rads you can get off ebay for less than $200. I am running quite a few of them and they have done well by me.
01 double cab hunting truck
06 tacoma street truck
