Zebra 85 2wd to 4wd( The Sketchy Build!)
Started by 91 ex-cab, June 03, 2011, 09:14:07 PM
John Doe
If any stinger I prefer the flat top hood line stinger.
zebracrawler
yeah that's what i was thinking i was thinking how long would the flat spot be on the stinger.
sas 85 2wd dual cases locked rear 35s
http://board.marlincrawler.com/index.php?topic=81775.0
91 ex-cab
Red Solo Truck
Haha, at first look......... It looks like he's launching off a jump!
zebracrawler
zebracrawler
#275
well turns out that my carb stopped working on me, time for a new one only thing i didn't rebuild on this truck and it goes out.
Red Solo Truck
Did you order a new one yet? or are you just gunna rebuild it?
nisota
How did you make your  :beer: holder attached to the column its sweet! :thumbs:
Oregon wheelin'
82' 2wd-4wd project
http://board.marlincrawler.com/index.php?topic=89180.0
zebracrawler
yeah its super handy it turns and rocks so your  :beer: doesn't spill when your wheeling it came out of a old boat  its called like a bar buddy or somthing
nisota
Awesome thats a really good investment. I like it gonna look into doing something like that myself  :thumbs: cant spill the  :beer: when your wheelin
Oregon wheelin'
82' 2wd-4wd project
zebracrawler
so im going to start building the truck more just got btf rear truss and armor going to 4 link the rear 3 link front after
AaronB
what did you guys do with the steering? did you use the stock 2wd or swap it for a 4wd steering box?
zebracrawler
yeah its swapped to a new style sttering box
zebracrawler
zebracrawler
looks like I'm putting a hood scoop. didn't want to sacrifice having to lower my bump stops and lifting my truck higher. didn't want to do a body lift ether so stuck with a tall intake
zippo
I looked hard at this swap. They do need a hood scoop. 89 and up can do it with only trimming the inner brace. I think the right black hood scoop wil look good with the strips
If you see it, its for sale.
zebracrawler
there is a hood scoop you can buy for the newer tacomas it looks like it would look good
John Doe
Quote from: zippo on November 17, 2014, 09:22:38 AM
No they do not :nonono:
All it takes is custom frame side motor mount brackets.
Did mine with no scoop, and no body lift, but it will bite me in the butt for use able uptravel in my not so distant future front 3 link.  :brick:
In your pic with all the parts on the ground I see a cold air intake, you will likely want to find a stock air box for when you try and go get the swap inspected.
zebracrawler
yeah i got a cold air for free i got a stock one from a tacoma i can throw on for the reff
zebracrawler
yeah my truck sits low but i like having that 4 in up travel my pan will have a 1/2 in space to my oil pan at full bump right now
John Doe
#293
Whats your frame height at the door?
Edit:
Quote from: zebracrawler on November 17, 2014, 04:59:00 PM
How high is your frame from the ground?
zebracrawler
5 in frame hight  or do you mean the amount of frame that hangs below the pinch weld in that case its around 2in
John Doe
zebracrawler
John Doe
That is much better then I was thinking you had.
zebracrawler
it is lower than my buddys  88 with a 4 in lift and 32s haha thats with 4 inch to bump on the front and 6 in the rear
zebracrawler
2 wheel drive fenders are about 3 in taller so it makes my wheel wells look big
