My 84 extra cab is gone. Tacoma build now.
Started by Hyena, November 21, 2004, 12:25:12 PM
Ramrod
if you can get that hub stud out I got 12 spares for ya
lol, i got some spare ones plus a whole rotor.  i should be set.
Ramrod
go buy some spark plugs and fix that thing but if you dont I'll leave a little extra space in the bed for ya
I am meeting Jason tomarrow to get a nuckle from him. i think i will go buy some plugs and wires right after work.  maybe get to working on it wednesday.
toynorcal
"No man I am going to take it easy on my rig until the roundup"  :slap:
Just playin man, thats some good carnage right there. Cage handle it alright? Lookin forward to viewin the scars up close.
the cage is in great shape still.  the whole passenger side of the cab is smashed into the cage.  a rock actually came through the extra cab window and hit the back bar of the cage, it only scuffed it up.  but the passenger side is in worse shape than the drivers side now.
toynorcal
A couple months maybe.  I will have access to all the tools i will need in 3 months.  hope to have a little more money then too.
i am done with toyota axles.  to much breakage.  time for some dana 60's.
Shamb
can't wait to see the buildup on this
i may have found a rear axle already, still need to find a front.  and i gotta get the front toy axle fixed before i can sell them.
boggerunner
did u destroy chromoly birfs or ring and pinyon?
broke all for drivers side nuckle studs and a couple hub studs.  wasn't bashing it it at all.  replacing nuckle studs 2 weeks in a row gets aggrivating.  this is 3 wheelin trips in a row that i have broken something important in the toyota axles.  i need something that won't break.
MiniSimp
Damnit Brad! :shake:
:talkingn: good to meet ya! :thumbs:
Yota4life
Brad you had some bad luck with those. Im surprised i didnt bust some when i got home they were loose enough to take off with my fingers. It was great wheelin and meeting you  :thumbs:
alright, so the plans are as fallows.  I am going to fix these axles and keep wheelin as much as i can while i look for a front dana 60.  I might do a hydro assist setup from trail gear soon to help wit hsteering with these axles.  i just got a broken crossmember from my boss, it is the fror style one that bolts to the back of the t-case.  i welded it back up today and plated it so it doesn't break again.  not bad for getting it free.  I just need to buy all the bolts and mounts so i can mount it.  But i plan to flat belly it while i am at it.  So i need to take out my seats so i can cut out the tranny tunnel and part of the floorboards.  I need to lift up the t-case about 3-4 inches is my guess.  then i will build a skid plate later that will attach to the bottom of the t-cases and the new crossmember.  i just bid on some nuckles on ebay so hopefully i get those. they should be here in a couple days if i win the bid.  then i can fix my nuckles and give locktup one that i barrowed from him.  i hope to have the t-case mounted and the nuckles fixed by this time nextm onth in time for the fordyce trip.  i am not worried about the t-case hitting rocks for now since it will be up with the frame rails.  and i am going to have my exhaust exit under my drivers door since it keep getting hit by rocks and smashing.  i have already had to redo it 3 times since in a couple months.
Clifcattankass
You better get it done by the fordyce trip next month, ive got a bunch of crap to do to mine also.
countrygirl
brad do you think you can handdle 60s???  hahaha
Matty
good luck with the 60 hunt.  that should be sick  :beerchug:
did you buy your in-cab cage and brace it?  or is that all custom?
Quote from: Clifcattankass on September 17, 2006, 11:04:34 PM
It should be done.  i have the weekends to work on it and after work also so i have time.
Quote from: countrygirl on September 18, 2006, 09:29:55 AM
You be quiet.  you don't even have a truck.
Quote from: 85xtracab on September 18, 2006, 12:24:14 PM
It is an All-pro cage that me and a couple friends extra braced.  it is the second truck the cage has been in.
toyhunter
Time to throw it down for the dynatrac pro rock 60s right :crossed:
Everyone starts off in life crawling but lots of us grow up and still are crawling around everywhere
Quote from: toyhunter on September 18, 2006, 09:06:52 PM
haha, thas funny.  2 of those axles cost more then my Ford.  don't think that will happen.
countrygirl
i do to have a truck its just a p.o.s. i was just asking if you have the balls for 60s???
Quote from: countrygirl on September 19, 2006, 11:26:39 AM
your just going to have to find out for yourself.
well, today i cut the trannt tunnel out of the truck.  almost cut off my finger when the angle grinder flew across the cab all over the place.  ordered a bunch of stuff from front range off-road like arp nuckle studs, 2 nuckles, some low profile drain plugs.  there goes my check i just got today  :(
Shamb
Quote from: Shamb on September 19, 2006, 08:06:22 PM
no luck on finding a D60 yet?
not yet but i am still looking.  i might as well fix my axles and wheel it some more while i look.
MiniSimp
Post up some pics of your tunnel. I might do that in phase 2.
i will take some pics tomarrow.  i still need to bolt on my new t-case mount them raise the cases 3 inches or so and see if i cut enough out.
Yota4life
Do you also have to cut off the crossmember on the frame and build a high clearence one? I know on mine i will have to do that when i flatbelly it because the driveshaft will hit. Something i read about knuckle studs is to just keep them torqued to 80 ft-lbs, over tightening streches/weakens the studs. Arps should last a long time
