Making Of The Willy Mammoth
Started by Willy Mammoth, November 18, 2004, 08:06:16 PM
0 Members and 6 Guests are viewing this topic.
Lady Di
Quote from: CTENG in KS on September 29, 2007, 06:39:51 PM
So...def looks like you are making progress on the house!
:yupyup:  he was going to start on it but we have to clear everything out of the living room for him to be able to do what he needs to do, and everything that is in the living room had been relocated to the LBC.
Since we are going to WV in another month, rather then load everything in the LBC and have to take it out again in a month, AND because there are mountains to drive up there as well, we decided this on last fab was the way to go first.
Life is like a bowl of beer flavored chocolate covered dog turds.. it makes no sense. :pokinit:
Where is the Mammoth?
How the Mammoth came to be
Number Two :pokinit:
Lady Di
  :think:  wait... did I LAST FAB??
Willy Mammoth
WOW, them 42" Irocks is spensive. Looking at $3100 for 5 tires 5 steel wheels and 5 new Stauns. :yikes:
Willy Mammoth
snowshoebrue
are you going to run them on your toyota axles or are you gonna switch to 1 tons?
CTENG in KS
Willy Mammoth
Quote from: snowshoebrue on September 30, 2007, 04:39:47 PM
Toy axles till I can afford to switch to Unimog or Volvo portals.
notajeep
Quote from: Willy Mammoth on September 30, 2007, 05:17:49 PM
With 42's?
Willy Mammoth
crawlerdan
Quote from: Willy Mammoth on September 30, 2007, 07:48:48 AM
thinking about selling the current setup??
notajeep
Quote from: Willy Mammoth on September 30, 2007, 05:24:42 PM
What is the question again?
Sorry......
I was just had a moment of shock there.... The question was: Are you going to run the 42's on the toy axles until you get some sort of portal setup?
blackdiamond
Quote from: notajeep on September 30, 2007, 05:51:22 PM
Sorry......
It's a perfect plan.  If nothing breaks then excellent, if it does break if often changes the definition of "afford" and budget considerations.
I met a guy this AM driving a Mog with 46" Goodyears that he said he got from the Army Surplus for about $750 for five including shipping.  It was a sweet rig.
El Cheapo
Quote from: Willy Mammoth on January 30, 2005, 09:02:20 PM
:gap: I wish I had a neighbor that wanted to learn caus I could use a good helper :whip:
yeah, after reading this whole thread, I wish I was your neighbor so I could learn from something other than books. Oh, well. Looks Good.
red
a 4 1/2" thick radiator would be more than enough for the willy lol. but better to overkill than not enough.
if you were close i'd help ya out, but thats a long drive from northern utah to florida.
read and comment :whip:
USAF EOD tech
Willy Mammoth
#3075
Quote from: red on October 02, 2007, 09:28:04 AM
Time to sprout wings my good man cause the fun begins now.
I understand these fit a Mazda something, the core is the exact same size as the Explorer V6 except it is 3" narrower. Which turned on its side means no more clearance issues with the steering.
BBL  :flamer:
Willy Mammoth
Less the tanks and trimmed down to get the cores as close as possible.
red
were you overheating alot on the trail?
USAF EOD tech
Willy Mammoth
Quote from: red on October 02, 2007, 12:09:00 PM
No, just on the hwy at speed up hills. That is if you call 225* hot.  On the trail has never been a problem. Seems the diesels produce a lot more heat then the gas engines and I have very little space for a proper sized radiator, well that is till now.
red
yep, diesels are hotter than gassers when a load is put on them :yesnod: . unloaded they will take forever to get to operating temp though.
USAF EOD tech
93tonkatoy
 :headscratch: With the 42's onthe driver's side, and the 38's still on the passenger side,as in the picture, makes me think you are trying to increase the pucker factor for the Mrs.!!! :yikes:
:hahaha: :hahaha: :hahaha:
SAVE TELLICO post 491
93tonkatoy
Willy Mammoth
Nope, just lucky that I could figure out how to chop them on the driver side.  I would spend another 4 hrs trying to figure out how to do the other side with Photo Shop.  :shake:
Anyway I got the two cores welded together.   :yikes: :scared: That was a tight spot to put a weld and the tubes are right there and they are very thin so one slip and they would disappear.
red
understatement on the tight fit!
USAF EOD tech
Fongs
uhhh Marc :beerchug: :yikes:
you get freeze behind this cooler
i shout give this pics to Colt...he had also temperatur-problems with his 1KZT :flamer:
looks good :thumbs:
Willy Mammoth
Fongs :wave:
Here is one with it hanging in place.  :disturbed:
93tonkatoy
so, are you going to make custom tanks for the radiator, or do you have some lined up that fit?
red
it looks like the tanks that came with it will fit going by the picture, but i cant see the passanger side.
USAF EOD tech
Willy Mammoth
Quote from: 93tonkatoy on October 02, 2007, 02:53:40 PM
I have tanks right here, can you see them? :yesnod:
Duffil
:hyper: Are you doing this one as a 2-pass also? I think we talked about it but I don't remember. :hammerhead:
