1966 Toyota Stout Build (20/22R Hybrid)
Started by SloCrawler, July 30, 2009, 05:47:42 PM
superyota
you need to get your mounts in first.  measure the distance between the mount on the axle and the mount on the frame at ride height, then compressed and extended.  depending on how you mount your shocks, l l,  or / \, will really make a difference on how much your shock travels.
ABD Motorsports
#4475
www.placercountycrawlers.com
KK6QDW
SloCrawler
got to figure my uptravel then i can figure the mounts out i imagin. i was planning on them being at a little angle but pretty much straight up and down
jrock
How would you mounted the shocks on the outside of the spring?
Straight up and down is great but don't worry about angling them a bit.
SloCrawler
my springs are inboarded 4", i will mount them on the stock pearches, it should help with control
jrock
The frame mounts are not in the best location for flex.
SloCrawler
im going to roll some dom and put wheel wells in my flatbed, then run dom to the top of both of those wells and connect my shocks there, maybe ill try and sketch my idea to show you guys
SloCrawler
this is where i plan on mounting the rear shock, the bottom connects on the outside of the spring and the top will be just inside the frame. see the square tube on the top left I'm going to cut that out and see how high the wheels tuck in and ill know hoe high my wheel wells need to go plus a few inches because i want to later upgrade to 37" tires, ill do that and both sides and connect a bar straight across for my shocks. when I'm figuring all this out i should be able to figure my up travel from there.
jrock
Personally I wouldn't do it that way. I would be afraid of it hitting the frame. I would mount it to the u-bolt plate.
SloCrawler
that was my original plan, had a guy contact me here at marlin and recommend this to help gain control of his beast, he has a very similar setup
953rz4runner
toyocrawlr
Bro u have a nice rig I'm a newb wich way gives u more down travel if u mount your shocks straight up and down or at an angle but wich way would give you both good up travel and down travel
superyota
angled with give you more travel (/ \), but less stability.
ABD Motorsports
#4475
KK6QDW
SloCrawler
Ordered 5  monster mod wheels with 2.5 backspace, get this  :pokinit:  off jackstands and on some rubber. They said a little less than a month ill have them.  Now I need my gear install kits, you guys think through MC or inchwarm?  My buddy gets a nice discount at inchwarm. Don't want to half ass though
Peterbuilt84
The install kit should come from the gear company, mine were from yukon. I think MC sells yukon too. If you can get a discount go for it.
jrock
It's not as much the install kit, it's the install that matters. But really, check what bearings they use. Timken are good.
SloCrawler
E4 T8-529 304
G-529 37-7  u.s.a.  L5F
Refrence for gears.
jrock
G is Genuine, I think. 5.29. 37 ring teeth, 7 pinion.
SloCrawler
got my 35s mounted finally thanks Superyota, got 16x8 with 2.5 backspacing rock crawler extreme wheels, my truck actually sits 22" to frame
superyota
sweet!  looks good chris.  now come wheel it!
ABD Motorsports
#4475
KK6QDW
SloCrawler
sounds like its gonna be little over $300 for front and rear set up kits with the solid spacer through marlin, ouch..
Peterbuilt84
Quote from: Chrstphrtptts on March 15, 2011, 01:09:28 PM
Sounds about right, gears are $$$. Rig looks like it's coming along good, are you still running stock birfs?
jrock
Do you drive this around on the street a lot? If yes, how much of a difference did you notice with the inboarded rears? With the jonny joints?
superyota
that just set up kits right?  no gears?
ABD Motorsports
#4475
KK6QDW
Peterbuilt84
Quote from: superyota on March 15, 2011, 01:44:18 PM
Marlin lists the setup kits for $130 plus $30 for the solid spacer.
superyota
Quote from: Peterbuilt84 on March 15, 2011, 01:59:48 PM
sounds about right.
ABD Motorsports
#4475
KK6QDW
Gear Jammin-Dog Chasin-Yota Man
how's that glass pack sound?  I was thinking of throwing one on mine with header and 2.5" exhaust.  Might be loud though....
nice build.
I am doing something similar :http://board.marlincrawler.com/index.php?topic=78730.0
1975 FJ-55 Landcruiser: pretty much stock with 31 x9.50x15 TSL's
1992 Extended Cab Pickup: 22r, weber carb, 51" RUF, F-150 rears, Aussie Front, Welded Rear, etc.
Build: http://board.marlincrawler.com/index.php?topic=78730
jackson58
Quote from: jrock on March 15, 2011, 01:28:51 PM
I have my truck setup with inboarded rear springs due to properly mounted shocks I don't notice a difference in handling just suspension travel. Another guy that I have helped says the same about his truck that is setup very similar.
Dirt is for wheelin not for wearin you filthy hippie!
SloCrawler
Got any pics of your shock setup
Quote from: jackson58 on March 15, 2011, 02:32:04 PM
