1966 Toyota Stout Build (20/22R Hybrid)
Started by SloCrawler, July 30, 2009, 05:47:42 PM
LilChief87
SloCrawler
Quote from: mayberry on October 27, 2009, 07:22:59 PM
are you planning on moving your spring perches on your axle?
As of now I have the  spring pearchs moved 4" toward the third, and have them on the farthest hole so the axle is back a 1".
mtm
hilux 82 with mk3 2.4d engine. bobed 18 inches, full soft top, 9 inches of lift,exo cage,swing out tyre carrier, front tube winchbumper with x9, rock sliders, rear tube bumper, front truetrac and rear arb lockers, twin trans adapter with 4.7 crawler gears,20 forward and 4 reverse gears, 38 inch super swampers , rear disc brake conversion, trans disc parking brake, 5.29 r&p ,rear bench seat,hand throtle,custom storage boxes, custom made snorkel,onboard air compressor,cb twin bateries,split charge system, diff guards, low profile gearbox mo
SloCrawler
#34
Suspension all done. :beerchug: Got gas tank and tool box relocated. shocks next, thinking of using 14" KYB for now and later switching to bilstien when i get cash. My girl is 32 weeks prego, :hammerhead: got to be smart with my cash right now.
superyota
lookin good chris!  keep the pictures coming.  you going to make it to the roundup?
ABD Motorsports
#4475
www.placercountycrawlers.com
KK6QDW
SloCrawler
I'm so knew I don't even know what roundup is. Need 5.29s and lockers 1st I imagine
Joey88RUNR
its the MC customer run in september
PBrown
Looks good. Any pics of it working yet?
91 reg cab sas, duals 4.7, 5.29s, detroits, 35s, bunch of marlin debt.
gtoyonrocks
Do you have any flex pics of the inboard rears?
SloCrawler
Still in the works. gonna flex it on the forklift before i do shocks.
gtoyonrocks
Cool, I will be looking for the pics.
SloCrawler
Just curious. :headscratch: I got a trailer so my truck will never see pavement again, what do you guys think about welding my front and rear diffs?
gtoyonrocks
It's a great idea..... I would do it in a heart beat, well the rear and then the front when you get some 30 splines.
Jud
Truck is looking better than before, keep up the good work.
If you trailer it I would definately weld the rearend. Just do a little research before doing it, idk how handy you are with a welder or anything, only reason I am saying this. A arc welder would do the best job or a good wire feed with innershield wire. Make sure to weld everything all together. weld the side and spider gears together, then weld the spiders to the carrier. When I weld diffs I pretty much blend the spider/side gears all together, whe I am done you can hardley tell there are gears in there...
"bout tree fiddy"
SloCrawler
Finish braceing in the rear of the flat bed, tank line all reran and hooked up. She runs again :beerchug:
SloCrawler
A little flex, checking things out. thing I need a flat pitman arm.
jrock
I'm not sure but you don't look as if you need a flat pitman :dunno: You do need a front driveshaft that takes the travel  :biggthumpup:
Awesome build :eye: :eye:
SloCrawler
#49
Quote from: jrock on August 13, 2010, 10:00:11 AM
That pitman picture is my truck at level. You dont think my spring will hit at shove. I found a 14" slip drive shaft for $179, waiting for a bit tell i get it
jrock
hilux-1983
Please don't take this wrong. Did you install the RUF's in the right direction? From the pics it looks like the front axle is further back than it should be. With the RUF's, your axle should have moved 1" to 1.5" forward.  :disturbed:
SloCrawler
#52
I'm not sure. I believe I placed the long side on the springs foward. I do know I could of moved my front spring hanger foward more. I'm going to change my RUF  pack to 2wd ones and add some leafs, in  the next week or so.
88_Pathy
Short side forward is the right way
SloCrawler
Thanks guys, Ill check tonight. Any tech or advice is greatly appreciated.
SloCrawler
I measure my springs the short side is foward, I'm thinking it looks that way because I didn't know to move my front hanger foward an inch. It's in the stock locations.  I don't want to have to move again, possibly 3 hole perches to move it foward an inch later when I do armor. Right know its a 4 leaf pack in front, I'm going to rebuild the leafs with 2wd mains to get more arch, and total up to 6 leafs, way to soft as is and springs are flat.
tryn2Crawl
Looks like your flabed rail is gonna be preventin your rear flex..The wheel is almost it....Hope you don't go bigger on the tire size if its something you not plannin to correct...JMHO..
refering to pic #2..FYI
SloCrawler
I want to run 35 or 37 tires. I am planning on doing wheel wells in myflatbed to allow the travel. I didn't want to raise my bed any more than that trying to keep center of gravity as low as possible. I'm like the low stance.
Jrod
Rick Vega
85 efi 2nd gen. - in progress
