1966 Toyota Stout Build (20/22R Hybrid)
Started by SloCrawler, July 30, 2009, 05:47:42 PM
jrock
Quote from: jackson58 on March 15, 2011, 02:32:04 PM
I have my truck setup with inboarded rear springs due to properly mounted shocks I don't notice a difference in handling just suspension travel. Another guy that I have helped says the same about his truck that is setup very similar.
Quote from: Chrstphrtptts on March 15, 2011, 03:38:36 PM
Got any pics of your shock setup
X2 and what springs?
jackson58
Quote from: jrock on March 15, 2011, 03:40:16 PM
Don't have any good pics to show shock placement but the pic you showed of your plan on how you were planning on mounting them is almost exactly like mine. The springs are All Pro 5''
Dirt is for wheelin not for wearin you filthy hippie!
jrock
Quote from: Chrstphrtptts on February 18, 2011, 08:28:12 AM
http://board.marlincrawler.com/index.php?topic=45027.90 check this build, this is how i was thinking of doing rear shocks and my cab exo
Your going to need some really long shocks  :disturbed:
SloCrawler
You thinks 14" would be long enough this way? I believe he useing 12" above. Might not work on my truck like you where saying my springs are awfully close to my frame the way I set them up.
BigBs84
Notch the inside of the frame and replate it to fit the shocks I wasted a brand new bilstein first time out. 12" shocks have done me great my frame hieght is 23 1/2 and with it that low 12's are perfect. Lookin good man keep up the good work. Oh and move that front hanger, and as far as triple drilled perches go just drill you a hole 1 1/2" back save time and money, then cap the perches for strength. :yupyup:
Build it wright-wind it tight
   High-N-Tight offroad
http://board.marlincrawler.com/index.php?topic=45027.0 My truggy build
jackson58
x2 on knotching the frame for needed clearance :biggthumpup: but as for 12's for my setup they would be like limiting straps. I use every bit 14'' shocks thats my  :twocents:
jrock
You have any pics of the creeper joints REALLY flexed out? I want to see how much they bind and rotate. Please 8)
SloCrawler
no just the ones from my trailer on page three, my wheel was about 2 feet up
SloCrawler
got a grant steering wheel, made my doors removable with pins finally, cut 3" off my rear ubolts and reran my ebrake line, oh yeah and ordered my gear install kits truss and gussets and armor for my front axle.
SloCrawler
Tell me if I'm going at this wrong, but the plan is to cut and weld my axles with oil in them? Then after im going to drain and rebuild them all new bearings gears and ring and pinion.  Anything I need to be extra careful about?  Also my rear shackles are not as aggressive as I wanted, there 7" eye to eye, shorting them I would think  help that?
Gear Jammin-Dog Chasin-Yota Man
It could be done that way.
I would have a fire extinguisher handy when you cut them open with oil every where.
And if you weld them, be sure to have all that oil and grease no place near them welds or you will not get a good weld (acetone and grind the grease oil off).
It may seem like more work at first, but if you clean the axles up prior to cutting and welding, you will get a better result in the long run.  Just my  :twocents:
1975 FJ-55 Landcruiser: pretty much stock with 31 x9.50x15 TSL's
1992 Extended Cab Pickup: 22r, weber carb, 51" RUF, F-150 rears, Aussie Front, Welded Rear, etc.
Build: http://board.marlincrawler.com/index.php?topic=78730
Quote from: Chrstphrtptts on March 23, 2011, 10:08:26 PM
What do you mean by "aggressive"?
Shackle angle will be less steep if you shorten them, opposit if you lengthen them.  IMO Ideal shackle angle for ride and articulation is around 35-45 degrees depending on your preference
SloCrawler
Quote from: Gear Jammin-Dog Chasin-Yota Man on March 24, 2011, 09:04:32 AM
right now ther like 35 degrees and i would like it closer to 45-55 degrees, shorting my shackle i may be able to accomplish this
SloCrawler
Quote from: Gear Jammin-Dog Chasin-Yota Man on March 24, 2011, 09:01:32 AM
wasnt planning on cuting open just takeing off all stock brackets, oil helps not heating up and warping, my buddy told me to pull breathers or oil will come seals. should i use the plasma or blades?
superyota
ABD Motorsports
#4475
www.placercountycrawlers.com
KK6QDW
Oh, in that case, yeah, I think the plasma would be a good choice for what you are doing.
As for your shackle angle, yes, shorter shackles will give you more angle in your situation, I would just take a tape measure and hold it up to your existing shackle on the truck (with the truck sitting at normal ride height) and move the tape measure till you have a 45 degree angle and that should give you your new measurement eye to eye for your shackles.  Hope that makes sense
I like a 40-45 degree shackle angle, I think it rides a little better too.
To each his own.  Good luck and nice build :thumbs:
Peterbuilt84
What's your frame height with the new shoes?
SloCrawler
Quote from: Peterbuilt84 on March 25, 2011, 10:02:04 PM
22" right now, I imagine it will be the same when I add a 2 leafs to the front pack and shortin my rear shackles. Im going to drill extra holes in my shackles so I can play and tune the angles.
Zs Confederate Toy
ZACH
87 Rock Rat X
80 SR5 The Shady Lady
Trail Junky
SloCrawler
Her is the reason why my slow build got slower, Passanger/ driver in training
superyota
ABD Motorsports
#4475
KK6QDW
superyota
now i need to talk my wife into taking her to the roundup.  she'll be 6 months old be then.  thats old enough, isn't it?
ABD Motorsports
#4475
KK6QDW
Zs Confederate Toy
Heck yeah thats old enough. My old man had me in Elk huntin camp when I was jus a month old.
ZACH
87 Rock Rat X
Trail Junky
superyota
ABD Motorsports
#4475
KK6QDW
SloCrawler
I was going out on the parent jetboat by 2 months, im ok still to this day. Im going to take her to Red Rock this weekend and see how she handles the out doors.
superyota
Chris, go check out burro scmidt tunnel and last chance canyon while your out there.  i'll be in bako this weekend.  come stop on your way back if you have time.
ABD Motorsports
#4475
KK6QDW
SloCrawler
Quote from: superyota on April 27, 2011, 02:14:51 PM
got an adress I can put in the  gps. I'm going to Red Rock near lake cachuma. Nowhere near bako
