1966 Toyota Stout Build (20/22R Hybrid)
Started by SloCrawler, July 30, 2009, 05:47:42 PM
SloCrawler
#60
I put together a list of things needed before crawling.
  MOTOR
Check timing and adjust valves (think LC cam is  broken in)
Rear main seal
Helei coil oil pan bolt
Remove any leftover smog crap
  DRIVELINE
Transmission & TC seals
Sqaure front DL
  Front axle rebuild, truss and install 5.29
   Rear axle install needs spool and 5.29
   Shocks all around and partial exo and should be good to go.
SloCrawler
Got sum goodies
superyota
ABD Motorsports
#4475
www.placercountycrawlers.com
KK6QDW
wakkjobb
I love that flatbed... you're giving me ideas when I re-do mine someday. Strapping down stuff is okay but I'd like to have lockable and weatherproof storage. What's the advantage of running springs inboard?
Looking good!  :biggthumpup:
>>Dan
and you are going to love the 5.29s
SloCrawler
Quote from: wakkjobb on October 28, 2010, 10:11:11 AM
>>Dan
To achive better flex from springs, been waiting on 5.29s  :thumbs:
yota4x4sc
wats the pin to pin width on the rear? compared to stock..i did this on a samurai, mount inboard a lot and it flexed so savage!!!!!!!!!!!
:usa: 92 xcab, full width, 39.5 boggers, beadlocks, 60 f arb 5.86s , 60 r spool , duals, 4.7 rear... 3.sl0, bobed , all pro 6 inch leafs f and r :usa:
the_white_shadow
SloCrawler
found pics before lift
4x4yota
Current:
Sold:
SloCrawler
I'll let you know as soon as I get these 35s mounted. I'm going to  switch from 4wd rears to 2wd  and add 2 more leafs total 6. And that should he my final frame height. Also picked up an IFS axle the other day..yay...
4x4yota
I was curious of its current height on the 31s and setup
Current:
Sold:
SloCrawler
It's hard to be 100% because its on jack stands. But I think about 22"
4x4yota
#76
sorry didnt know it was on stands but thanks
Current:
Sold:
swillbuilt400
punchyyoter85
#78
i like the bug guard!
yota4x4sc
SloCrawler
Picked up an IFS axle with all new bearing and seals plus creaper breather, also seeing how the RAM above was to big for my truck I traded it for 4 Bilstein 5150s.
Rocksnail
I can so see my beach house in them pics. Truck is looking good keep up the work.
Do you know what they where doing to the beach in them pics? loks like they moved alot of sand out. Or is it from the weather? i havnt been to pismo in over  a year.
1993 4door  s10 Tahoe. 4.3 th350c duel toys w/4.7 rear, D60 front 5.13 welded. 14Bolt rear 5.13 mini spool,hydro assist, TG 5HD front springs, 63s out back. h2s with 39x14 17 Pit Bull Madd Dogs
SloCrawler
That was a year ago or more right in front of the Oceano on ramp, all caused by rain and tide. The wall must of been about 4' at first.
zeros215
Love your flatbed want to send me some measurements! Can't wait till I lift my 83. Looking good man
Learning every step of the way!
SloCrawler
got some 12" and 14" bilsteins, i think i might trade the 12" probly to small for me rear. what you think?
superyota
get them on the truck and see how much travel you have.
ABD Motorsports
#4475
KK6QDW
SloCrawler
got to fab all shock mounts 1st, you got 12s or 14s in your back superyota?
superyota
14's. i ran 12's for years.  worked great.  the only reason i went to 14's was because the 12's were limiting my down travel.  wait til you get a chance to mount them up and see how they fit.  my guess would be with f150 packs you should be good with the 12's.
ABD Motorsports
#4475
KK6QDW
SloCrawler
i would hate to have to switch to 14s later and lose 2" of up travel, i was planning on mounting  the shock on the outside of my springs, and i got 7" shacles on the rear. ill have to try and cycle flex on a fork lift 1st and measure before im thinking, what should i look for and measure for when i do this? sorry still knew to this and dont want to have to do it twice.
