Crawlerdans new 4runner build up......it begins
Started by crawlerdan, April 04, 2009, 08:50:50 PM
should i add this ?
ya
8 (66.7%)
no
4 (33.3%)
Total Members Voted: 12
crawlerdan
Quote from: wakkjobb on November 30, 2009, 02:57:13 PM
Awesome rig... should be on the cover of a magazine!! (maybe the centerfold too!  :bowdown: )
the I/C is off a volvo wagon, very common in wrecking yards.
im not sure about fans yet. i will have to wait until the radiator is mounted to see w hat kind of room i have
crawlerdan
while the intercooler, and power steering cooler are mounted, and look good- they may not be permanent. priority lies in the radiator and cooling fans. i know i can get a much more compact oil cooler, and mount it wherever the hell- and i have a much smaller intercooler as well. when the motor and radiator are in, we will find out.  ive used saab IC before, they worked very well until i wanted to push more then 12psi.
that being said- this motor is being built to peak at 7-9 and maintain that boost through its rpm range- teh saab IC was designed for a very small motor, and i think that the 2jz will flow enough CFM to turn it into in inter-heater, as i will probably flow way more then what it can efficiantly cool.
if i cannot use the massive volvo IC, i will likely use a stock supra IC and side mount it- it the location that the batery used to sit on this truck :D
TacoRunner
#392
www.4WHEELUNDERGROUND.com
[email protected]
wakkjobb
QuoteIf I cannot use the massive Volvo IC, I will likely use a stock Supra IC and side mount it where battery used to sit on this truck.
An idea for you: I saw an 85 diesel X-cab at the yard last week (in the parking lot, not scrap) that had a built bumper like yours... and the IC was mounted in the front left corner behind some expanded steel. Of course I didn't get any pics... but it seemed like a really slick way of mounting an IC. I'm filing that idea away if I ever get a turbo on the Runner I don't have yet; I'm still kind of amazed the turbo engines didn't have an IC! Figured it went hand-in-hand; with turbo comes IC.
What do I know anyway?   :blah:
>>Dan
crawlerdan
Quote from: wakkjobb on November 30, 2009, 06:06:16 PM
>>Dan
well that is an excellant idea, but i see two problems right off, it will get almost no cold air flow inside there, and second- it would be subject to whatever my tires decide to throw up at it. another issue would be finding an intercooler to fit in that hole, as it is rather odd shaped....and very small
crawlerdan
Quote from: TacoRunner on November 30, 2009, 04:10:02 PM
So Dan.
Dan the man.
Are you linking it? (Before you answer, I have freinds in the HA)(And they are big and hairy)(And they like to fight)
I need someone (like yourself) to Prototype a suspension system for me.
i would like to....i would be willing to discuss it, ill pm you my number
toyotanner
So Dan.
Dan the man.
HA? hells angels?
wakkjobb
QuoteWell that is an excellent idea, but I see two problems right off: It will get almost no cold air flow inside there and second it would be subject to whatever my tires decide to throw up at it. Another issue would be finding an intercooler to fit in that hole, as it is rather odd shaped....and very small.
The guy had some expanded steel in front to allow airflow and an angled cover to deflect tire debris on the back; may have had a fan too? It looked about the same size as the MkIV Supra's IC (I think) or about 8" tall by 12" wide, give or take. Kind of like a DSM IC for the Talons and Eclipses or even the Audi/VW; side-mounted in the wheel well.
Ah heck, you'll think of something great in no time.  :beerchug:
>>Dan
TacoRunner
[email protected]
crawlerdan
well, dropped the motor in today, its sitting on its own weight!! rolled teh truck out to clean the shop :D
there is anly about 1/4 inch of room between the radiator and the water pump, so thats a no- go. i will have to get a different radiator....hmmm
i will probably have to relocate power steering cooler and IC as well, dunno yet
there is GREAT clearance at the sides, for the header/turbo. I have WAAAAAY more room in there now as compared to the v6
crawlerdan
46&2
crawlerdan
i made a intake....the mass air meter will live somewhere in the charge pipes
i also got started on making a down pipe, on that note, plasma cutters and templates kick ass!!
crawlerdan
 :sleeping:
IF you wake up and MAGICALLY are missing your 4Runner... .Don't Call me :outtahere:
Both your 4Runners have always been my Favorites.... Damn you do some inspirational work dude.
46&2
Quote from: THK90 on December 01, 2009, 06:01:46 PM
X2 on that. Actually though I think I almost like this one better than the first....
crawlerdan
no runner 4 you!!!!
    :D
i just layed out about 90% of the intercooler pipes. i need to make a mass air adapter tommarow, and finish em up. im trying to do as many- cheap/free things as i can....since im not working right now- get all the little stuff outa the way for when i get parts.
put the fuse block back in, and mounted the 2jz coil pack on the fender well....its getting crowded in there :D
crawlerdan
Quote from: crawlerdan on November 30, 2009, 01:26:28 PM
im still on the fence about megasquirt. i had it in my last rally car, it was ok i guess. i have found a guy in so cal that can make a plug and play harness, that will allow me to use the ecu i have for the lexus, and retain all my guages, fuse block, ect. this is a option i will probably take, as i will daily drive this truck (or want to be able to at least) and the cost is a fraction of a standalone system
this was my rally car i ran megasquirt on...i miss it...i may do it again....ask me in two months :D
pumkin toy
97 4runner Limited
crawlerdan
well, today i got the intercooler pipes run, the blow off valve welded in and set, as well as made a new intake, that houses the mass air flow sensor....its pretty tight in there now... it will all have to come out when i get a radiator later on
holy toledo! thats one sick engine compartment!!!
pumkin toy
 :bowdown:damn!  makes me want to get my intercooler installed!  It would be nice to get it running first though :hammerhead:
97 4runner Limited
crawlerdan
got the throttle cable and heater hoses hooked up....my freekin hands hurt
Cheesemaker
Heck Dan you should have picked up a front clip and stretched the front end about 4 to 6 inches!
axled89
yeha that is tight dan.   so how close to it being done and trail ready?????
i love oregon wheelin.
crawlerdan
Quote from: axled89 on December 02, 2009, 09:19:43 PM
not close at all, i dont have a trans or cases, or flywheel and clutch...
TacoRunner
My head hurts trying to follow all that air ducting.
[email protected]
crawlerdan
pretty straight foreward, i guess...now i need to find a radiator with ports on the opposite sides...and a little smaller
Quote from: crawlerdan on December 03, 2009, 08:30:03 AM
what are you wanting to run?
R154 Bellhousing, R151F, Dual 23 Cases? ah boy wait til you see the price of a clutch on that thing!!!
so expensive on these Inline-6's
