Crawlerdans new 4runner build up......it begins
Started by crawlerdan, April 04, 2009, 08:50:50 PM
should i add this ?
ya
8 (66.7%)
no
4 (33.3%)
Total Members Voted: 12
Cheesemaker
I'm gonna have to come check this out when it's all together.  Since I know where you live.   :thumbs:  I drove by your way when I went to Kyota's to get tires from him.  I would have stopped by, but I didn't see any rigs in the yard.
crawlerdan
Quote from: Cheesemaker on October 13, 2009, 07:26:26 PM
well your always welcome here cheesy- you should stop next time
OOOOOO
Thats coming together.
Estimated time of completion?
crawlerdan
Quote from: THK90 on October 13, 2009, 07:33:39 PM
OOOOOO
when i get about 3grand to throw at it :D, hopefully before sept next year
yjay
Nice motor selection. Are you going to keep the same axles?
22re Daily Driver
http://board.marlincrawler.com/index.php?topic=56568.0
91 4Runner-R151f, MC07,23 spline duals, Marlin 1200lb clutch, 85 Front axle, Leaf swap rear, Yukon 5.29's, BFG KM2 35's, Detroit, OBA, 280k
crawlerdan
Voss
Got it runing yet ? That should be sweet.  Thing is going to be strong and sound great.
Geez...... this is going to rip.
specs on the engine?
isn't it the upgrade to the 7MGTE?
86bobbedtoy
dans just killing us,
come on with some pics!!!!
crawlerdan
Quote from: Voss on October 14, 2009, 08:02:01 AM
no- ask me in 6 months
crawlerdan
Quote from: THK90 on October 14, 2009, 12:04:30 PM
specs are- 2JZ-GTE (remember mine will be single turbo with a N/A intake mani
Engine bay of Supra JZA80The 2JZ-GTE is an inline-layout, six-cylinder, belt-driven dual-overhead camshaft, air-intercooled, twin-turbocharged, cast-iron engine designed and manufactured by Toyota Motor Corporation that was produced from 1991 until 2002 in Japan. Development and evolution of the engine was, principally, a response to Nissan's relatively new and then-successful RB26DETT engine which had achieved palpable success in FIA Group A and Group N touring car championships, worldwide. Final development of the 2JZ-GTE was outsourced to German engineering firm Johann A. Krause Maschinenfabrik GmbH for refinement to meet production car homogolation requirements set forth by the former All-Japan Grand Touring Car Championship.
For all applications, two gearboxes were mated to the engine:
Toyota A341E 4-speed automatic
Toyota V160 and V161 6-speed manual (jointly developed with GETRAG GmbH as the Type 233)
The 2JZ-GTE originally powered the Toyota Aristo V (JZS147) in 1991 before becoming Toyota's flagship performance engine in the Toyota Supra RZ (JZA80). Its mechanical basis was the existing 2JZ-GE, but differed in its use of sequential twin turbochargers and an air-to-air side-mounted intercooler. The engine block, crank, and connecting rods of the 2JZ-GE and 2JZ-GTE are the same with the exception that the 2JZ-GTE has oil spray bars installed in the block to aid in cooling the pistons. Toyota's VVT-i variable valve timing technology was added to the engine beginning in September 1997, whence it phased out the original engine. Consequently, maximum torque and horsepower was raised for engines selling in all markets.
The addition of twin turbochargers, jointly developed by Toyota with Hitachi, in sequential configuration had raised its commercially-cited output from 230 PS (166 kW, 225 hp DIN) to the, then, Japanese auto industry maximum of 280 PS (206 kW, 280 hp DIN) at 5600 rpm. In its first appearance, torque was advertised as 44.3 kgm (435 Nm, 320 lbft) to be later recited as 46.4 kgm (455 Nm, 335 lbft) with the introduction VVT-i in 1997. The mutually-agreed, industry-wide output ceiling was enforced by Japan's now-defunct Gentlemen's Agreement, exclusively between Japanese automakers selling to the Japanese domestic market. For North American and European markets, power was raised to 320 hp DIN (229 kW) at 5600 rpm.
The export version of the 2JZ-GTE achieved its higher power output with the use of newer stainless steel turbochargers (ceramic for Japanese models), revised camshafts, and larger injectors (550 cc/min for export, 440 cc/min for Japanese). The mechanical similarities between the Japanese-specification CT20 turbine and export-specification CT12B turbine allow interchangeability of the exhaust-side propeller shaft. Additionally, the export-exclusive CT12B turbine received more durable turbine housings and stainless steel turbine and impeller fins. Multiple variants of the Japanese CT20 turbine exist discretely, which are identified with the B, R, and A part number suffixes (eg.: CT20A).
The 2JZ-GTE engine is popularly associated with Nissan's RB26DETT due to their similar mechanical principles and auto racing pedigree. It remains as the only engine ever developed with the distinguished purpose of competing with Nissan's flagship touring car powerplant.
Applications:
Toyota Aristo V300 JZS161 (Japan-only)
Toyota Supra RZ/Turbo JZA80
it is the replacement of the 7m
YUMMM :D I think I want Diesel when my engine blows out.... i want some with a turbo or turboes when i go to a new engine.
crawlerdan
GOOD GRIEF, get ahold of a 1VD-FTV
I did not know Toyota made one!!! :gap:
crawlerdan
Quote from: THK90 on October 14, 2009, 09:59:34 PM
a wha..?? :inthedark:
it'd be Toyota's newest edition to the Diesel family
In 2007 the single turbo version debuted in the 70-Series Land Cruisers while the twin turbos were found in the 200-Series Land Cruisers in Australia.
V8 DOHC 32 Valve Variable Geometry Intercooled Turbo Diesel
single turbo: 202 HP/ 317 TQ twin turbos: 260/479 TQ
http://en.wikipedia.org/wiki/Toyota_VD_engine
crawlerdan
Quote from: THK90 on October 15, 2009, 11:34:29 AM
giggity
crawlerdan
well heres todays progress, hard mounted the intercooler, cut holes in the support to run intercooler pipes through. re wired all the lights and the winch, as well as plumbed the power steering cooler, all to route around teh intercooler that now lives there.
also trimmed the grill, heavily, to fit around the intercooler
crawlerdan
more
86turboyota
My Build 1986 4runner SAS 36s etc
http://board.marlincrawler.com/index.php?topic=22625.0
"Later, I learned that even though I engage 4WD my hubs are not automatically locking? Something about manual locking hubs I think. What's manual mean? I need to read a manual to lock them? lol  So I found these neat autolocking hubs and installed them. Sometimes they dont stay locked while I am backing up, but that's fine because I dont have a backup camera to see where Im going (like our RV) so I just simply dont ever back up"- BigMike
crawlerdan
Quote from: 86turboyota on October 15, 2009, 03:03:09 PM
looks good, now drop in that engine!
gotta get a bell housing , clutch, motor mounts ect, gonna be a few months
crawlerdan
got a little done today- made plated for motor mounts, now ill just add arms to em later
axled89
i love oregon wheelin.
crawlerdan
did a little today-
got the impossible to find- does not exist-billion dollar - rear sump 2jz pan
and a new factory single turbo coolant line
also cleaned up the plastic parts on the motor :D
crawlerdan
more
and just for the hell of it i added my shelby steering wheel
pumkin toy
cant wait to see this rig all done!  i'm picking up that 4runner with the 7mgte swap. i'm super stoked to get it!
97 4runner Limited
