Crawlerdans new 4runner build up......it begins
Started by crawlerdan, April 04, 2009, 08:50:50 PM
should i add this ?
ya
8 (66.7%)
no
4 (33.3%)
Total Members Voted: 12
CTENG in KS
What size are those spacers?  What they coming off for?  IFS hub conversion?
Oh gotcha :p
and damn they look like 2.5-3in Spacers
crawlerdan
Quote from: CTENG in KS on April 18, 2009, 09:25:53 AM
3 inchers, and im going to 1.5s and an ifs hub later
crawlerdan
well, i finished up the sas today, had to move the steering box about 4 inches foreward...what a PITA!
then i pulled it out, turned it around, and took the rear end apart.
plans for the rear are- 2 inch coil spacers, and sleeve the control arms with 1.5 dom and add johhny joints at one end.
they will be 2 inches longer, adjustable, and flexible.
im not sure about the final ride hieght, i may need to add oldmanemu coils later
crawlerdan
 :thumbs:
crawlerdan
 :yawn:
84xcab
Bobbed 84 xtra cab, pickin up parts as I go.
If at first you do not succeed, put it in 4low and try again.
crawlerdan
today i wired my e locker in, an auxilary fuse panel, my kc lights, and i pulled off my 3 inch wheel spacers in favor of the 1.5s.
the front axle is stoopid far foreward, i love it (although getting the steering box up there sucked)
with the rears up front its moved a total of 5.5 inches ahead of centerline, leaving me with my favorite wheelbase :D -111 inches....its my magic wheel base, my triple cased 85 was 111, the 87 runner was 110, i like it.
pumkin toy
5.5 inches! holy crap! thats awesome.   i really want to move my front axle forward a bunch more too
97 4runner Limited
John Doe
DAMN DAN!!!!!!!
that will make it more stable!
I may move mine as far forward as I can!
offroadin88
based on where most peple mount there front hanger (flush with exising crossmember) where did you mount yours looks about an inch.
also whats your frame height? looks bad ass so far
crawlerdan
Quote from: offroadin88 on April 19, 2009, 09:55:49 PM
not sure on the framwe height, as it isnt done yet, ill have the rear done later this week. should be around 25.5-26.5 with 37s. the 87 was 28 and this one is waaaaay lower so far
crawlerdan
oh and teh hanger is 2.5 inches foreward of the factory x mamber, the plate you see in the pics is part of the warn bumper, not the frame. combine that with 1.5 inch movement for the rears up front, and the fact that the hanger was drilled for 1.5 inches foreward to begin with...and you get magic wheel base (for me at least  :yesnod: )
offroadin88
well it looks bitchin when you get to flexing it out let us know how much up travel you are getting
well then ill make a hanger and mount it 1-1.5in forward from what an 85 stock hanger would be.
Cause I'd like to have it forward more then most.
46&2
Looking good Dan!  :beerchug:
Are you going to have to trim a little out of the front bumper?
crawlerdan
Quote from: fortysixandtwo on April 19, 2009, 11:02:50 PM
i dunno yet, i doubt it
offroadin88
why didnt you move your front shackle mounts forward 2.5 inches to compinsate for the hanger moving up so far?
95toyrunner
Could you post some pics of your modification process of the rear links?
1995 toyota 4runner, sr5, 5" sas, ome 863 coils, extended links, 37" MT/r's, 4.88's
http://board.marlincrawler.com/index.php?topic=51430.0 SOLD
1996 Toyota Tacoma ex-2wd, 2rz, 3link 14"FOAs, dual ultimate cases, chevy rear, 37" MT/r's, 4.88's
http://board.marlincrawler.com/index.php?topic=91724.0 SOLD
2001 Taco Dcab, king coilovers, 4.56 gears, detroit, 33's, SOLD
1999 Taco extracab, 3.4 5 speed, sas'd on one tons, 37" km2's, spooled front, detroit rear, bobbed, tirecarrier, hydro asist, high steer. SOLD
2005 4runner, sway-a-way coilovers, all pro rear 3.5 springs, 285 ko2's on method NVs SOLD
2016 4unner Trail, Icon stage 6, 285/75 Toyo's, full armor
88 4runner SAS, 37's, duals, etc
crawlerdan
Quote from: offroadin88 on April 20, 2009, 10:13:26 AM
i moved em an inch, and it sits right where i want it
crawlerdan
Quote from: 95toyrunner on April 20, 2009, 11:21:56 AM
when it happend i will, im still debating on what exactly to do
crawlerdan
well today i whipped out the plasma and made some brackets to raise the panhard bar about 5 inches, this is a must when lifting a 5 link
i used 1/4 hardened plate
i also replaced the factory rubber bushings with a 2.5 wide poly joint and it is adjustable :D
i even rewelded the lsvp valve on the track bar :D
crawlerdan
i hope this is way overkill :turtle3:
crawlerdan
95toyrunner
crawlerdan
Quote from: 95toyrunner on April 20, 2009, 09:25:56 PM
you ordered new ones? what kind? Allpro?
um... no- they arent as long as i want and wouldnt do custom lengths...and i dont like heims for street driven vehicles as they wear poorly and are costly to replace, im using curie johnny joints that are fully rebuildable :D
95toyrunner
So you bought parts to make your own upgraded links?
crawlerdan
yes, they will be johnny joints at one end, poly joints at the other, adustable about 1.5 inches, and be 1.5 .250 wall dom tube :D
