Crawlerdans new 4runner build up......it begins
Started by crawlerdan, April 04, 2009, 08:50:50 PM
should i add this ?
ya
8 (66.7%)
no
4 (33.3%)
Total Members Voted: 12
crawlerdan
2.5 inch stainless magnaflow high flow cat and muffler = giggity
pumkin toy
i like pretty exhaust!  I wish mine was that pretty :rivers:
97 4runner Limited
Gixxer Jon
Quote from: crawlerdan on February 08, 2010, 12:05:04 PM
Yup i just installed my magna flow cat today so it would pass Ca Smog....
Hillcrest Crawlers
_________________________________
||_________||_________||__TOYOTA_||
||_________||_________||__________||
http://board.marlincrawler.com/index.php?topic=67011.0
crawlerdan
today i ordered-
1 jz bell house-r154
1jz flywheel
OEM Toyota flywheel bolts
OEM toyota turbo clutch
OEM slave cyl., clutch fork, release hub, detent balls and springs
new ECU
and a plug and play harness for the conversion.....teehee
:driving:
pumkin toy
Quote from: crawlerdan on February 08, 2010, 08:52:31 PM
today i ordered-
1jz flywheel
new ECU
:driving:
sweet dude!  so is that so you can get it running N/A?
97 4runner Limited
crawlerdan
ya, it basically will be running as a hopped up gs300 or sc300
pumkin toy
Quote from: crawlerdan on February 09, 2010, 07:39:31 AM
even with that setup it will probly still have bigger balls than my 7mgte!
97 4runner Limited
Goldrush
how much was that cat, if u dont mind me asking?
Gixxer Jon
If i recall its about 120 @ autozone, and for direct fit add 100 bucks to that. comes with a 5 year warranty too
Hillcrest Crawlers
crawlerdan
crawlerdan
Quote from: pumkin toy on February 09, 2010, 05:10:41 PM
about the same HP, but WAAAAY more torque
Goldrush
crawlerdan
oh ya, this is what ive been waiting for...now we can get in some trouble.
these are all OEM toyota supra turbo parts...mmmmm....sexy
crawlerdan
ooo, OEM turbo clutch and flywheel
crawlerdan
here is an r150 suited for use behind a jz series motor
notice anything weird?
Goldrush
crawlerdan
Quote from: goldrush on February 15, 2010, 08:30:18 PM
ur pic is blurry?
granted- that it is- but what is weird is that the slave cyl mounts to the backside of the bell and pushes foreward, rather then the oppostite. the clutch is a pull style throwout, rarther then push like all the w and r series we're used to
Quote from: crawlerdan on February 15, 2010, 09:03:34 PM
not only do you have a weird style slave and throwout... but your trans is an oddball.
MANNNN DONT BREAK ON A TRAIL! lol
Sexy lookin OEM Parts Dan!!!
Get your build on bro!
crawlerdan
ah man- this stuff makes me say giggity
zippo
Nice work. you flip flop with ideas as much as i do.
If you see it, its for sale.
crawlerdan
i installed the motor and found out that the motor sat too high in the chassis, so the trans would not bolt on.
so i have to scrap my motor mounts and re do them where they need to be.
on the positive side, now the motor will sit lower and further back, helping with weight distribution and center of gravity, i now have a ton of room in front for fans, ect
here is the stuff installed in the new location, it moved my trans back 6 inches which means my original crossmember and drivelines are useless now, but oh well, i make new.
pumkin toy
Quote from: crawlerdan on February 15, 2010, 08:15:27 PM
yeah, no dual cases!  ha ha
lookin great Dan, i like all that new shiney aluminum!  I think you will be very happy that you ended up moving your engine down and back
97 4runner Limited
crawlerdan
got the clutch slave mounted, and all the lines bent, bled it, it works!
also bent and installed fuel lines.....double flaring is a pregnant dog.
all i need to do is remake motor mounts, make new tranny mounts, and install harness....giggity
crawlerdan
today i made shifters, re installed the center console and tested everything, also installed an adapter plate from advaced adapters to work with the tranny in a different spot
also installed the mid pipe, will finish exhaust tommorow
Cheesemaker
Holy shims Batman!!  Your pretty much there Dan.  :thumbs:
pumkin toy
Dan are you going to have any issues with your front driveshaft hitting your stock crossmember?  just wondering with that extender plate thing on there!  Lookin great though Dan!
97 4runner Limited
crawlerdan
Quote from: pumkin toy on February 22, 2010, 08:20:15 PM
i dunno yet, i need to make new shafts, and will modify it if i have too
