Jrock's BuildUp
Started by jrock, April 04, 2009, 06:21:30 PM
jrock
Quote from: Duffil on May 20, 2009, 08:23:49 PM
do you remember when I told you that you overthink things?
Well, ya, you're doing it again. :gap:
:gap: That's me! But really, I want very little lift and this is the first step, with it I'm already lifting the truck.
Duffil
it is on half of the leaf, so if you get one inch of vertical separation, you are only increasing ride height by .50".
same theory as a 1 inch over stock shackle.
jrock
Okay... you sold me. There's no other way of doing this other than frenching it and I don't want to get into that yet.
Duffil
jrock
jrock
Think it'll hold....  :muscles:  :laugh:
Duffil
those are grade 8 right? well then just pack the whole area with JB Weld and it'll be waayy overkill. do it. trust me. :gap:
*** YELLER ***
Quote from: jrock on May 21, 2009, 05:23:00 PM
give me a couple weeks and I'll weld it on for ya  :biggthumpup:
:usa: :beerwhack:
except BACON
jrock
 :clap: :laugh:
They are G8 and they're just for mockup. I plan to take it into Valley Trucking in Stockton and have them weld it up. I will likely leave the bolts in after for the hell of it.  :gap: Then I get new springs!  :crossed:
unclejpl4x4
i say duck tape and bubble gum
jrock
Quote from: ÜncleĴ on June 05, 2009, 06:49:20 PM
Read my mind  :D
Well, my truck is now part Ford.  :gap:
Pictures tomarra.
jrock
Not as good as I expected but I still haven't tweaked with it yet.
Double shackle Ford + 6in. Front mount moved 5in forward. 2wd F150 4 leaf with last removed and still has overload (stock u-bolts barely work).
fordh8r
Looks good! Is that left side rear shock hooked up? It looks like it's just hanging there.  :headscratch:
jrock
#74
It is, I thought it was limiting flex but it's the shackles that's limiting it. The bolts are too tight.
EDIT: It is the tires hitting the frame that limits the droop.
jrock
I happened into the back entrance of the Rubicon last week  :D , from Tahoma, Tahoe and was surprised at the lack of vehicles. 4 hours on the trail (total) and I only saw 2 other vehicles. There was water and that was fun, I got lost and never found any good stuff  :thumbdown: .
jrock
BTW, does anyone in near the SF Peninsula have a set of 1.5in wheel spacers I could borrow for a very short while. I want to see the stance and flex of wider axles. Please.  :bowdown:
hilux-1983
What are those rear shackle looking thingys? Are they bolted on too?
Do these parts interest you any?
jrock
Quote from: hilux-1983 on June 20, 2009, 06:51:31 PM
The Double Shackles? The horizontals are Ford stock rear shackles and the verticals are 6in shackles.
Do you have spacers? What's the thing in the bottom left?
hilux-1983
Quote from: jrock on June 20, 2009, 08:46:53 PM
It is an extension for the torque rod. If you bolt it on and re-attatch the torque rod, it wont jerk to and fro when you hit the brakes. I took all of it off to install hi-steer. I figure you already know the other part is a drop arm. I do not have spacers, sorry.
jrock
Sorry, I don't need anything of the sort. I had my torque rod extended. Thanks though.  :biggthumpup:
jrock
#83
Hollister today and... well... it's started....  :headscratch: Where to go from here?
fordh8r
Looks like you're ready for a flatbed now.  :gap:
Slolyfe
Carry a can of spray paint! That'll take care of most damage!
You'll never take me alive
luvyota
luvyota
jrock
Got me some histeer! Yeeeeaaaaah!
jrock
Rented a Lincoln 125 from HomeDepot. This is cool. Time to get stuff done.
jrock
Tackled a project that has been pissing me off the last few trips. My tires, in the stock location, shoved so far into my firewall that they have been ripping off tread  :thumbdown: . Real real bad. So I drilled some new spring pin holes in my perches and moved the axle forward 1.5inches. Cut off 1/2inch from one side of my adjustable draglink and fitted it all back together.  No more rubbing... well, until I do 35's  :king: .
