Yjay's 2nd gen 4runner
Started by yjay, March 18, 2009, 06:27:05 PM
crawlerdan
Quote from: yjay on June 07, 2009, 09:33:20 AM
I torched off the outer portion of the brake plate/dust shield which had a support for the hard brake line. Any suggestions on how to support it now or how you've done it? Pix would be great.
I'll post some pics of the runner next week after the KM2's go on. Still trying to decide what width rims and offset to do. Don't want it so wide the wheel bearings suffer, plus I drive past the PO PO shop on my way to and from work.
zipties are your freind
yjay
#121
I know that's not how you did it, your attention to detail is disturbing :slap:
What are the rims on your runner Dan? They look good.
22re Daily Driver
http://board.marlincrawler.com/index.php?topic=56568.0
91 4Runner-R151f, MC07,23 spline duals, Marlin 1200lb clutch, 85 Front axle, Leaf swap rear, Yukon 5.29's, BFG KM2 35's, Detroit, OBA, 280k
crawlerdan
Quote from: yjay on June 07, 2009, 09:56:34 AM
they are called soft 8s, american racing makes a model, allied makes a similar model
seriously though, cut the tabs of the old backing plates, make a small plate to weld to the frame to hold em, and if you cannot reuse the clip, two zippies will hold it fine, this is what i had to do :D
get this bad boy done bro.
if you need any help this next weekend, just hollar.
I am trying to pick up a 98 Tacoma 145mi 3RZ 5spd 2in lift on my 33s crawler front bumper and 4x2 tube rear.
its pretty nice.
anyways let me know YJ.
yjay
Quote from: crawlerdan on June 07, 2009, 10:25:42 AM
I did exactly that, but i figured the hard line needed to be supported near the caliper?
What width and offset are the rims? I was planning on using soft 8's, had them on my jeep for a while.
22re Daily Driver
crawlerdan
Quote from: yjay on June 07, 2009, 12:49:08 PM
ive run no support on the hard lines for about 10 years on 6 different rigs, never had an issue, is it possible? yes, but not likely
yjay
Right on. I think I'll just make some short ones then, like 3 inches or so.
What about the width and backspacing on your rims? I'm gonna buy some tomorrow if I can figure out what I want.
Thanks.
22re Daily Driver
crawlerdan
Quote from: yjay on June 07, 2009, 07:02:02 PM
Thanks.
im not sure, like 4.75 call les swchab and ask, they refer to whatever mine are as "standard rear wheel drive offset"
yjay
Got new shoes today. 35x12.5 BFG KM2's. The stripes on the steelies gotta go. I am pleased with the road manners of the Detroit. I think I may drop the front a little, and maybe try to stiffen it up because it dives pretty hard under braking. I'm also going to run some type of swaybar with disconnects up front. Should be a fun project. Now for bumpers, get my winch on etc. etc.
Yes the running boards will go
22re Daily Driver
that looks hella good man.
i will shortly follow no worries.
thegoofster21
brake clean will take stripes right off.
Quote from: crawlerdad on October 08, 2009, 08:21:17 PM
Any guy who takes his woman wheeling enjoys her. A woman who is owned is left at home to cook, clean, and keep beer cold. So if this offends you you should stop looking and go have some tacos.    :rofl2: And a beer. If your old enough.   :beerchug:   :beer:
04 Tacoma 33s http://board.marlincrawler.com/index.php?topic=61454.0
jmoffroad.com
boggerunner
gotta loose the running boards.
LilChief87
 :beerchug: clean got any other plans for it
yjay
Upgrade the front axles and lock the front, make some bumpers and sliders, interior cage.
22re Daily Driver
get an aussie bro... they work great!
yjay
Can someone tell me where the other end of this plug is. It comes from the engine bay and is in the same harness as the reverse light and the neutral sensor. The picture sucks, but it's 3 prong. I can't believe I can't find it, obviously it's right there  :maddest:
22re Daily Driver
uh.... 4wd indicator?
or ADD connection? idk.
i could go look on my auto in a bit and tell you
Jud
Idk what that is but you should put square ubolts on the left side of your front axle. Those things will always stretch and come loose then break on you.  :twocents:
"bout tree fiddy"
yjay
Just temporary. Thanks for looking out  :thumbs:
22re Daily Driver
Goose
Quote from: THK90 on June 13, 2009, 02:54:22 PM
Its that thing....
Its from the old ifs axle..
Im still trying to figure out what to do with mine, i just ziptied it up for the time being..
Baller Status: Coming Soon To A Toyota Near You!...   :afro:
My Life Is A Very Complicated Drinking Game... -Me
90 ext. cab v6, SAS'd, 37's
94 4runner -work in progress
www.slagfactory.com
My Buildups:
'90 ext. cab
http://board.marlincrawler.com/index.php?topic=38260.new#new
'94 4Runner
http://board.marlincrawler.com/index.php?topic=53882.new#new
NorCalToy
Quote from: Goose on June 13, 2009, 11:33:33 PM
Its that thing....
it looks like the plug for teh green light on teh dash sayin your in 4x4. my green light doesnt light up if that thing isnt plugged into my IFS diff
:flamer: IFS
Quote from: NorCalToy on June 13, 2009, 11:36:05 PM
:werd:
Goose
It is, it plugs into the ADD thing. Im still trying to figure out if you short it out, if it will make your green 4wd light work normally again or not.. idk yet though..
www.slagfactory.com
My Buildups:
'90 ext. cab
'94 4Runner
yjay
Made a front driveshaft from parts lying around. I put both cases in low and let the clutch out in 1st holding the brakes and I have approx. 3/4" of slip left under compression, but in reverse doing the same thing it shows the splines. Not sure what it will do under real testing, but it doesn't look good. The stock yoke may not do it :thumbdown:
I'm kinda bummed cause a guy I know with a really flexy runner uses the stock yoke and has no problems, so I was hopeful.
Square shaft time maybe (only temporary if I do).
Pretty gnarly that it will push the suspension to the bumpstops at idle.
22re Daily Driver
yjay
Finished my square front driveshaft today. I was worried about getting the CV joint installed square into the tubing, but I learned that if you find a shop that makes driveshafts for agricultural applications, they can center them because square shafts are common for that kind of thing. I had everything prepped and they got it set within 5 thousandths. Also got some good inner and outer axle shafts for spares.
Minisimp's thread on making square driveshafts is great. Thanks Mini   :yesnod:
22re Daily Driver
yjay
#146
Minus running boards.
22re Daily Driver
yjay
#147
New bumper, old winch. Did the t chain, tensioner, guides,oil pump. The ones that were in there looked brand new. The guides showed no signs of wear at all. Oh well, you don't know till you get in there. Adjusted valves as well, they were pretty good though. Seems to have been very well cared for.
275k miles and doesn't ask for anything.  :driving:
22re Daily Driver
95toyrunner
that looks great...let see a side pic of the runner with the new bumper and winch
1995 toyota 4runner, sr5, 5" sas, ome 863 coils, extended links, 37" MT/r's, 4.88's
http://board.marlincrawler.com/index.php?topic=51430.0 SOLD
1996 Toyota Tacoma ex-2wd, 2rz, 3link 14"FOAs, dual ultimate cases, chevy rear, 37" MT/r's, 4.88's
http://board.marlincrawler.com/index.php?topic=91724.0 SOLD
2001 Taco Dcab, king coilovers, 4.56 gears, detroit, 33's, SOLD
1999 Taco extracab, 3.4 5 speed, sas'd on one tons, 37" km2's, spooled front, detroit rear, bobbed, tirecarrier, hydro asist, high steer. SOLD
2005 4runner, sway-a-way coilovers, all pro rear 3.5 springs, 285 ko2's on method NVs SOLD
2016 4unner Trail, Icon stage 6, 285/75 Toyo's, full armor
88 4runner SAS, 37's, duals, etc
