Yjay's 2nd gen 4runner
Started by yjay, March 18, 2009, 06:27:05 PM
yjay
Where's he located? I'd prefer not having to remove all the brackets on the runner axle, it sucks. Are 87 axles the same width?
I am going to run 5.29's open front for now, probably a spool out back. Eventually Detroits and Longs.
22re Daily Driver
http://board.marlincrawler.com/index.php?topic=56568.0
91 4Runner-R151f, MC07,23 spline duals, Marlin 1200lb clutch, 85 Front axle, Leaf swap rear, Yukon 5.29's, BFG KM2 35's, Detroit, OBA, 280k
Quote from: yjay on May 04, 2009, 08:20:40 PM
86-95 is all the same width yes.
He is in Sandpoint, Id as well as I am.
I just got off the phone with him.
I can give you his number and you can give him a call?
89sastoyo
WTF That rotor is so bad who in there right mind would do that lol.
89 extra cab stock on 1 tons.
92 2wd DD
first gen cab
Check out the build.
yjay
I'm ready to cut and turn my knuckles but would like some more info before I do it. I searched but didn't find any comprehensive threads. If anyone has a good link that would be great. I assume  ::) you can readily see when you've reached the inner tube with a cutting wheel, I'm kinda wondering how far inside the factory weld to cut, maybe a half inch? How thick is the outer tube?
Oh, and that rotor mic's at .110.
22re Daily Driver
you interested in the rear axle trade?
yjay
Yes, but I'm not sure when I'm doing the swap. It may be a few weeks away. It's my driver so when it goes down I'm kinda stuck as far as an exchange. I don't really know how to work it without having the axle here first and he doesn't know me from Adam.
22re Daily Driver
well its just sittin at our personal boneyard... so let me know... I'll relay the situation to him for ya.
the 87 IFS rear isn't going anywhere anytime soon
LilChief87
damn good job cleanin that axles up you could almost eat off of that dang thing haha
yjay
Cut my axle tubes to turn the knuckles and set caster and pinion angle. To whom it may concern (because I looked for this info and couldn't find it) the outer tubes are 3/16" thick. I used a grinder to determine the thickness, then made my cut with a pipe cutter I rented for 15 bucks. I made my cut 3/4 of an inch from the end of the tube. I'll open it up a bit before welding. I'll set the final pinion angle and 6 degrees of caster when I do the sas and can put it under the weight of the vehicle. Putting some heat on the outer tube makes it easier to rotate as it is a pressed fit.
22re Daily Driver
yjay
Got most of the parts today to finish my sas. Front 4" kit with all the garbage, rear 5" coil to leaf kit. Surgery scheduled tentatively for next weekend. Just waiting for a speedo extension cable and knuckle ball gusset kit. :werd:
22re Daily Driver
Quote from: yjay on May 08, 2009, 05:38:32 PM
So when will we need to do the axle swap?
yjay
I don't know when I could get to Sandpoint with my runner down, so maybe I'll just use the axle I have.
Some progress today...
22re Daily Driver
4runner freak
Finally got my '85 4runner!
Let the buildup begin!
Working on DUAL-TRANNYS
http://www.pirate4x4.com/forum/showthread.php?t=862345
Talon84x4
Low & Slow 84 PU - http://board.marlincrawler.com/index.php?topic=31982.0
Central Valley Crawlers
yjay
It's not. It just looks weird because it's shiny and has an odd reflection on the bottom truss. Birfs came out super easy.
THK90 check your PM's.
22re Daily Driver
Quote from: Talon84x4 on May 12, 2009, 12:10:14 PM
i was wondering the same thing
I do see what they are talking about though.
and okay YJAY. my keyboard is messed up and takes forever to type.
ill ask him bout that
yjay
22re Daily Driver
yjay
Started last night. pulled the rear end, fuel tank, tranny and t case. I'm wondering what the mechanism is that is on the rear crossmember that has an arm going to the axle and the rear brake line goes to. Proportioning valve maybe? What do you do with
it ?
22re Daily Driver
Yotaman80
That is a LSPV (Load Sensing Proportioning Valve) it distributres more fluid to the back brakes as you add a load to the bed or back cargo area in your case. I took mine out cause it was frozen and leaking. Then relocated the mount for the brake line so it just doesnt hang there.
80 Mini Truck-6" springs, Custom Cab Cage, 5150 Bilsteins, 5.29 Yukons, Aussie Locked, Warn M8000, 35"MTRs 5-Points, Diff Breathers, Sliders, Custom Front and Rear bumpers thanks to FATKID
Build Up- http://board.marlincrawler.com/index.php?topic=50320.0
yjay
#80
Grinding makes me grouchy :snare:. Lotsa brackets and tow points out back.
Also ordered a v6 rear 3rd with a Detroit and 5.29 Yukons and 35" KM2's yesterday.
22re Daily Driver
yjay
What do you guys think about my shackle angle in the rear? The first pic is compressed and the second is full droop. 5" springs with 5" shackles. I suppose they'll sag a bit too. Everything is tacked so if I have to now's the time to adjust.
22re Daily Driver
crawlerdan
GJToyotabug
looks good. looks like you'll have max droop and max compression or at least as close as it will get
yjay
22re Daily Driver
yjay
Got the ifs off tonight. Note: always wear gloves when using a grinder with no guard. Pic 2 is the result of trying to grind my knuckle off. Now I feel a kinship with the runner :thumbs:. Gotta shed blood to make it real.
22re Daily Driver
crawlerdan
one time, i was using a 8 inch diam wire wheel on a  car trailer, and the wheel caught the edge, kicked back, and tore my shirt off....hell it didnt even buy me a drink first...
left me with no skin in a figure 8 shape on my chest... that was hard to explain :yupyup:
yjay
A guy I was working with one time was backgouging a full pen weld on a moment connection at face level with an 8 incher when it kicked back and sawed thru his face shield and went thru his lips to his teeth. Good example of why when you're cutting with a grinder to always have the wheel pulling away from you just in case  :thumbs:
That must have been rowdy to have a grinder disrobe you without getting totally maimed.
22re Daily Driver
