Glen's budget rebuild
Started by 79coyotefrg, September 26, 2004, 05:30:02 PM
0 Members and 36 Guests are viewing this topic.
they are Rockford brand  :dunno:  i used them yesterday  and they feel and work great
yota_krawler
unclejpl4x4
dont need no stinkin a/c now  :haha:
Josh and Sean are here i gotta go :whip:
cutting the floor
test fit
trim to fit,  Josh working up a sweat :whip:
whats left  :headshake:
Josh's  nifty cutting ,  and yes  he  did  a great job  and measuring and  making the cut match  :bowdown:
and heres Sean  working hard
heres  the floor  of the blue truck :yikes:
unclejpl4x4
YotaJosh
One thing is for sure, you won't run out of anything to do for a while! :thud:
Here's that radiator I was telling you about. I don't know if it will work in a truck or not.
http://board.marlincrawler.com/index.php?topic=40081.0
'79 Short Bed Pickup 4x4
'04 4Runner V8 Sport 4x2
a camry  :eek:   i asked  for pics out of the box,  :dunno:  maybe it'll work
4inchToyotas
that second hole is for the crawler shifter? I assume it is, just gotta make sure.
I've gotten buckets put in mine and now am thinking about a center console vs the small glove box.
2006 Tundra DC 4x4 - DD/Tow (if I can ever find a place to store a trailer)
1983 Hilux - 20/22r Weber 32/36 carb, 4" ProComp suspension, 5.29's Lockrite Front, Spool rear, 34x10.50x15 LTBs
yea  i still have to cut the hole for the tcase shifter
hey Josh  look at this http://car-part.com/cgi-bin/search.cgi
ArkieToy85
Yay I got my Marlin publicity!    :gap:
Quote from: 4inchToyotas on December 29, 2007, 05:23:41 PM
OH  that second hole  :aaa:
Quote from: ArkieToy85 on December 29, 2007, 07:02:04 PM
:haha:
well it didnt take too long to get everything fitted together
:thud:
i wish i had  Josh's  cutting skills :down:   now i gotta fix a couple holes  :tantrum:
a little primer , i gotta paint it befor i install the wiring
rear view
yes  thats a lawn mower blade,  i used  2 of them  sandwiching the  sheet metal between them  then welded them together
you know me  BEEF
um  yes  i  put the primer on with a brush,  i want longevity,  pretty  comes second,  when i can i'll try and pick up a  small  sprayer
YotaJosh
Cool, you moved pretty quick today.
You can thank Milwaukee for the mad sawzall skillz. :ninja:
:thumbs:  yea  i found  my welding skill need some polishing,  i turned the welder down to 60 amps,  it does  great  on the thicker stuff,   the thin parts  im going to sandwich  with  some sheet metal  with JB weld  in between
well  i didnt JBweld  anything,  i decided  to use a filler rod while  welding and it turned out GREAT,  finished  all the passenger side
pics  tomorrow,  yea  i forgot the camera  :wall:
oh  and  i  sprayed  the firewall and inner fenders  blue  and installed the wireing harness :woohoo:
tomorrow  brakes and clutch,  and finish filler welding the drivers side,
Gittinit
                                        Function
____________________________________________________________
                                          Form
But lawnmower blades? Are you adding much structural support by putting them in there the way you have them? If they arent welded in solid and you were to have a breck again, you could end up with a new reason for a sore but.  :spankbutt: With the amount of welds you have there you might be good to go for the assembly then drive it to somewhere and have it welded in a little better, then finish it all with some seam sealer.
I am not a body man btw.
my favorite places:
http://www.flatnasty.net/
http://www.orvpark.com/
well these  blades  are  short,  they have  3 holes in them  are like 1/4 inch thick,  and i used  grade 5  bolts,  this forces  the  2  pieces of cab  to  line  up together,  i'll get pics tomorrow  of the welding i did today,   its  not coming apart,   remember how i build bumpers??   thats  the theory  im using here
unclejpl4x4
NO JB weld :yikes:   it;s gona fall apart.
j/k    looking good   now i got get out side and weld my exaust
CTENG in KS
The real test will be trying to fit doors onto it.  If the doors fit well then that is a fantastic job of measuring!
Quote from: CTENG in KS on January 01, 2008, 07:41:17 AM
already did,  :woohoo: DOORS FIT GREAT :woohoo:
a little paint to get me in the mood
pass side floor
drivers side floor
patched the big holes i made,  :_oops:
gotta be able to stop ,  THANKS  to Baldwookie  for  allowing me  to work on his truck,   "Will work for parts"  :disturbed:
gotta love those 1ton MCs
wish i could feel how they work compared to the stock ones :down:
then i moved on to  getting ready  to install the heat/air boxes  and decided i better clean them :yikes:
now  befor the wreck my  heater  and defrost barely worked   NOW  i know why
NASTY
OH  missed a floor pic
KDXSR5
eeeeeeeeeeewwwwwwwwwwwwwwww :reg:
