Glen's budget rebuild
Started by 79coyotefrg, September 26, 2004, 05:30:02 PM
0 Members and 11 Guests are viewing this topic.
Quote from: skipnrocks on November 28, 2007, 03:55:22 PM
I cant picture it, seems like the shaft to the rear axle would always be hitting the front axle...
um  no  actually  the front or "middle" axle  would be limited  in travel sort of,  the rear  would be designed to flex  like crazy
as well as the front
i would need to talk with Willymammoth  about how  strong those Nissan divorced tcases  are
maybe a junkyard  ford  divorced np205 :dunno:
skipnrocks
Quote from: 79coyotefrg on November 28, 2007, 04:22:11 PM
i dreamed this idea up a couple years ago  but  convinced myself  it wasnt  worth while because  my truck was so clean,  well  aint gotta  worry about that anymore :down:
So ill take that as a yes...  Do you have any pics of what your thinking?
WILLYNILLY
Gittinit
You shouldn't have to limit the travel of the middle axle, so long as you have enough room for a slip yoke between the divorced case and the axles.
I like the idea, but I would much rather see you get something going soon, and hen mabye tinker with the frame and extra axles you have later. A project like this would take a little time to get everything squared away, then you have all the common bugs to work out.....Get something going so we can wheel!
my favorite places:
http://www.flatnasty.net/
http://www.orvpark.com/
Jordan7118
Quote from: ImaPostHoToy85 on November 28, 2007, 03:48:31 PM
my xcab is 112 isnt it?
Oops... I did misinterpret you "no SWB" My bad...
How do you like 112? What kind of wheeling are you doing? My 'Runner's a SWB, but I'm thinking of stretching it a bit. Sorry for the hijack, Glen, but I'm wondering what you think about your LWB.  :bowdown: for your input
DanS
Glen, are you getting sidetracked? Should you not concentrate on getting some 'Toyota' armour around you! Rental vehicles are not 'GLEN' protected  :yikes:                                   :yupyup:
DanS
Wow, been looking at my 4Runner rust away too long, need some inspiration and here I will find it...!
85 Toyota 4Runner, solid axle, 22Re, original paint and graphics and not a straight panel to be found!
Quote from: DanS on November 28, 2007, 05:54:08 PM
DanS
i only had the little rental for a little over a week  :down:
DanS
Tell me your not being driven around in the family Limo  :rofl2:
4inchToyotas
Quote from: 79coyotefrg on November 28, 2007, 03:50:52 PM
rockwells would be WAY too heavy  and WAY too pricey
I could get you a set of 'mog axles heheh
2006 Tundra DC 4x4 - DD/Tow (if I can ever find a place to store a trailer)
1983 Hilux - 20/22r Weber 32/36 carb, 4" ProComp suspension, 5.29's Lockrite Front, Spool rear, 34x10.50x15 LTBs
Quote from: 4inchToyotas on November 28, 2007, 06:50:48 PM
are MOG axles a  thru pinion design ???
4inchToyotas
not sure, but they'd be hella cool under your truck ;)
this is the basic idea  for the suspension,
although  using this basic design  i would probably use a  chevy 3/4 ton 63 inc leaf pack  inverted  and mounted to the frame
DanS
Glen your inventiveness surprises impresses me  :bowdown:
DanS
KDXSR5
this is such an awesome idea. you must do it!
skipnrocks
Does your back axle receve power from the tcase or from  a d-shaft from the front diff?
WILLYNILLY
Quote from: skipnrocks on November 28, 2007, 07:44:23 PM
it would recieve power from a  tcase mounted  possibley TO  the middle axle
unclejpl4x4
glen why not do what the trailers have   2 sets of leaves 1 side and a triangle link bar ?
4inchToyotas
Quote from: unclejpl4x4 on November 28, 2007, 07:47:46 PM
that's what I was thinking.
skipnrocks
Quote from: 79coyotefrg on November 28, 2007, 07:29:29 PM
WHat are the green lines? lower links maybe...  That would be pretty cool, if you run something like that what size tires would you run?
WILLYNILLY
with this set up   when  say i turn  a left turn  the  truck will naturally  lean to the right ,   this compresses  the spring on the right of the truck making it longer in effect  pushing the pass side  rear tires away from each other forcing the rear of the truck  to actually steer itself  reduceing  scrub
this  is  how MACK  has  done  for 60 years
Quote from: skipnrocks on November 28, 2007, 07:51:24 PM
they are  lower links,  which i would probably NOT use
it would be  built to clear 35's  but  probably run 33's
Duffil
damn Glen if you did that autocad, then you are floppin' killing it!!
Nobody really needs a 6x6, BTW, except the military.
sorry to be a killjoy.
skipnrocks
Quote from: Duffil on November 28, 2007, 07:59:30 PM
damn Glen if you did that autocad, then you are floppin killing it!!
:blah:  :blah: :blah:  Dont listen LOL.....  Yea so I agree but it would still be kinda cool, but I dont know if it would be worth it..
WILLYNILLY
Gittinit
Quote from: 79coyotefrg on November 28, 2007, 07:57:22 PM
You would have to have the links to controll the axles. The 63 wouldn't work in this configuration either unless you mounted the spring eyes off from rhe axle centerline.
I'd say you were being realistic.  As cool as this idea is, it still means 2 extra tires to buy and alot more weak links, bugs, and it would still be less capable (imho) in an environmet involving anything but mud. How much power would this setup rob from the 4cyl.
my favorite places:
Quote from: Gittinit on November 29, 2007, 06:26:23 AM
all in how you gear it :]
Cheesemaker
Whether or not he does it, it's still fun to talk about how would it work, and how to make it work!  Am I right?  :dunno:  We all know that Glen's first priority is to get the truck running, and after that, it's all up to him.
No matter what, I'd love to drive a 6x6 toy around.  Just see the looks on peoples faces.
Quote from: cheesemaker on November 29, 2007, 01:11:56 PM
I second that
Gittinit
:yesnod:
my favorite places:
been to  sick  to do much  of anything this week  :thud:
iNfErNaL
WWW.GLOBALOFFROADSUPPLY.COM
Support Your Local Brawlers
www.RockBrawlers.com
www.offroadtruckshow.com
