project 4skinner
Started by peacesells, January 07, 2009, 05:58:57 PM
peacesells
Well winter is on the way and I really want to get out and do some campin, so im knockin out everything I need done on the 4skinner. list includes
front axle shaved/trussed/gusseted/diff armor
Marfields installed
v6 calipers/vented rotors/1in m/c/extended brakelines/backing plate eliminators
12in bilsteins up front
new spring bushings
steering stabilizer
stiffen up frame, new front spring hanger
new knuckle bearings and wheel bearings on all 4 corners
Marlin seals on all 4 wheels
wire up the rear locker
winch
sliders
pull tcases and reseal/cut shift rod
Lots of work, but I hope to have it done in 2 weeks or so. progress so far
this my man lysol, fresh out the joint
pumkin toy
nice!  i like seeing new parts all lined up!
97 4runner Limited
peacesells
I got some work done this morning. Took the axle apart, cut off all unneccisary brackets, cleaned up the housing and welded on the top truss, lower knuckle gussets, diff armor, and boxed the steering stops. I sprayed it black, then put my new spring bushings in while it dried. I may end up pulling the hp arb third out of my crawler to put in the 4skinner as I am going to 60's and links. I may even end up runnin the 30 spline longs in this rig too... Too many projects... Too many descisions... No money...
peacesells
Quote from: pumkin toy on October 22, 2009, 04:41:37 PM
Me too, gotta get some pictures while everything still looks good! The new rear housing has been in there for about a month and it already looks like assss...
DieselD
ah so thats where that housing went. those guys are friends of mine. good dudes.
46&2
Nice.. you are starting to motivate me to put my junk back together  :beerchug:
pumkin toy
97 4runner Limited
peacesells
Quote from: DieselD on October 24, 2009, 11:25:46 AM
Yep, its been workin good too! yeah they are, I wheeled with joe a few times(the only time he didnt roll on cd) and joe 87pickup when he broke his output on annihilator. Its gonna suck havin my crawler apart for this season.. I like how your cage turned out, how long before you get rid of the rest of the sheet metal and go full tube? haha
Quote from: fortysixandtwo on October 24, 2009, 01:51:09 PM
Put it together man, snow is about to hit!!
Quote from: pumkin toy on October 24, 2009, 05:32:31 PM
housing looks great!
Thanks man!
peacesells
I finished the front end and got it back in today. 30 spline longfields, hi pinion 5.29 arb 3rd, arp steering studs, new knuckle and wheel bearings, seals, vented rotors, v6 calipers, and extended brakelines. I picked up a v6 booster and master im going to install when I replace the rear axle bearings.
46&2
Nice! Thats what I need to do to my front axle. Well the longfields and HP ARB that is.
89sastoyo
always raggin on trail-queer. My dirty thirtys do work I got a screamin deal on them or id have longs but they haven't broke yet
89 extra cab stock on 1 tons.
92 2wd DD
first gen cab
Check out the build.
peacesells
Ive had no problem with tg parts, ever. I know most of the marlin crowd does not like them, but the hard parts have held up really well. I wont use any of their gears or adapters, but the bumpers, skidplate, diff armor, and other misc parts have been good to me.
My buddy's truck has lots of tg parts, f/r lift, tcase 4.7's, 5.29's, and has never had a problem. His truck has done some of the hardest trails here in az and is a daily driver on 37's
pumkin toy
nice lookin truck!  yeah i have been trying to figure out why everyone hates trail gear so much. i ordered a couple parts from them that marlin doesnt offer and i got them quickly and have never had a problem with them.  I really want to build some thirds using there new high pinion third housings
97 4runner Limited
peacesells
Im pretty sure theyre hp housings are from toyota, either way check your local pull a part, I just picked up a 4.11 hp 3rd last week for $40 ready to roll, lots of 80 series are in due to the cash for clunkers program. If you need some parts or it you are lookin and cant find anything hit me up man!
pumkin toy
Quote from: peacesells63 on November 12, 2009, 07:10:57 PM
dude you got a high pinion third for 40 bucks?  we dont have "pull a part" or "pick n pull" places here.  Just regular  junk yards and if you could ever find a high pinion third here they would want a crap load for it!  So how how much can you get me two HP thirds for? :eyebrow:
97 4runner Limited
LilChief87
looking good man killer my rigs almost done finally so if your still willin to hit up some trails when its done ill let you know
peacesells
I just spent 3 hours in police custody. My chevy is totaled, apparently it did alot of damage... Nobody was hurt.. broken tie rod, 2 taco'd wheels, 2 pass side flats. 4wd works, apparently my truck was hi centerd on a 3ft wall at around 60? mph by a friend I had drive home from the bar because I was too drunk to drive. 100 some odd feet from the crash site was my truck, about 2 miles away i was found, face to muzzle with a 45, after getting pregnant dog slammed, handcuffed, then pregnant dog slammed due to the knife I mentioned I always have with me, then I was hog tied in the back of a cruiser. Taken back to the crash site, my buddy (passenger) was beaten on, hog tied, same treatment and then some. After an hour or so the officer I was arrested by let my cuffs loose and was pretty cool. We both were released (no BAC test, no questioning) a few hours later, after witnesses said it wasnt either of us driving... mother fucks... I shaved my head 3 hours before all of this :pokinit: happend (had long hair for 10+ years) im sure that didnt help anything. As soon as I mentioned I was an EMT student they treated me like gold and basically let me off of the hook. My friend and myself are listed as leads in a case that has nothing to do with either of us. Good times
LilChief87
holy hell man damnsounds like a interesting  time you guys had yeah i almostwent to jail the other night too man cops been gettin people for anything and everything lately
46&2
I never understood why cops felt the need to be rough with people who have just gotten in an accident, regardless if the driver was intoxicated or not. And leaving the scene of an accident, flopp that, when you get in a gnarly wreck your head is not in the right place, especially since this accident sounds like it was pretty brutal. I had a friend that was a passenger in a wreck where they were going 30 mph and got tboned by a car going 60 mph and everyone in the car going 30 was in such wicked shock they had all just wandered off but were still in the vicinity. Police beat the hell out of them, and both my friend who was driving and the passenger both had broken necks/backs BEFORE the cops beat them down. freakin' bull crap. Glad no one was hurt. What happened to your friend that was driving?
LilChief87
trust me man i know alot cops now are complete trigger happy baton beaten bastards now a days but there still a few that are pretty cool but yeah back to topic lol :beerchug:
Wow........ id turn them bitches in for that harrasment. jesus christ.
peacesells
My buddy is trying to get those 2 :moon: cops in trouble. he got beaten pretty bad, road rash on his face and the outline of a boot on the back of his head. From looking at my truck there was no impact, but a lot of belly damage, definately didnt get his injuries from that. no air bags went off either. Im one step closer to gettin a cummins though  :pirate:
pumkin toy
Quote from: peacesells63 on November 14, 2009, 05:26:01 PM
damn! yeah dude i would deffinately try to get those cops in some :pokinit: for that!  I posted some new pics of my runner with the 37s!
97 4runner Limited
peacesells
Quote from: pumkin toy on November 14, 2009, 05:32:47 PM
You runner looks awesome man, cane wait to see that thing linked!!
peacesells
I made a bit of progress this weekend. Not much, but shes gettin there... I pulled the rear end back apart for wheel bearing/seals and had Zuk install the yukon 5.29's and a master kit in my elocker 3rd this weekend, beautiful job! I will post some pictures when I figure out how to resize them. I installed the newer v6 4runner brake booster and master, you can tell its going to stop better just by lookin at it!! I have a clinical at the hospitol all day tomorrow, and work and school the next, then insurance garbage to deal with wed. I probably wont get everything buttoned up until next weekend.
TacoRunner
Page 71 of the latest 4WDToyota Owner Mag.
Top right of the page is a press release from TG. Stating that their HP housings are their own and not Toyota's. Personally anything that requires precision grinding.
All Toyota housings are rifle drilled at the bearings. If TG doesn't do that, you are asking for trouble. I have no idea if they do. But it may be something you want to ask before you buy.
www.4WHEELUNDERGROUND.com
[email protected]
pumkin toy
Quote from: peacesells63 on November 15, 2009, 07:44:00 PM
dude you will love the bigger brake booster! it makes your brakes like ten times better.
Quote from: TacoRunner on November 15, 2009, 09:26:42 PM
yeah i saw that on TG's website that they make them themselves. what exactly is rifle drilling?
97 4runner Limited
peacesells
I can wait to try em out! The runner is gonna a fun ride with both lockers, 5.29's, and shocks that are worth a :pokinit:.
I just checked those tg housings out, I wonder how many of those they sell? its not too hard to find a complete stock hp 3rd for around the same price as the housing kit they have.
By the way pumkin let me know when youre ready for a HP, Ill hook you up. My buddy is buyin this one from me, but there is another 80 at the yard im waiting for them to put out. Its a 94 too, may be an elocker  :crossed:
LilChief87
hows the runner coming man?
