85 4runner and the work never ends....
Started by John Doe, June 15, 2008, 03:54:11 AM
John Doe
Quote from: THK Matt on January 22, 2013, 08:39:12 PM
swap dashes? :D ive always liked the newer 4runner and tacoma dashes.
I do not have the dash from the Tacoma, just the wiring that went in it and the engine and transmission that powered it.
I had a long day today but my new bumper is finialy mounted.
I need to touch up some paint, install my winch and a few other things. I will get a few better shots later, time for bed.
Jordan7118
How are you liking the 80-series front compared to the mini-truck front end? I'm pondering a switch since I picked up a FF 80-series rear.
John Doe
I love it. I would never do another mini truck front.
was it if difficult to mount it with leafs? how'd you go about making perches?
what did the steering cost you.
John Doe
It takes some time to get the leafs set up. I got my perches from Ruffstuff. Had to make them fit the housing. I do not remember how much the kuckles cost me, contact Billybob and hell get you a quote.
kdub0013
The bumper looks good mounted. Nice to see it not kicking around the shop floor anymore.
86yoter
86' runner nothing special
John Doe
Well I may be going with the 3.4 sooner then I had thought...... I have been having serious issues with my cooling system lately. 1st thought was possibly a large air bubble somewhere in the block that still needed to be burped out. Apx 2 weeks ago I replaced the Radiator, cap, and t-stat (non OEM) and I have been over heating nearly every day. Each time I catch it quick before the radiator over flow spews coolant everywhere. Pull over then release pressure in the system. Before I release the pressure the upper radiator hose is solid as a rock telling me there is a blockage of some kind some where. I do not believe I am loosing much coolant, but I do smell the rich/ sweet exhaust telling me that some is getting into the exhaust system. could this be another blown/ cracked head gasket just 1 year after my last?  :mad:
Thoughts on the 3.4 swap, Will a 21 spline stock gear driven t-case be sufficient or will 23 spline in puts, and upgraded 30 spline outputs be worth it? I have the stock tacoma auto transmission and I do not wheel with a heavy foot.
Quote from: John Doe on January 27, 2013, 02:12:53 PM
run an auto trans man with a manual valve body and torq conv lock up kit. and run 23 spl all the way out.
John Doe
Anyone know if the tacoma auto transmission requires a 23 spline input for the t-case?
the 3.0 and 3.4L both use 23 spl t cases. so id say yes?
http://www.marlincrawler.com/transfer-case/line-ups/transmission-to-transfer-case-adapters
Quote1995-2004 5VZ-FE 3.4-liter V6 drivetrains
This adapter kit allows you to bolt the Toyota RF1A Gear Drive Transfer case behind your Tacoma/4Runner/T100 5-speed or automatic transmission.
We have designed our kit using a 23-spline coupler for ultimate strength. Therefore, a 23-spline gear drive transfer case or Crawl Box input will be required.
John Doe
Thanks. Well that means I have 1 23 spline case already, now I will need to get a 23 spline adapter and a crawl box.
redrocket93
That sucks about your motor issues. I'd throw that pos threw the window of the builders place. It's really not that hard to build a decent 22re. On a brighter note, that 3.4 is gonna be really nice.
Quote from: John Doe on January 30, 2013, 07:28:36 PM
welcome. :beerchug:
Jordan7118
Quote from: John Doe on January 24, 2013, 10:36:18 PM
Are you running the same spring perch width as a stock mini-truck front axle? In other words, did you modify the front spring hanger and run the goofy shackles to go to a wider spring perch location?
Sorry to hear that about your motor. That is so frustrating :(
John Doe
Quote from: Jordan7118 on January 30, 2013, 09:57:34 PM
I am running a wider 31" spring hanger, that is why I moved the shackles.
I have been looking into the 3.4 swap and it should be pretty easy with everything that I have.
Going to see what is up for sure with my engine on Friday.
John Doe
Anyone have any guesses for what I am going to use this for?
kdub0013
OOPS
Work that never ends; you got that right. I did my SAS in 99 and have been working on it ever since.
Bought a RuffStuff housing to replace the bent front stock housing (fourth one since 99). As I am working on it I discover both my shock mounts a cracked. I built these shock hoops in 99 so I could make a run to the hammers; they were supposed to be temporary. As I am cutting them off with my Plasma cutter, the cutter takes a dump on me so I have to take it and get it repaired. Get it back today and it works great. Cutting off the hoops today I discover the frame is cracking behind the motor mount. Now I have to make some plates for the frame!!!
Never ending work, you bet!!!!
Jordan7118
Quote from: OOPS on February 08, 2013, 03:55:17 PM
Hoooooooooooooooooooooooooooooooooooooooooolllllllllllllllllllllllllllllllllllllllllly craaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaapppppppppppppppppppppppppp!!!
John Doe
Cheesemaker
This sounds like Bigmikes build up.   :yupyup:
I've been trying to get my truck built up for years.  But all I seem to do is get parts one at a time, very slowly.  Our sport isn't never ending on fixes, its expensive too!!
86yoter
i am finding this out i had a highway patrol tell me the other day while pulling me over for mud flaps . he said " you know there is a time when enough is enough"and i said no there is always something to cut of and re-due.
1985CRAWLER
86yoter, aint that the truth about mud flaps ahah oh also with the re due part too.chp will always be wathching.
Talon84x4
Looking good John, always a few steps ahead of me haha.
Central Valley Crawlers
kdub0013
Well I saw the rig sitting at GSM the other day, what's up? Any progress gonna be made on this thing or what?
John Doe
Quote from: kdub0013 on February 14, 2013, 07:19:45 AM
I have a 2nd blown head gasket in 11 months on my Davez offroad engine. I have sent an email to Dave with no response. I am ditching the 22re all together. It is obvious that Dave does not stand behind his product.
I got the truck towed home yesterday and I'll be doing some welding on the cage, and those plates tomorrow, then dive back to the shop to finish the cage and pull this engine.
86yoter
hey bud that sucks i hate head gaskets. i had one changed and not even six months went by that one was blown. but i have been riding with this one for about 3 1/2 years or more... i am starting to get nervous  about it happening again. :sick: :attention:
