my 1st gen...1980 longbed
Started by TheCookieMonster, December 15, 2007, 12:32:12 AM
TIMS89CRAWLER
ya you will always see  :boobs: at the lake when ya have one of these!!!
and we saw some good burnouts at the lake thanks to this too
www.choptechfab.com
www.myspace.com/choptechfab
CHECK THE BUILD
TheCookieMonster
 :yesnod: :beerchug:....did you get a pic of the road sunday :yupyup:
TIMS89CRAWLER
sure did all my burneys from the neon... reverse at 20mph str8 to 1st in the rev limiter
www.choptechfab.com
CHECK THE BUILD
toyotanner
TheCookieMonster
Quote from: toyotanner on May 19, 2008, 05:12:17 PM
you need some bigger tires :yupyup:
:yesnod:...i need 40s
more progress on the crossmember :suprised:....all cut, drilled and ready
tacked together
getting closer
Jud
"bout tree fiddy"
TheCookieMonster
Quote from: Jud on May 22, 2008, 09:59:37 AM
looks good.
thanks....it will look a lot better once its in the truck and i have a flatbelly :yupyup:
95SAS
nice xmember. i need to build me one.
1986 extracab, SAS 38.5's Locked Duals, truggyfied, beadlocks
1988 2wd bagged and body dropped 3'' with a healthy 22r....
my build
http://board.marlincrawler.com/index.php?topic=35602.0
TheCookieMonster
well i finially got motivated any started my flatbelly :woohoo:
some pics before i started  :flamer: old crossmember
floor before the grinder came into play
old crossmember out finially :thumbs:
the new one i built installed :o
chipped the rubber crap off the floor and drew  a line to follow while cutting
and then
as you can see the front of my tranny was already resting on the floor in the stock position...this happened when i swapped in the 5 speed a while back
so more  :flamer: was needed
then i jacked everything up and found this
so
some more lifting and wala :yupyup:
FLATBELLY :yikes: :yesnod:
still need to cut the back section of the tunnel to be able to get a driveline to that flange :ack:
then i got the crossmember all burned together :eyebrow:
more to come tommorrow :beerchug: stay tuned :moon:
toyotanner
sweet man everything looks sweet how's the exhaust looking like its gonna turn out?
TheCookieMonster
Quote from: toyotanner on May 25, 2008, 12:41:59 AM
its gonna be pretty tight....ill probably take it to the exhaust shop and have someone run a whole new piece to the back. there isnt very much room between the new crossmember and the floor. ill figure somethin out. hopefully i can get it all in there today. we'll see :beerchug:
toyotanner
yeah when i do my flatbelly i was like yeah im gonna take it to an exhaust shop but then i would have to put a cat on my truck and they are $$$
TheCookieMonster
i dont need a cat here :thumbs:...they'll put exhaust on without it. i got more progress today im just too tired to upload pics....after drilling 16 1" holes through the frame my arms feel like rubber :thud:...ill post up tmr
TheCookieMonster
so here is some more for ya
tabs cut out and sleeves for frame cut
test fitting to get tabs in the right spot :thumbs:
tacked on
all welded :D
back in once again
marking spots for the holes
inside holes drilled...what a pita that was
had to lift the cab up to drill the outside holes....wasnt as bad as the inside holes...crunched my rain gutters with the tow strap :slap:
and finially..sleeves are welded
installed again...just need to get some bolts for the frame
i need to move my fuel pump back a lil ways
heres what i got for exhaust room....right around 3" in the tight spot
front shot
motor sits just right
a little close to the fan
need to cut this down
so thats what i got done for the weekend. next is all the sheet metal work
:eyebrow:
Tallchevy
87 4Runner redo
TheCookieMonster
Quote from: Tallchevy on May 27, 2008, 01:31:55 PM
That's look'n sweet  :thumbs:
thanks man :beerchug:...hopefully ill get some more done tonite. i got all my hardware at lunch to bolt the crossmember to the frame. ill get that on after work and hopefully get the rear driveline back in :crossed:
toyotanner
stop with the progress your making me look bad :shhh:
Jud
"bout tree fiddy"
Gittinit
Nice and beefy. I just wish I could see all the pics. Its prolly just my crappy old puter though.
my favorite places:
http://www.flatnasty.net/
http://www.orvpark.com/
TheCookieMonster
Quote from: toyotanner on May 27, 2008, 05:50:48 PM
:rofl2:
thanks for the good words fellas :beerchug:
Quote from: Gittinit on May 27, 2008, 08:04:22 PM
are my pics not showin up :headscratch:...can everyone else see them :dunno:
oh yea i got some more done tonite also....havent got any pics yet tho
Jud
I can see them all they just tale a while to load.
"bout tree fiddy"
TIMS89CRAWLER
pics work fine for me but my crappy computer at work takes forever to load them up!
www.choptechfab.com
CHECK THE BUILD
TheCookieMonster
ya its probably because there are about 70 pics on that page :smack:
toyotanner
well if you need a new bed let me know.... i got a blue long bed that i bought for 100 bucks  i comp cut it and decided to go another route
TheCookieMonster
what kind of shape is it in???? does it have a tailgate??? i may be interested because my bed is pretty hammered
toyotanner
it does have a tailgate... its actually in pretty good condition. if you were to bob it it would be a damn near perfect bed because it has little surface rust spots but its on the back half.
TIMS89CRAWLER
 :yupyup: he needs it for sure! this one is pretty hammered on..
www.choptechfab.com
CHECK THE BUILD
TheCookieMonster
Quote from: toyotanner on May 29, 2008, 09:58:40 AM
sweet man :thumbs:...how much you want for it? i would bob it for sure. that would be sweet to have a tailgate so my crap dont fly out the back as eazy :yupyup: ...let me know ill take it
toyotanner
100 bucks would be nice just what i paid for it. i comp cut it clean too. no sawzall crooked line haha
