my 1st gen...1980 longbed
Started by TheCookieMonster, December 15, 2007, 12:32:12 AM
TIMS89CRAWLER
www.choptechfab.com
www.myspace.com/choptechfab
CHECK THE BUILD
TheCookieMonster
some more pics of whats been happenin :biggthumpup:
this is the tube i used to put my driveline back together. there is about a 3 inch piece of it inside the driveline where welded it back together. i did this so there is more metal to weld to and to keep the d-line straight while welding. my step dad machined it for me so it slid right inside and was snug.
this is the sheet metal i picked up for 10 smackers :yesnod:
so i had to cut a little more out of the front of the tunnel because it was still hitting the top of my trans.
got some primer on it
did some more trimming to get the floor straight
got one of the sides of the tunnel tacked in
other side still needs a little trimming before it goes in
thats what got done last night hopefully some more tonite :thumbs:
ajordan1975
looking good.  :thumbs:  can't wait to do mine
TheCookieMonster
Quote from: ajordan1975 on June 04, 2008, 12:00:49 PM
thanks :D...its definetly worth the time and effort. i cant wait til its all buttoned up :eyebrow:
I.D.G.A.F
did you loosen the motor/mounts when you jacked the d line up in the tunnel?
TheCookieMonster
Quote from: I.D.G.A.F on June 04, 2008, 02:02:38 PM
i loosened the bolts that go into the block on the motor mounts. the rubber pieces on the mounts bearly moved at all when i jacked it up in there. retightened them when everything was in place. should work fine :thumbs:
toyotanner
got a pic of that bed for you... no dents just little outies.
TIMS89CRAWLER
Quote from: toyotanner on June 04, 2008, 08:25:54 PM
2wd bed??
www.choptechfab.com
CHECK THE BUILD
TheCookieMonster
more tunnel progress  :o
need to get this covered still
ill try and tackle this back section tomorrow
i want to make a removeable top for this for eazy access to shifters etc...so thats why there is nothin on top yet :thumbs:
toyotanner
toyotanner
TIMS89CRAWLER
Quote from: toyotanner on June 05, 2008, 09:36:57 PM
the only difference is the flares and he has those :thumbs:
ya I know man I was just asking cause I thought it looked 2wd....looks pretty good though....
www.choptechfab.com
CHECK THE BUILD
TheCookieMonster
Quote from: toyotanner on June 05, 2008, 09:39:33 PM
Tunnel is looking good man  :biggthumpup:
thanks :thumbs:...it takes a lot of time. i want to be done with it already :hammerhead:
toyotanner
looking good. your making the top removable right? any ideas on how your gonna do that yet?
i'd probably put a little rubber liner across that top ridge so that the removable top of it doesnt rattle :twocents:
TheCookieMonster
Quote from: toyotanner on June 09, 2008, 05:24:18 PM
ya thats what i was thinking. like weather stripping or somethin along those lines. ill probably weld some flatbar to the inside of the tunnel then screw the top to that. i want it to be simple :yesnod:.
ajordan1975
TheCookieMonster
thanks guys :thumbs:..got it all finished up last night besides the top (i need more metal). i really like how it turned out. ill tell ya welding to a rusty floor is not to fun :shake: and the rubber coating on the undercarrage likes to catch on fire a lot :yesnod:..ill post pics in a few
TheCookieMonster
all welded up
fixed passenger side seat mount
all primered
seam sealed
im gonna paint it tonite and get the heater and stuff back in there. still need to figure out a temp fix for the exhaust too
TheCookieMonster
 :eyebrow:
started on an aluminum dash panel
fixed my floppy battery tray. gave it some fresh paint too :thumbs:
toyotanner
nice job man turned out nice and clean.
TheCookieMonster
thanks :thumbs:..i still got a few more things to do before she is ready to wheel. need to get some shifter boots, reciever tubing for front driveline, fix steering box mount , im sure there is more...im getting close :woohoo:
TIMS89CRAWLER
www.choptechfab.com
CHECK THE BUILD
TheCookieMonster
got a full exhaust put on my junk today by the local exhaust shop :biggthumpup:....ill get some pics later on :beerchug:
TheCookieMonster
here is the driveline i picked up at pick-a-part for $25....it measures 26 1/2" flange to flange collapsed right now. my truck is about 31" from flange to flange for the front d-line. i may just extend this one a couple inches or cut the ends off and make a square one. havent decided yet :headscratch:...not sure what this driveline came out of...maybe an IFS truck :dunno:
TheCookieMonster
got 2" exhaust ran :thumbs:
FLATNESS :eyebrow:
it came out great...everything is above the framerails so im satisfied. :biggthumpup:
my new manual fuel pump. ive went through 2 electric pumps already so im done with those pieces of :pokinit:
my electric fan also took a crap on me  :shake:. so im gonna go back to the clutch fan for reliability
Blingn
TheCookieMonster
Quote from: BLINGN on June 27, 2008, 03:40:00 PM
looks great man
thanks..got the manual fuel pump on. for some reason its runnin a lot better now. i guess thats a good thing :thumbs:
..just workin on little things now. changing tranny fluid, change u joints in rear d-line, extend front d-line
