my 1st gen...1980 longbed
Started by TheCookieMonster, December 15, 2007, 12:32:12 AM
TheCookieMonster
forgot to mention the 20r has been recently rebuilt by me. it has probably 200-300 mile on it. striped it all down, had it bored 20 over, new pistons, all new bearings, reconditioned the rods, reground the crank and cam (redline cranks and cams), i reground the valves and the hole head when i was in school, pretty much everything got redone. runs like a champ besides my weber :thumbdown:...its alright :therethere:
the rest of the pics :thumbs:
rear end..
dash
seats out of something but a yota :dunno:
steering box mount that Still needs put on
front end
front driveline that needs cut apart
front and rear...the rear is cut to lenght for the duals right now. im just waiting on a piece of metal to slide inside the shafts to weld it back together. my step dad is making a piece that fits perfectly inside to slide the 2 pieces back together. this wont be a permenant fix. but it will work for now :eyebrow:
TheCookieMonster
almost forgot the custom e brake :slap:
let me know if you want one :yupyup: :beerchug:
94MtnYote
 cool truck!
Taking orders on custom woodgrain e-brakes?
Marlin 1200LB clutch
TheCookieMonster
Quote from: toyoduh! on March 28, 2008, 04:48:27 PM
cool truck!
thanks :thumbs:...im sure you can get one of those e brakes anywhere (neighbors tree) :smack:
94MtnYote
 Oh duh! bout time I fired up the chainsaw   :yupyup:
jrock
Looks real good. Keep it coming. More pics.
toyotanner
YEAH!!! whens it gonna be done?
82rustbeast
quick question  :confused: What kind of GM vehicle did the distributor come from, did you have to modify any of the electrical to get it to work? Do you know the output on it?
sigman
Why won't the DMV recognize mud as a color?
Silly Jeepers, Jeeps are for mailmen!
TIMS89CRAWLER
Quote from: 82rustbeast on March 30, 2008, 08:48:35 PM
the gm ignitor is just a standard 4 wire GM HEI ignitor.... any parts store knows what they are... the 2 wires coming from the distributor go to the side with a G & W and the other 2 connectors get 12v. & GND.... they are labeled as well.... these ignitors are much more dependable than the stock toyota unit.... :yupyup:
www.choptechfab.com
www.myspace.com/choptechfab
CHECK THE BUILD
toyotanner
judging by your floorboard you didnt go with the flatbelly?
TIMS89CRAWLER
no he is talking about the distributor ignitor mounted to the inside fender well... you can use these rather than the stock piece of :pokinit: toyota ignitor which are always having problems....:yupyup:
www.choptechfab.com
CHECK THE BUILD
TheCookieMonster
Quote from: toyotanner on March 31, 2008, 08:11:06 AM
im still planning on flatbelly'in it. i just need to get a crossmember to be able to do it. once i get the crossmember ill  :flamer: the floor out however much i need. im still tryin to figure out which crossmember to go with. i just put the cases in with the stock one for now. also i comp cut the bed this weekend too :eyebrow:
TheCookieMonster
Quote from: toyotanner on March 30, 2008, 01:38:37 AM
haha...well its getting closer but no where close to done :hammerhead:
1. get rears up front and 63" chevys in the rear
2.make new front spring hanger, rear spring hangers
3. get shackels front and rear
3. figure out which t case crossmember to use then put it in
4. make new rear crossmember to mount rear shackels
5. weld front diff./ rebuild front end
6.mount new MC steering box mount farther forward than it is
7.get drivelines welded up :flamer:
8. new tires and wheels w/ DIY beadlocks
9. get wider rearend put in
thats just a start. im sure there is more :_order:
toyotanner
lol please dont weld up the front diff. my friend absolutely hates it. sure it works but good look steering. i have a lock right in the front and it works great and you can steer lol
which crossmember you trying to go with i thought you were set on the FROR one?
TheCookieMonster
i might wait and get a locker but i just dont have the money...we'll see what happens :smack:..as for the crossmember i got a cardboard template of the part that bolts to the back of the t case. im gonna do somethin like 4rnRick did on the Tuki (page 4 of his build). im just waiting on some metal to  :flamer: . then ill need to get some leaf spring bushings to mount it to the crossbar.
toyotanner
TheCookieMonster
ill get some more pics up soon :eyebrow:
TheCookieMonster
 :smack:..its been a while so here is whats been happenin.....
got a new wider rearend from a buddy for $150...also comp cut the rear of the bed :eyebrow:
also got some wheel spacers for the front....i hated the stock stance. not so tipsy anymore :thumbs:
before:
after:
painted my hubs
TheCookieMonster
ive also been making progress on the flatbelly crossmember and have been fabbin up some spring hangers for the new  :turtle: springs that will be comin soon
front spring hanger:
done: :yesnod:
TheCookieMonster
heres the progress of the crossmember :yupyup:
right after cutting with cutting torch. by the way that 1/2" plate
all cleaned up with tubes and gussets welded on :wink2:
here is what that will bolt too. 2x4x1/4
toyotanner
i think we need some side shots of the comp cut
TheCookieMonster
ya ill get some...it looks a lot better from the side . my rearend was so f ' ed up before it now looks like crap from the rear :eek:...it will be much better with lots of tube and some real tires :driving:
toyotanner
i think it would look fine if it wasnt so damn tall lol..... or maybe some bigger tires
TheCookieMonster
its not tall. it just looks like that from the rear. ill get a pic in a lil bit. im ordering the marlin 5 inch springs next week along with new shackels and a speedo extension :thumbs:.im gonna finish the crossmember this week and get it in next weekend. then well see how much more  :flamer: needs done for the flatbelly!!!
toyotanner
nice! i remember going from my 4 to 5 speed and its longer so the speedo hole was back farther lets just say it BARELY made it lol dual cases now thats a limit i dont think i can stretch
TheCookieMonster
Quote from: toyotanner on May 12, 2008, 04:50:25 PM
ya same here. i just notice my brother took the camera to seattle to i wont have anymore pics til later this week. ill have more progress this weekend so stay tuned :cool:
TIMS89CRAWLER
 :yupyup: he sure does!!! hahaha
www.choptechfab.com
CHECK THE BUILD
TheCookieMonster
#118
so no more progress this weekend :shake:. i had to go camping because it was so hot out. did a lot of :drunk: :boozer:...and saw some :boobs:..   but i got some more pics :thumbs:
so heres some more of the comp cut...doors had to come off for air conditioning :yupyup:
TheCookieMonster
i also put in this piece of 2x3 and capped off the rear of the frame when i had the bed off...i had to get rid of the stock piece of junk crossmember in the rear
i also put some 1 in. tube in the corners for extra support and they'll work great for rocklight mounts when i get some :eyebrow:
