the wookie mobile build-up
Started by baldwookie, October 11, 2007, 12:42:34 AM
goes to a metal tube, then to a P shaped hose that goes into the bottom of the intake manifold
Quote from: baldwookie on April 18, 2009, 05:06:09 PM
cool bro.. only thing i dont know now is the one off the backside of the water pump(passengerside)... where it goes or block it off.... ty...
hey joe ...ummm.. nvm..i dont blow :p
thats the one the metal tube attaches to
the block off needs to be on the drivers side behind the water pump
JOSH :hyper:  yea Josh has a 20R  :woohoo:
Josh he needs pics
baldwookie
yeah josh plz  :bowdown:..Need!! pics.....bout got this figured out... so i can bolt it in the truck... i wanna  :driving:
1980 lwb sr5  stock
Gittinit
I can get you some pics of my 86 toy with a 20r in it tomarrow if I rember. I did away with the 20r carb though so my heater hoses may be slightly different, or are you gonna run a webber too?
my favorite places:
http://www.flatnasty.net/
http://www.orvpark.com/
baldwookie
yeah thnx gittinit,  im puttin a weber on also..ty
1980 lwb sr5  stock
KYOTA
well at least you've got a nice clean environment to build an engine in  :ack: :crossed:
Gittinit
my favorite places:
YotaJosh
Quote from: 79coyotefrg on April 18, 2009, 06:59:19 PM
Josh he needs pics
Quote from: baldwookie on April 18, 2009, 09:14:29 PM
I'll get some in the morning.  :thumbs:
'79 Short Bed Pickup 4x4
'04 4Runner V8 Sport 4x2
YotaJosh
Ok, lets see if these help you.
1. Right below carb and intake. Hose on left goes to heater core valve on firewall and comes from metal pipe that bolts to head between intake and head. Hose on right goes from metal tube that comes from back of timing cover, and goes to water port on stock carb. Small black hose with red wire ziptied to it is the vacuum hose for the brake booster.
2. Looking down from top of carb. Hose on bottom comes from metal tube that's connected to back of timing cover. Hose on top goes to large port on manifold.
3. Overall view of things.
If you want to ditch the stock water choke carb, you can probably replace the straight nipple on the top of the manifold with a 90 degree elbow, and route the hose from the back of the timing cover to the new 90* nipple.
:teeth:
QuoteIf you want to ditch the stock water choke carb, you can probably replace the straight nipple on the top of the manifold with a 90 degree elbow, and route the hose from the back of the timing cover to the new 90* nipple.
:thumbs:   now i remember :wall:
i remember now  i used a 2 inch long piece of rubber hose, into a 90 elbow into the hose to the pipe bolted to the back of the timing cover
removing that nipple and installing a threaded 90  would be best
baldwookie
ok ty guys i think that covers it....  the metal pipe on the back of passenger side water pump is smaller diameter than hoses... ill have to step it down so it'll work.... ty again.......at least now i can move forward
1980 lwb sr5  stock
Kevin if you need me i can try and make it up there sometime soon just gotta get my doctors figured out
:bat:  what do we gotta do to get updates here :bat:
:worthless:
baldwookie
#136
needs nekid wemens...to crack a :whip: at me.....nah getting close....waitin on the block off plates to get here then in she goes.......ill try to upload pics later ....    takes forevr....all ready ecept for air injector blockoff plates and o2 sensor blockoff plate
1980 lwb sr5  stock
unclejpl4x4
i would love to biuld a 22re with no egr, pair valve and crap  it would probably run right
baldwookie
yay its finally in.. an i got tired enough to try an upload some photos (dial-up)   uggg...too lazy to go to the library...err too much hassle to bum a ride
still not running yet...drivers side motor mount too bent to bolt up knew it was bent just not that bad :(
and had to reswap throttle linakge from old 22r, throttle cable end wouldnt fit.
took 90 elbow off intake an just went in like normal...kept interfering with linkage
so tomo ill finish hooking up alt,battery, radiator....
got tired, couldnt hold up rad an but bolts in...:(
:crossed: see what happens tomo....
1980 lwb sr5  stock
ninja turtle
 :clap2: right on kevin! getting closer.
unclejpl4x4
thats it slide her in nice n easy  a little more a little more   perfect
baldwookie
well it turns over !!!!!  after chasing leaks at every hose...bum battery...... was about to try to start it..... in all the excitement forgot an important ingredient....go-go juice :(((    had a vol fire meeting to go to an 4 ballgames so no vehicle to go grab any...uggg       also the throttle linkage doesnt want to spring back....linkage doesnt have a spot for a return spring....   read somewhere i can loosen up the nut that holds thr bracket on.....  hoping that fixs that.....we shall see
1980 lwb sr5  stock
baldwookie
#144
WOOHOOO!!!!!!!!   IT RUNS!!!!!!!!!!!!!!!!!!!!!!                    video on the way... as soon as i figure out how to change 3gp file to mpeg ...  still have a problem with the throttle linkage... doesnt want to spring back :clap2: :clap2: :clap2: :clap2: :clap2: :clap2:
http://s240.photobucket.com/albums/ff8/baldwookie/?action=view&current=05-30-09_1511-1.flv
1980 lwb sr5  stock
Quote from: baldwookie on May 30, 2009, 01:32:46 PM
.............. doesnt want to spring back
should be 2 nuts on the carb throttle shaft,loosen it a little and that should do it,  remember that spring i told you to make sure you got in there ??
baldwookie
yeah spring is on there...... loosened nuts a little still doing it....
1980 lwb sr5  stock
V-Man
baldwookie
friend came over the other day to pick me up,  fired the truck up so he could hear it.....  blowing oil on the driverside... looks like out of the spark plugs....  but wasnt fowling out.. still runnin.....skeers me, dont think i over filled it... what it looks like,  its sort of on a hill also,  just  4 qts, figured would need a little xtra to fill oil filter an galleys etc.. im at his house visiting while his family is on vacation..... when i get home ill see what that might be,  still got a leak under the intake...   be better to buy a seal,  or would some rtv, work?     all so leaks around the lower temp sensor,  gonna put some tape around the threads hope that fixes that.  tues when i get paid finish gettin the paper work part of it legal... then the skeery trip to town an have muffler welded..(open header)  in a hick-town... sure to be a ticket... :crossed:  linkage on carb still wont spring back... but i can lift up the pedal with my foot n it idles back down.....  still more adjusting.. oh an yeh im a boob... this is all new to me.. i love vehicles... but normally just tinkered... this is the first motor ive ever put in,  much less custom....
1980 lwb sr5  stock
