the wookie mobile build-up
Started by baldwookie, October 11, 2007, 12:42:34 AM
80/90 wt gear lube,   I suspect the reason the clutch is going bad is cause you still dont have gears done for those 35's
baldwookie
probably n i ride the clutch a lot.... dont drive it much would have thought it would have lasted a bit longer... all i do is work....   if i have a day off im just relaxing....  clutch is one of the things i know how to replace.. done it a few times already... maybe just the master cylinder its pretty old....   ill know for sure when i break it apart an see how thick it is
1980 lwb sr5  stock
baldwookie
took zach to mud madness (local 4x4 club thing)    had him pull it around the mud pit... been acting up sense.....   was pretty muddy even in the spectater areas
1980 lwb sr5  stock
get yourself a Marlin 1200  you'll never need another clutch
Quote from: baldwookie on April 30, 2010, 10:32:33 AM
OMG  dude you should have went to Gilmer,  the main dang roads where foot deep mud :disturbed:
i tell you what order you some 5.29's from Marlin and send them down here and i'll set them up for ya
baldwookie
i did i put in the 1200 when put motor in.... i would have liked too.... gettin off work is a pita....... im gonna order em just not sure if the gears will work when i change rear end to a ifs rear..... also gonna put locker in at the same time (aussie)
1980 lwb sr5  stock
you shouldnt need a clutch probably the slave or master
yes, if we build a diff now  it will swap right into the ifs housing with no mods at all
ok  :bolt:
baldwookie
yeah twas what i was hoping... aight cool.....
1980 lwb sr5  stock
baldwookie
ooh wifie is gonna do surprise updates to my truck yay.... dont know what she has in mind... just told me to clean it out real good.... goodie-goodie :clap2: :clap2: :clap2:
1980 lwb sr5  stock
unclejpl4x4
Quote from: baldwookie on July 24, 2010, 04:50:51 AM
:shudder: she dose not like pink dose she ............... im just saying
maybe its a inclometer  or a radio or a gauges or air freshener.
baldwookie
well changed out the slave cylinder seemed to help but still not perfect....     im gonna try to gather up the stuff to do ruf/f150 springs.... hate to but might ask for some assistance if anyone is bored in about a month....  i can provide beer n someting on the grill :)   ill know more after i gather stuff
1980 lwb sr5  stock
unclejpl4x4
i would help but i would just steal your springs and put them on my truck muhahahahahaha
Kevin when you get ready let me know a week or so ahead of time and we'll get r done.  my brain and your muscles :)
baldwookie
1980 lwb sr5  stock
baldwookie
ok just bout rdy to do ruf/f150s....  good plan to wait on shocks til after i get it all done... measure it out?    not really sure how to do this... someone pt me to a link?    also can i run my push pull steering for a bit til i gather up some cash n pieces for hysteer?     ya i know that piece i was suppose to get from domino.. that i kept droppin the ball on would have helped huh... geesh i suxor
1980 lwb sr5  stock
unclejpl4x4
wish i could come over just need :beer:
domino
You could do the RUF without going to histeer, but you would have to cut, shorten, and sleeve your drag link and torque rod.  The added flex from the RUF would make 4 wheeling suck though.  You would have a lot of binding in your steering and probably go through more than your share of j-arms.  Adding hi steer isn't that expensive for what you're getting.  IFS steering boxes sell for $75 and you can usually find used histeer for under $250.
baldwookie
thnx domino ill have to keep my eye out for some used parts.... come on over joe....    BEEEEEER!!!!!!!
1980 lwb sr5  stock
domino
And I've got an IFS steering box you could have for $50 if you pull it off the truck.
:popcorn:   hopefully when you get ready i'll have these damn migraines under control :wall:
baldwookie
oh ive been ready to do it.... just gettin off my lazy butt n not feelin guilty for spending the money.. n just doing it... tired of not been able to wheel.....  forgot how much i hate 2nd shift... yeah i know im whining... at least its a job.. feels more like purgatory most of the time
1980 lwb sr5  stock
baldwookie
well passenger side shock tower splittin away from the frame now... geesh... last time i buy shocks from napa.....too short a shock it has no lift an the shocks are over extending.... not even wheelin driving 3 blocks to work... c'mon income tax i want new suspension
1980 lwb sr5  stock
sounds like its time for some shock hoops.
hey did that crack in the drivers side ever get welded up??
baldwookie
#265
yeah had local muffler shop weld it up....    maybe i should do that...  but then id have a hell of a time figuring out which shocks to put on it..  also anyone have any idea where to find a shift  boot that fits yota's?
1980 lwb sr5  stock
baldwookie
well had it all runnin good... coming back from break yesterday... it died coming in the parking lot at work....  just got gas.....  it turns over strong.. is gas at the carb.....  but cant seem to get any fire.....pulled a sparkplug wire off.. tried to see if it was jumping spark.. cant see any spark.. it is daylight tho......could be coil or the modulator under it... it still has the factory coil on the firewall... any ideas be greatly appreciated....im not having much luck with my truck.. sigh....
1980 lwb sr5  stock
mine has been running like crap for about a week. those damn gas companies probably changed the mix.
I need more info.  pull the cap off the distributor and make sure the rotor button goes round and round when you crank the starter.
baldwookie
alright gotta walk back down to work.. i left it in the parking lot     thinkin something might have happend to the dist shaft?     lookin at coil prices wow there not cheap....
1980 lwb sr5  stock
V-Man
Quote from: baldwookie on March 12, 2011, 03:16:23 PM
I think glen could look on one of the trucks for a used one, maybe...  :headscratch: Glen can we spare a Coil if he needs one....Of course it maybe cheaper for him to buy a new one then to come down and help with the Pumpkin build. :yesnod:
