Author Topic: the wookie mobile build-up  (Read 47921 times)
0 Members and 9 Guests are viewing this topic.
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
Re: the wookie mobile build-up
« Reply #150 on: Jun 05, 2009, 12:13:11 PM »
did you put the dipstick back in??  i cant think of anything on the drivers side that would spit oil :headscratch:
baldwookie [OP]
  • Turtle Points: 43
  • Male Posts: 173
  • Member since Feb '06
  • one of these days ill be big like u guys/gals
« Reply #151 on: Jun 06, 2009, 06:52:15 AM »
yeah dipstick is in... its up high why i think its coming from spark plugs....... u call me a dipstick :) hehehe didnt mess with it very long... i will when i get home....
1980 lwb sr5  stock
« Reply #152 on: Jun 06, 2009, 07:48:39 AM »
:headscratch: i HOPE its the valve cover gasket has a kink in it :dunno:
baldwookie [OP]
  • Turtle Points: 43
  • Male Posts: 173
« Reply #153 on: Jun 06, 2009, 08:17:11 AM »
it might be ....
1980 lwb sr5  stock
unclejpl4x4
  • Turtle Points: 348
  • Male Posts: 3,522
  • Member since Apr '05
  • Broke & rusted
    • myspace
« Reply #154 on: Jun 06, 2009, 08:26:04 AM »
thats what i was thinking a pice of wookie hair is stuck in it
V-Man
  • Turtle Points: 29
  • Male Posts: 792
  • Member since Sep '04
« Reply #155 on: Jun 06, 2009, 08:39:43 AM »
 Ya but it suits the owner to a tee.....Just a little bent.  :cheese:  :yupyup:
baldwookie [OP]
  • Turtle Points: 43
  • Male Posts: 173
« Reply #156 on: Jun 06, 2009, 10:00:16 AM »
so im bent now?    grrrrrrrrrrr
1980 lwb sr5  stock
baldwookie [OP]
  • Turtle Points: 43
  • Male Posts: 173
« Reply #157 on: Jun 12, 2009, 06:50:59 PM »
well    ws tinkerin on truck today, water leak fixed(pipe tape on threads for the lower water temp sender), oil leak fixed(small pinch in valve cover gasket),   something told me to check the oil, and  :yikes: oil was a bit milky :(((  not real bad just cloudy...s.o.b    ill drain it in the morn see how bad it is......frustrated
1980 lwb sr5  stock
unclejpl4x4
  • Male Posts: 3,522
  • Broke & rusted
    • myspace
« Reply #158 on: Jun 12, 2009, 06:57:40 PM »
........... milky     like  white russin milky  or MCDs milkshake milky
« Reply #159 on: Jun 13, 2009, 04:04:56 PM »
coolant is leaking past the timing cover gasket :woohoo:  at least its not the headgasket :ack:
your going to need to lower the oil pan,  most of the way, it doesnt need to come off, but the front needs to be about 1/2 inch dropped down
then remove the 12mm bolt thats in the oil pool under the distributor THEN you can remove the timing cover,
you shouldnt need to remove the timing chain
baldwookie [OP]
  • Turtle Points: 43
  • Male Posts: 173
« Reply #160 on: Jun 13, 2009, 04:14:52 PM »
k cool.. it never ran long enough to get hot barely register off cold even when i drove it to thoe house... good..... was hoping head wasnt warped...k     rad/oil draining so i can remove some of the oil pan bolts.... dist,alt,ac,ps water pump (water was clean)
all removed
1980 lwb sr5  stock
baldwookie [OP]
  • Turtle Points: 43
  • Male Posts: 173
« Reply #161 on: Jun 13, 2009, 04:17:10 PM »
so is that the right way.... had it at 0 deg on crank then spun it till master links are like at 11:45?  so i can re-align everything?    just remove cam bolt?
1980 lwb sr5  stock
« Reply #162 on: Jun 13, 2009, 04:32:57 PM »
remove the cam bolt and distributor drive, DONT REMOVE THE CAM GEAR
« Reply #163 on: Jun 13, 2009, 04:34:46 PM »
not really,  but you shouldnt need to mess with the chain or the gears,  i had to have messed up the gaskets in there behind the timing cover :headshake:
« Reply #164 on: Jun 14, 2009, 03:56:05 PM »
:sofa:
« Reply #165 on: Jun 14, 2009, 03:59:39 PM »
1/2 inch breaker bar and 19mm socket,  put bar up against pass side frame rail and bump the starter
baldwookie [OP]
  • Turtle Points: 43
  • Male Posts: 173
« Reply #166 on: Jun 15, 2009, 12:35:17 PM »
the day i found this in my oil  :( :yikes:
http://i240.photobucket.com/albums/ff8/baldwookie/06-12-09_2220.jpg
after i pulled it apart (gaps in the rtv?)
http://i240.photobucket.com/albums/ff8/baldwookie/06-15-09_1339.jpg
gaskets look ok....  just on of the top holes looked a little misaligned.....not bad tho.. no tears in it
and how it sits now til i get new gaskets tues
http://i240.photobucket.com/albums/ff8/baldwookie/06-15-09_1341.jpg
1980 lwb sr5  stock
unclejpl4x4
  • Male Posts: 3,522
  • Broke & rusted
    • myspace
« Reply #167 on: Jun 15, 2009, 02:30:15 PM »
well  there should only be enough  rtv on the gasket 2 hold it in place there is a few spots where a little more is good
also drop the oil pan a bit  if U have not done so  don't wanna bunch up the oil pan gasket or nick the head gasket when it's time 2 reassemble.
baldwookie [OP]
  • Turtle Points: 43
  • Male Posts: 173
« Reply #168 on: Jun 15, 2009, 04:09:01 PM »
thnx joe....was just a little on the cover none was stuck to gaskets
1980 lwb sr5  stock
« Reply #169 on: Jun 15, 2009, 04:39:49 PM »
i only had blue RTV  :headscratch:
« Reply #170 on: Jun 15, 2009, 04:47:56 PM »
:headscratch:  OMG  how could i have missed NOT cleaning that timing cover :headshake:
i must have stuck it on to check that it fit (not a laser block cover) and forgot what i was doing and just bolted it up :wall:
:rivers: IM SORRY :rivers:
unclejpl4x4
  • Male Posts: 3,522
  • Broke & rusted
    • myspace
« Reply #171 on: Jun 15, 2009, 05:06:43 PM »
:shudder:
« Reply #172 on: Jun 16, 2009, 06:11:37 PM »
Kevin ??  what did ya find ??
baldwookie [OP]
  • Turtle Points: 43
  • Male Posts: 173
« Reply #173 on: Jun 17, 2009, 07:43:50 AM »
cover looks fine...scraped all goo off..wire-wheeled it smooth.....   headn to town to get gaskets,oil,antifreeze now......mebbe tonight ill try to fire it up... :crossed:
1980 lwb sr5  stock
« Reply #174 on: Jun 17, 2009, 08:09:36 PM »
:popcorn:  AND ???
baldwookie [OP]
  • Turtle Points: 43
  • Male Posts: 173
« Reply #175 on: Jun 22, 2009, 03:49:17 PM »
well figures.... as i was tryin to get cover on i nicked up the head gasket... now im sick to my stomach :willynilly:
1980 lwb sr5  stock
« Reply #176 on: Jun 22, 2009, 04:27:02 PM »
how bad??  did you drop the oil pan down??
if its not bad you could try some rtv :dunno:
:slap: WHAT YA DO THAT FOR :slap:
baldwookie [OP]
  • Turtle Points: 43
  • Male Posts: 173
« Reply #177 on: Jun 22, 2009, 04:36:50 PM »
yeah dropped it down.. bout 1/2 inch.......im just like that i guess..... wasnt on purpose i can assure u
1980 lwb sr5  stock
unclejpl4x4
  • Male Posts: 3,522
  • Broke & rusted
    • myspace
« Reply #178 on: Jun 22, 2009, 04:41:27 PM »
U where drinking that fancy :beer: and not a good motor building :beer:  wherent U
baldwookie [OP]
  • Turtle Points: 43
  • Male Posts: 173
« Reply #179 on: Jun 22, 2009, 05:30:14 PM »
wasnt drinkn any beer :(      might be part of the problem.....just cant get the cover on...... doesnt seem to be lining up.....gotta take a break... way too frustrated
1980 lwb sr5  stock
Last post Sep 10, 2007, 03:20:05 PM
by DTB
cheezy mobile
Last post Jun 22, 2011, 05:41:57 AM
by Superyota85
Last post May 06, 2008, 06:20:56 PM
by lilbuddy
Last post Jan 26, 2009, 03:52:51 PM
by unclejpl4x4
Last post May 21, 2011, 01:49:24 PM
by 79coyotefrg
