IFS is gone!! 3.0 Killer on 1 tons
Started by BLACKDOG, April 17, 2006, 08:57:18 PM
Brandon
Brandon Miller
RCRC, Sacramento, CA
www.RiverCityRockCrawlers.com
BLACKDOG
Quote from: Brandon on May 15, 2006, 09:02:50 PM
cute pup ;)
sheepdog?
queensland heeler/corgi mix.  Definitely more of the queensland then the corgi.  he's a good dog though, about 13 weeks old, I think.
              -Ronald Reagan
Shamb
gonna love those duals, night and day differance.
BLACKDOG
 :inthedark: found it!  Now that I am done moving, I'm back to work on my truck.  I  plan on throwing the duals in within the week, and then progressing to other things!! :hyper:
              -Ronald Reagan
toyo487
1986 Toyota 4Runner 22re 5spd transmission and dual transfer cases (4.7's in the rear). E-lockers front and rear.
2005 GMC Sierra diesel, compound turbo setup to pull.
   God gave all people talents but the only one who can find them is you.
unclejpl4x4
BLACKDOG
Alright, getting some stuff done, but I need a quick question answered.  I'm wanting to position my new lower shock mounts in the circle on the axle, and position the top mounts on a plate welded to  the crossmember overhead, the classic /\ pattern. My question is, how much of the shock shaft be seen when at ride height?  It seems that about half would make sense, give just as much down travel as up travel, but I :dunno:
              -Ronald Reagan
MiniSimp
You really need to flex it out to find out.
I had mine all measured out until I flexed it, then I had to move my lower mounts 1" down so they wouldn't bottom.
BLACKDOG
Quote from: MiniSimp on June 07, 2006, 09:43:04 PM
oh alright, fine.    :-\
              -Ronald Reagan
BLACKDOG
Man, :headshake: I thought I'd be less busy this summer.  Finally got around to working on my truck today :hyper:  got the adapter plate put on the crawler, and it is almost ready to be thrown in!!  Made a mess out of my truck in the process, and discovered about $8 in change under my seats and carpet.
I do have one question though, how hard should the cralwer be to shift?  the shift rail was barely fit into the hole in the adapter.  Its all together now, and it shifts, but its really stiff :dunno:  is this normal?  I'm guessing that once the transfer case is bolted in, it may be easier to shift since I 'll have some resistance, and the whole case won't be trying to roll over on me.
              -Ronald Reagan
BLACKDOG
              -Ronald Reagan
BLACKDOG
 :outtahere:
              -Ronald Reagan
BLACKDOG
Quote from: BLACKDOG on June 13, 2006, 12:46:12 AM
:dunno: anyone? :dunno:
              -Ronald Reagan
MiniSimp
Not that hard.
Did you torque the detent screw properly?
BLACKDOG
Quote from: MiniSimp on June 13, 2006, 03:28:15 PM
Not that hard.
I didn't know I was supposed to torque it :dunno:  I didn't see that in my instructions.
I messed with it a little today, shifted it back and forth a few times, and it smoothed out :thumbs:
Got the crossmember off, that thing was a PITA.  Its hard to work on this thing between work and it getting dark.  :down:  I don't get to work on it tommorow, but Hopefully I'll have the crawler bolted up on thursday :crossed:
              -Ronald Reagan
reklund5
Hey Blackdog-
It looks like somebody took your SAS and put the IFS back on...
:yikes:
BLACKDOG
Quote from: reklund5 on June 13, 2006, 10:19:53 PM
Hey Blackdog-
:yikes:
:down: I wish, cause that would mean that I had had a SAS at one point in time.
Soon Reklund, soon :crossed:  I have the axle, after this gets done, thats the next big $$ project :thumbs:  couldn't afford to do both at the same time, and I figure since the front driveshaft on an IFS doesn't really move much, I can use a square tube driveline, and use the same one with the SAS.  either that or make another one :dunno:
              -Ronald Reagan
MiniSimp
Quote from: BLACKDOG on June 13, 2006, 09:48:12 PM
It's in the FSM "Torque to 9ft. lbs (13nm)
BLACKDOG
              -Ronald Reagan
BLACKDOG
Didn't get a wholoe lot done today, got the old t-case out, and clearanced the tranny for one of the bolts for the adapter.  I'm going to be getting off work early tommorow, so hopefully I'll get everything bolted back in :crossed:
              -Ronald Reagan
BLACKDOG
I do have a question.  I got a new seal from marlin, but I wasn't exactly sure how it goes in.  I think I figured it out, but I want to confirm before I pull the old seal out and bolt everything together.  Nothing I hate more than to have to redo something because I was stupid :smack:
              -Ronald Reagan
fj-rankenstein
your last pic you posted is right... i am just going through the exact thing this week....that seal will seal around the input of the new tcase you will put on the back of that tranny.... the v6 adapter "locks in" that seal adapter once its all together....
i think it presses in, sorta, on the tranny end and just fits in the v6 adapter end... i was thinking i would put some sealant on the seal adapter shoulder where it plugs into the v6 adapter  so there is no oil transfer.....
the never ending build...
http://board.marlincrawler.com/index.php?topic=12165.0;highlight=extend-a-toy
Quote from: BigMike on April 10, 2010, 11:30:18 AM
Was searching for something and came across this old jew. BUMP to a classic thread :thumbs:
BLACKDOG
Quote from: fj-rankenstein on June 15, 2006, 08:02:49 PM
I put it together, but its more like the way I have it in the 2nd pic.  The coupler doesn't fit in the new seal, so you slide the seal onto the crawl box input, where it locks in, then slide the coupler onto the input, and then attach to the tranny :thumbs:  it all went together just fine.
Now I have to go find some studs to attach my rear t-case to the adapter.  The bolts that came with it cannot fit in the gap to thread into the holes, so I need to run some studs into the t-case, and then mount it.
pics to come! :thumbs:
              -Ronald Reagan
yota-tota
looking good mang :gap: that's the new adapter for the g-58 trans isn't?
91 toy truggy on h2 injection, hacked n chopped n locked n SAS'd rolling 36" IROKS........doubler comming soon
BLACKDOG
Quote from: yota-tota on June 18, 2006, 01:30:01 PM
nah, adapter to use the chain driven t-case behind the 3.0 :thumbs:
its going:
3.0-->R150-->3.0 adapter plate-->crawl box-->MC10 adapter-->Chain driven t-case :thumbs:
              -Ronald Reagan
BLACKDOG
Pictures!! :hyper: :hyper:
1st pic:
shaving the tranny housing (didn't shave enough off :headshake: )
2nd:  Almost done!! (or so I thught)
3rd: :werd:
              -Ronald Reagan
BLACKDOG
 :clap:
Bit of a problem, but no big deal.  The provided bolts will not fit in the gap between parts of the adpater to thread into the necessary holes.  I simply need to get 3 more studs to thread into the t-case before I bolt it up to the adapter.  :dunno:
Hopefully I'll get the studs tommorow, because it is all downhill from here :hyper:
              -Ronald Reagan
synwars
Quote from: BLACKDOG on June 13, 2006, 03:16:58 PM
Ya I remember mine was difficult to shift initially. One because the assembly grease is way thicker than gear oil, the other because it wasn't mounted. Wait until after you do your first oil change to worry about it. Once the oil works its way in there, there will be a lot less friction to bind it up. :thumbs:
Build up thread:
KEEP IT CLEAN PEOPLE!!! :bat:
BLACKDOG
Quote from: synwars on June 19, 2006, 06:53:46 AM
Well, thats a relief.  :thumbs:  kinda what I was thinkin :yupyup:
Got some studs and tossed those in the rear t-case, have everything bolted together now :hyper:  went to bolt on the crossmember and ran into ANOTHER snag.  My crossmember mount that bolts to the t-case doesn't quite match up to the crawlbox mount holes :smack:  I was gonna cut and weld the tab a little differently, but wouldn't you know it, the welder I borrowed from spotter's dad doesn't match the 220v plug we have in our house :smack:  So now I am looking for a gear driven t-case mount, so I can continue on.  I may take the peices over to a friends house, see what we can do there, or I may just go see if I can find the mount at an auto parts store : :headscratch:
I swear I'm gonna get this done eventually!!
              -Ronald Reagan
