cute pup sheepdog?
You really need to flex it out to find out.I had mine all measured out until I flexed it, then I had to move my lower mounts 1" down so they wouldn't bottom.
I do have one question though, how hard should the cralwer be to shift? the shift rail was barely fit into the hole in the adapter. Its all together now, and it shifts, but its really stiff is this normal? I'm guessing that once the transfer case is bolted in, it may be easier to shift since I 'll have some resistance, and the whole case won't be trying to roll over on me.
Not that hard.Did you torque the detent screw properly?
Hey Blackdog-It looks like somebody took your SAS and put the IFS back on...
I didn't know I was supposed to torque it I didn't see that in my instructions.
It's in the FSM "Torque to 9ft. lbs (13nm)
Was searching for something and came across this old jew. BUMP to a classic thread
your last pic you posted is right... i am just going through the exact thing this week....that seal will seal around the input of the new tcase you will put on the back of that tranny.... the v6 adapter "locks in" that seal adapter once its all together....i think it presses in, sorta, on the tranny end and just fits in the v6 adapter end... i was thinking i would put some sealant on the seal adapter shoulder where it plugs into the v6 adapter so there is no oil transfer.....
looking good mang that's the new adapter for the g-58 trans isn't?
anyone?
Ya I remember mine was difficult to shift initially. One because the assembly grease is way thicker than gear oil, the other because it wasn't mounted. Wait until after you do your first oil change to worry about it. Once the oil works its way in there, there will be a lot less friction to bind it up.
Started by yotadork83 Parts For Sale
Started by nor-cal zukini Parts For Sale
Started by BLACKDOG Chit Chat Camp
Started by blackdiamond Project Research and Build-Ups
Started by kdub0013 « 1 2 ... 11 12 » Project Research and Build-Ups
