Duffil's 84 Xtra Cab is still bringing the suck
Started by Duffil, March 26, 2006, 07:25:29 PM
CrazyYota
Quote from: Duffil on February 07, 2008, 09:32:22 PM
about 8 months ago I put in an  AutoGage Temp/volt/oil pressure cluster..I never hooked up the temp gauge.  When it goes back together, it will have the temp gauge hooked up.
are those the ones on your dash :gap:
Yota87Truck
[spoiler]looks good[/spoiler]
Wermz84
I thought you were going to get 1022021.  that box says 1022024.   Change your mind?  :dunno:
I like to Drive!
Duffil
Quote from: Wermz84 on February 08, 2008, 06:14:15 PM
congratulations!! you are the only person paying attention!!  I'm not sure what happened...I think I was drinking when I posted that up, because the 1022024 has a little higher torque numbers all the way up the powerband.  [spoiler]So, either I changed my mind, posted the wrong info(read: :boozer: ), or they sent me the wrong part.  Take your pick. :laugh: [/spoiler]
edit: i couldn't resist.
*** YELLER ***
Quote from: Duffil on February 08, 2008, 06:33:01 PM
He went back and read it over just to catch the RAINMAN  in an OOPS  :rofl2:
:usa: :beerwhack:
except BACON
Wermz84
:rofl:  I think it's all of the above!  :yupyup:
I'm paying attention because i'm trying to figure out what the hell i'm doing with my build.  haha.   I better go take some pics and put it in my thread.  haha
EDIT:  why does end quote not work anymore??
I like to Drive!
Duffil
it does, but not if you use the spoiler. :dunno:
Dave, you had better mark that down. :bolt:
skipnrocks
ummm all the above maybe?
WILLYNILLY
*** YELLER ***
except BACON
Duffil
OK so I  :bath: and now I feel ready to go out.  damn the bars just closed.
:bowdown: to MiniSimp
OK so for tomorrow I still have to:
adjust the valves
install thermostat
install AC Compressor
install radiator/hoses
install belts
install temp sender for AutoGage gauges
install engine to trans bracket
finish routing vacuum lines/install air cleaner
add oil
break in cam
post a shitload of pics
skipnrocks
How do you break in a cam?  I have a new one in my motor but I never thought much about breaking it in.
WILLYNILLY
Duffil
run the engine at 1500-1800 RPM for20-30 minutes, as per LCs instructions.
skipnrocks
THen do you have to change the oil after that?
WILLYNILLY
Duffil
[spoiler] it is alive!!  gonna go run it a while to get some time with it...I need to relearn how to drive it.[/spoiler]
Wermz84
Quote from: skipnrocks on February 10, 2008, 10:35:17 AM
Thats what i've been told.   run 20 min, change oil.
Quote from: Duffil on February 10, 2008, 04:57:50 PM
Woohoo!    what? it's been that long.   :gap:
I like to Drive!
Duffil
yes, it has.  I just got back...went about 50miles.  When I first got behind the wheel, I was NOT impressed.  It felt totally stock...very little lope, it wasn't peaky at all...I couldn't figure it out.  Then I put the hammer down.  This thing will spin the tires in 1st gear hi/hi, where it never would before.  It has loosened up a bit, and I am liking it more and more.  It feels like a totally stock truck...with a shitload of torque. Where my last cam was a little flatter until my vac advance kicked in(and then hold on) this thing is strong all the way from idle.
It idles WAY smoother than it ever has before...and actually so low(read:where it is supposed to) that I need to step up to a 20w50 oil; there is a oil pressure related tick until it gets back to 35psi.  It is running a little warm I think, at around 220, but I have not tuned the carb for this cam, and I am waiting on a BVSV from Toyota tomorrow to replace one that I broke.\
I should note that I have the adjustable cam gear set at stock right now, and am running at stock distributor timing instead of my usual 15*.
Duffil
 :pirate:
and it's back on the road!
skipnrocks
Awesome! bet it feels good to have it goin strong again!
WILLYNILLY
*** YELLER ***
SWEEEEEEET nice work bud  :thumbs:
good job  :bowdown:
:usa: :beerwhack:
except BACON
*** YELLER ***
BTW does your shaved axle get warmer now that you shaved it, you know cause it has less oil now ??? or am I mistaken in my assumtion, shaved meens less oil and warmer temp. ???
:usa: :beerwhack:
except BACON
Duffil
Quote from: oldyellercj on February 10, 2008, 07:11:42 PM
:usa: :beerwhack:
I don't know.  I never paid attention to it before, and I really only felt it when I was breaking in my gears.  I think in theory, it probably should.
*** YELLER ***
Quote from: Duffil on February 10, 2008, 07:35:25 PM
Then you arent worried about it  :dunno:   if yer not then I wont  :greengrin:
:usa: :beerwhack:
except BACON
Duffil
well, I have thought about it, and I do plan on flipping the fill plug to let it hold some more fluid.  I don't think I'll do it to this housing, but I will do it when I get an IFS rear.
*** YELLER ***
Quote from: Duffil on February 10, 2008, 07:44:11 PM
but I will do it when you give me that IFS rear.
:biggthumpup: fixed it fer ya bud  :thumbs:
:usa: :beerwhack:
except BACON
skipnrocks
#804
What are you refering to when you say IFS rear?  I only know that to mean independant front suspension?
WILLYNILLY
*** YELLER ***
Quote from: skipnrocks on February 10, 2008, 08:26:01 PM
What are you refering to when you say IFS rear?  I only know that to mean individual front suspension?
86 and up rear axle is wider than 85 and older  :slap:
:usa: :beerwhack:
except BACON
*** YELLER ***
and I belive its INDEPENDENT FRONT SUSPENTION  :slap:
FREEKIN' JEEP OWNERS  :disturbed:
:usa: :beerwhack:
except BACON
Duffil
I am going to use the old front end off of Daves truck so I can have independent rear suspension, and i want to shave the IFS housing because it is really hairy.
*** YELLER ***
 :haha:
Quote from: Duffil on February 10, 2008, 09:04:32 PM
:usa:  :beerwhack:
except BACON
skipnrocks
Quote from: oldyellercj on February 10, 2008, 08:36:29 PM
:usa: :beerwhack:
Come on oldyeller we cant all know everything....   thats just reserved for those of you that have been around to see everything....
LOL I was wonderin......
WILLYNILLY
