0 Members and 15 Guests are viewing this topic.
about 8 months ago I put in an AutoGage Temp/volt/oil pressure cluster..I never hooked up the temp gauge. When it goes back together, it will have the temp gauge hooked up.
I thought you were going to get 1022021. that box says 1022024. Change your mind?
congratulations!! you are the only person paying attention!! I'm not sure what happened...I think I was drinking when I posted that up, because the 1022024 has a little higher torque numbers all the way up the powerband. [spoiler]So, either I changed my mind, posted the wrong info(read: ), or they sent me the wrong part. Take your pick. [/spoiler]edit: i couldn't resist.
Dave, you had better mark that down.
THen do you have to change the oil after that?
[spoiler] it is alive!! gonna go run it a while to get some time with it...I need to relearn how to drive it.[/spoiler]
BTW does your shaved axle get warmer now that you shaved it, you know cause it has less oil now or am I mistaken in my assumtion, shaved meens less oil and warmer temp.
I don't know. I never paid attention to it before, and I really only felt it when I was breaking in my gears. I think in theory, it probably should.
but I will do it when you give me that IFS rear.
What are you refering to when you say IFS rear? I only know that to mean individual front suspension?
I am going to use the old front end off of Daves truck so I can have independent rear suspension, and i want to shave the IFS housing because it is really hairy.
FREEKIN' JEEP OWNERS
Started by tdawg Parts Wanted
Started by lilbuddy Rig Gallery
Started by DTB « 1 2 3 4 5 » Chit Chat Camp
Started by BadnewsBob Project Research and Build-Ups
Started by 83Camo Newbie Questions
