84 4Runner Buildup - Last minute summer mods
Started by Volcom, August 23, 2005, 10:03:16 AM
Jud
Quote from: Volcom on February 06, 2007, 12:12:15 PM
I also have to figure out what I'm going to do with the stupid LPSV in the rear.
i talked to the guys down at allpro and they told me to just hack the bar off then ziptie it up to give the full amount of braking to the rear and it worked great!
"bout tree fiddy"
Volcom
Quote from: Fearofrunner on February 06, 2007, 12:18:59 PM
get rid of it, with a runner that old the LSPV probably locked up... am i right?  Aftermarket proportioning is well worth the effort
I will probably follow your buildup thread on how to put that Wilwood proportioning valve in :)
84 4Runner
Marlin Dual Ultimate crawler
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
Fearofrunner
 :thumbs: sweet man that's what it's there for.   :greengrin:
Volcom
My dad rocks!!!  He took the front axle housing and spend 5 hours cutting and grinding all the unneeded brackets and mounts.  He saved me 5 hours of work this weekend so I can spend my time working on something else.  Thanks DAD!  :beerchug:
84 4Runner
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
hollywood_toy90
nice looking build man, and agree about the light thing, you can nevr have to much, during builds and usally just repairs we have 2 or 3 flashlights out and on.  i like to see what im doing! keep it up!!
Loki
Quote from: Volcom on February 08, 2007, 11:43:21 AM
what did he use to cut all that stuff off the axle? and where are the pictures of the cleaned up axle? :)
88 turd SAS with some "stuff" under it.
MY BUILD UP THREAD
Volcom
Quote from: Loki on February 08, 2007, 01:00:21 PM
angle grinder with a cutoff wheel.  I'll post some pics tonight!
84 4Runner
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
Loki
ok...now i know why it took so long...yes post pics...i've got to see how that came out...can't wait to see this thing done.
MY BUILD UP THREAD
Volcom
Front axle housing with brackets and mounts cut off.
I went to AutoZone tonight and spent $380 in brakes for the front and rear.  Before you say, wow, you spent way too much.  I do get $130 of that back with my core returns.  So, I've got $250 in brakes.  I bought reman front V-6 calipers, new V-6 brake master cylinder (1 inch bore vs. 3/4 bore on stock 84 setup), front brake pads, rear brake shoes, and rear wheel cylinders.  This setup should make a huge difference in stopping power from the stock 84 setup.  I also needed a bigger master cylinder for the larger drums on the rear with the IFS rearend I'm running.
V-6 and stock 84 calipers
One small piston and one large piston
Two large pistons
V-6 caliper has cooling fins on side of caliper.  They are bigger and will work with the new FJ-40 brake rotors I got with the kit.
Stock POS
I bought a breaker bar also.   My brother asked me like 3 times for a breaker bar last weekend and I didn't have one.  I do now  :D
84 4Runner
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
Loki
what rotors are you running? axle looks pretty good, any armor going on that thing?
MY BUILD UP THREAD
Volcom
Quote from: Loki on February 09, 2007, 06:49:23 AM
Whatever rotors work with a solid front axle and either IFS 4 cylinder or V-6 brakes, I think they are FJ40 rotors.
I've got an axle truss, knuckle gussets, and diff armor to install this weekend.
84 4Runner
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
Volcom
2/10/07
30 Spline Longfields are here!!!!  They are almost too pretty to install, work of art.
Stock birfield is 30 spline in the diff and necks down to 27 spline
30 spline Longfield stays 30 spline into the birfield
Joe and I disassembled the top shift transfer case I plan on using for rear case and 4.7 gears
Here's was our workbench for several hours.  My knees killed me after working on the case
84 4Runner
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
Volcom
Sunday 2/11/07
My dad and I worked on the front axle, cutting out the drain plug, and getting on the armor and truss.  We also cut off the stock shock towers and postioned the front crossmember.
Front spring hanger is 3/4 of an inch in front of the stock hanger
Shock towers are gone
84 4Runner
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
Fearofrunner
why'd you go 3/4" in front of the stock location? Better alignment of your axel??
toybuilt
Looks like thats goin to be a stronge front axle once your done. Cool build, lets see more  :beer: :biggthumpup:
2021 Toyota Tacoma TRD Off Road
1983 Toyota Turned Chevy
Treat every day like its your last, because you never know when your time is up. In loving memory of Judstin.
topar
Volcom
Quote from: Fearofrunner on February 11, 2007, 10:28:16 PM
TG instructions say to.
84 4Runner
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
Volcom
Marlin Crawler 23 spline dual case adapter, 4.7 to 1 low range gears, and two solid collar spacers were delivered today!!!
Looks like I'll be working on t-cases this weekend!
I took a quick trip home to get the package off of the doorstep and into the garage.  I don't like having expensive stuff sitting right out in the open.
84 4Runner
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
Fearofrunner
[napolian dynamite] LUCKHEE!
you gonna post some pics of the stuff? :drooling:
46&2
Awesome build man. Very well thought out. Im digging the pictures, keep em up.
Volcom
2/12/07
Marlin Crawler stuff is here  :turtle: :turtle: :turtle:
Each one is stamped with a #.  I'm dual case # 3580
4.7 to 1 low range gears!
Same with the 4.7 gears.  I'm impressed with the gears and the adapter so far.
PORC has shipped my 5.29 gears.  Come on Aussie Lockers!!!!!!!!  I need them this week but I'm guessing they won't get off of back order for a while.  I hope they get another shipment this week and fill their orders so I can get my two aussies in the next 2 weeks or I'll be screwed for being locked for my Moab trip  :slap:
84 4Runner
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
Jud
how much do those aussie lockers go for?
"bout tree fiddy"
Fearofrunner
Jud
"bout tree fiddy"
Volcom
Quote from: Fearofrunner on February 12, 2007, 09:37:53 PM
239.99 http://www.offroadlockers.com/
He is correct!  Two of them shipped to CO was @ $500.  I think they are one of the best buys when it comes to Toyota lockers.
84 4Runner
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
Jud
Quote from: Volcom on February 12, 2007, 10:09:53 PM
I'm planning on putting one in the rear.
"bout tree fiddy"
Volcom
2/14/07
5.29 gears from PORC are here!
Motive Gear???  Anybody hear of them before?
Made in India.  I was hoping for US made gears but what can you expect for $400 (two sets of R&P and two master setup kits).
Marking on the side of the gear
Bearing are Koyo and have Japan stamped on them.
I bought solid spacers instead of using the crush sleeves.
I finally cleaned off my workbench so I can actually stand up and clean parts rather than bending down on the floor.
I've got one hub completely cleaned up.
84 4Runner
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
Volcom
I lost the little tiny ball bearing while I was taking the locking hub apart.  Is this part critical for the hub to work properly?  I circled it in red
84 4Runner
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
Loki
:conf: seems like i've already responded to this, but i'll do it again...you're going to need that steel ball for the hub cover...if you need one, i' have a couple spare hubs around the garage, i can drop one in the mail to you.
MY BUILD UP THREAD
Ramrod
I just ordered some motive gears for my taco and there supposed to be good
