Snow White- 85xtracab Build
Started by Matty, July 17, 2005, 02:19:20 PM
82 HiLux
what gear were you in? was that double low?
i wish there were spots like that to wheel were i live.  :down:
unclejpl4x4
nice looks like fun
I love how u mounted the rear lights
Matty
Quote from: 82 HiLux on May 28, 2007, 12:06:57 AM
yea i was in double low in all of that, going at some of those faces i was in 2nd instead of first to get a little more tire speed.
yea i dont have many spots around, i go there a lot, and only a couple other places.
Quote from: unclejpl4x4 on May 28, 2007, 05:50:35 AM
nice looks like fun
thanks, with the rear lights there i finally stop smashing them everysingle time i go out.
synwars
Build up thread:
KEEP IT CLEAN PEOPLE!!! :bat:
Matty
Quote from: synwars on May 28, 2007, 08:46:58 AM
Nice build.
12-13 seconds in, this video went very wrong...
no need to bring that up.  i was hoping people would look past it and enjoy the wheelin.   :thumbs:
synwars
Quote from: 85xtracab on May 28, 2007, 08:55:47 AM
:haha: HAHAHAHA. If it was on any other site I wouldn't have said a thing. :slap:  :headshake:
But being that you posted it on the :turtle: forum, I must uphold Marlin's sovereignty of the 4x4 world. :moon:
Just bugging. Nice pics and vids. :beerchug:
Build up thread:
topar
Jud
"bout tree fiddy"
Matty
well the whole new rearend is in with marlin 4inch rear springs  :greengrin:  about to start on the front once i finish finding springs.
so the last thing that i have to do on the rear is move the shackle mount and it appears even though we measured a ton and even measuring the springs on the truck everything was done right, but i gained a little bit of wheel base in the rear regardless.   anyways it might work out perfect i am thinking about mounting the shackles on the upper edge of the frame and running a crossmember between the rails.  anyways sketched up a little something.  let me know what ya think.  oh yea these springs seem a little tall for my liking as well so mounting them like this will give me a little less lift.  and for the rear to match the front i think that i may run a 5 leaf RUF pack instead of 6 depending on how much lift the new shackles and drop hanger give me.    FYI trying to keep this around 3 in of lift.
(disregard shackle angle i couldnt figure out how to rotate it more in paint.  its more kicked back.)
dov'd85
finally you cut the back of your flat bed... looks killer man!
85 long bed: 30 spline long, hydro assist, hysteer, 223.1 twin sticks, 39.5 iroks, rear disk,
http://board.marlincrawler.com/index.php?topic=28696.msg344178#msg344178
82 HiLux
awesome truck.  i love the 2nd gen extra cab trucks.  i dunno if i like those or 1st gens better.
how satisfying is stock dual cases?  im getting a parts truck soon and im gonna double up mine.  if its really that worth it to go with 4.7 gears in the second case then i better start saving now.  if stock duals is slow enough to drive up a rock, thats fine for me.  ANYTHING is better than stock.  ive never driven a truck in double low, so i dont even know what it feels like  :down:
DieselD
nice build. I am diggin the iroks too.
86turboyota
Quote from: 82 HiLux on June 16, 2007, 01:12:52 AM
id say go with the dual ultimate... the 4.7s in the rear case are killer... 1st gear in double low is perfect for crawling..
My Build 1986 4runner SAS 36s etc
http://board.marlincrawler.com/index.php?topic=22625.0
"Later, I learned that even though I engage 4WD my hubs are not automatically locking? Something about manual locking hubs I think. What's manual mean? I need to read a manual to lock them? lol  So I found these neat autolocking hubs and installed them. Sometimes they dont stay locked while I am backing up, but that's fine because I dont have a backup camera to see where Im going (like our RV) so I just simply dont ever back up"- BigMike
82 HiLux
cha ching! i think ill do that after i put in the dual cases.  i wish i could just pull money out of my :moon:
Matty
#254
 >:D
new fender trim
body lifted bed
new rearend in without shackle mounts moved
frontend all stripped ready to be grinded
housing ready to be ground down
the backyard broken birf!
keenan welding the marlin knuckle ball gussets on
knuckle ball gussets and the AP style armor welded on.  i decided not to use the top truss because it isnt necessary
finished RUF pack
greg (4.3s10) welding some last minute stuff on the axle one night.
axle hung, front hanger tacked on new front shackles yada yada
side view
30 splines  :drool:
axle back together not sure what gregs doing in there.  painted the marlin highsteer turtle green  :turtle3:
tires finally on to see how far the axle was moved
rear crossmember welded in, and new shackle mounts welded in, with the marlin 4in springs
new shackle angle
steering box mount
box mocked up as far forward as possible
pitman arm, draglink, tierod clearances
steering box through rad support
truck sitting outside yesterday after everything.  after putting the IFS rear in we put the wheel spacers into the front.  the front springs are basically flat at ride height so i ordered bumpstops for them cause they go negative easily.  i like the new stance a lot.  wheelin next week so should have some good posers.
that looks really good..why did you lift the bed so high? is it to clear the rear tires?  :thumbs:
Matty
Quote from: DirToyBoy on July 19, 2007, 04:29:28 PM
thanks man.  yea i lifted it because if you look through the older pics you can see how close it was.  it was limiting a ton of flex.  i was on some tight time constraints because we were gonna put wheel wells in instead of body lifting it but the pucks were free and it took like 20 min to do.  the bed is at the perfect height for bump stops though.  it stops the springs as they get to full stuff. :thumbs:
tom w.
Beauty, eh. This is good motivation for me.
topar
Matty
Quote from: tom w. on July 20, 2007, 07:56:50 PM
i hope it good motivation cause my truck sat for so long then we finally got it going and tore out both suspensions got it rolling and boom a week later everything was done.
Quote from: topar on July 20, 2007, 08:00:57 PM
:thumbs: Looks good!
thanks man.  cant wait to wheel it!
tom w.
I know how that is. We spent a year on my '82, and then I only drove it for about two months. Now i'm startin' another truck.
gtoyonrocks
Nice truck, my truck wasn't anything close to what you have built at 17 years of age, that's awesome.
1985 toy, Hybrid 20r/22r on propane, 30splines, custom built leaf packs, welded front and rear diffs, dual ultimate crawler, full hydro, full exo, flat bed, 37' mtrs
WHAT THE  :thud:  I cant  believe  you  :down:
Matty
some poser pics flexin out the new suspension.
Ramrod
looks like its working great, are you bringing it back to school with you this year?
Matty
Quote from: TEAM RAMROD on July 29, 2007, 03:07:12 PM
nah man not this year.  had some stuff fall through trying to get my tow rig and trailer setup.  i am planning on getting it out there early next summer though.
Ramrod
Volcom
Yeah, you've got to get it out to CO  :greengrin:
84 4Runner
Marlin Dual Ultimate crawler
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
