My 88 pickup is back in buisness
Started by Yota4life, May 04, 2005, 09:19:51 PM
Yota4life
Today i ordered up ram/lines/and fittings for hydro assist. Also ordered up a tranny cooler from summit to run on the return line, and now i needed to get the box tapped sometime next week and extend my power steering reservoir for more capacitiy. All together its going to cost me under 180$
6.72:1
I like where this is going....
[email protected]
Cell: (205) 919-3290
www.Kupferphotography.com
got this email back from this one dude that sells steering box seals.
"The kit runs 53 and includes priority shipping.
All I need is the year, model and check sent to
John Vargus
PO Box 201195
Austin, Texas 78720
Let me know
John"
i know Toyota will charge an arm and a leg for the same kit so i think i am going to order from this guy.
Yota4life
Alright cool. I heard toyotas was like 120$, way overpriced. Sounds good im going to order that also.
toybuilt
I'm diggin the flat belly, its a great look :biggthumpup:
1983 Toyota Turned Chevy
Yota4life
It was well worth all the time spent. Got the skidplate done, a little dirty from greenhorn last sunday but here it is. Cut up the old transfercase mounts to bolt it on and basicly made it like fror. Havent tested it on any rocks yet. By the way greenhorn was pretty fun. I have never seen so many rigs in one place ever.
olivedrab85
looks sick! By the way your missing a bolt in your tcase mount.  :thumbs:
"Gotta keep it G rated for Marlin"   my runner http://board.marlincrawler.com/index.php?topic=26527.0
John Doe
Nice and simple. Good job.
Yota4life
#218
Thanks! Im missing one on both the front mounts, I put it on at night and i was in a hurry and i couldnt find the other 2 at the time.
Well again i have no pictures of me, but i took some from greenhorn.
10 minutes into it, kent testing cage
whohh im in this pic
Heres all of these plus some more http://s99.photobucket.com/albums/l287/yota4life/greenhorn/
Matty
looks like fun.  that is a lot of rigs  :shocking:
i cant stop laughing at this yota.  appears to have yota axles still and a nice  :turtle: sticker on it.    :rofl2:
Yota4life
Ya i guess he rolled his 83 and decided to swap corrola body on the 83 chassis?!?. It looks weird
Matty
interesting choice for a body swap :screwy:
its wasn't a Corrola, it was a Cressada!
boggerunner
did he use the 5 or 7mge straight 6 motor too?
i believe it was just the stock truck drivetrain.
Yota4life
Got everything in the mail. Ram, lines plus a spare, fittings, and small tranny cooler. Ready to start drilling and tapping the box. Just need the rebuild kit to come in the mail so i can finish it.
He if you haven't put the lines on the cooler yet they are a real pregnant dog to get on all the way.  i tried pushing and pulling them for awhile.  got them on barely enough for the clamp to go on.  i had the cooler already on the radiator, you might try and put the lines on before you install the cooler.  they are also really hard to get onto the resuvoir and pump fittings.
Yota4life
Thanks for the heads up on that. Im going to use some soap when i do mine. How much did you get done?
i just got the cooler attached an the lines for that ran.  i got my resevoir extened at work and i tig'd it back together.  other then that nothing, just waiting on the seal kit.
little_blue
my sammi is better!!!!!!!!!!!!!!!!!!!!
papa mike
nice  truck  i love  the flex :beer: :thumbs:
Yota4life
Quote from: little_blue on January 26, 2007, 05:05:30 PM
Now who could that be!!?!?! :)  Well see whos is better when the hammers comes around!!
did you get that thing back together yet?
Yota4life
Oh hell ya. I was in 4wheel drive going up and down my street :) I drove down to DMV and i was flexing up the light posts just to test it out. Haha i love it i could flex with just one hand on the wheel and have total control.
My first attemp to drive it i had a return hose from the tranny cooler rubbing on the pully and it cut a hole in it and i had ATF spewwing everywhere in the engine bay! I lost my steering and i though my steering box died. But it didnt
hollywood_toy90
nice truck man, i dig it
Loki
Quote from: Yota4life on January 18, 2007, 08:51:53 PM
hey yota4life...can you get me the part numbers for the tranny cooler and the size fittings needed to run hose in/out of it plus hose size or is it the same as the 3 on the right side? thanks...nice build by the way
88 turd SAS with some "stuff" under it.
MY BUILD UP THREAD
Yota4life
Loki
#238
thanks a bunch milton :gap:
**EDIT** I just ordere mine ;)
MY BUILD UP THREAD
Yota4life
Drilled, tapped and rebuilt the steering box. It all works great but there is an odd spot thats leaking on the steering box.
Ram Mounted. Should be plenty strong. Instead of just welding the tabs to the tie-rod i made a bolt on mount so if it ever needs to be adjusted it can.
I welded 2 resivoirs together for more capacity
Tranny cooler on the return mounted behind the grill on the radiator
Pump dosent make any noise so its getting enouph fluid. I noticed that when i drive it on the street i dont get any bump steer anymore. Its so nice i wish i would have done it sooner. I just need to fix the leaks now. Tested it out a little in 4wd and i have no problems turning the wheel when im up against something. Cant wait to test it on the trail.
