My 88 pickup is back in buisness
Started by Yota4life, May 04, 2005, 09:19:51 PM
Alright, i will see when we are going.
h0nke
1980 SR5 shortbed pickup (Project Rust Bucket)
We might be going up Sunday now just for the day.
Yota4life
Alright i got some more things done. Installed a Uniden 520pro CB and a a 4' Willson silverload superflex antenna on the left bed rail right behind the cab. Went and got the antenna tuned today. I mounted the CB on the cage right inbetween the seats in the middle. Ill get some pics later. Its close to my head so i can hear it really good.. Im going to get a PA speaker soon. I went out to Rubicon Express today and got 2 large flex joints for my rear shackles mounts. Im ditching the buggy leafs. I have to make the mounts for them. I got some 2x4 3/16" to make the mounts.
Yota4life
Today i finished welding my interior cage and painted it all. Id say i did pretty good using my arc welder on it. It seemed damn near impossible to weld a cage with it but i did ;)  I also drilled and welded new mounts for the seat belts so they are up at stock location now.They were really low and im too tall :gap: Some pics
Yota4life
 :bling: You can see my CB mounted on the cage. I like that spot because its close to my ear so i can hear it nice and loud. I bought a PA speaker from radioshack but i cant get it to work. Guess im just a :hammerhead: about wiring it. I tryed a few connectors and cant get it to make any noise. Guess this is a bad speaker :confused:
Yota4life
close up
MiniSimp
Are those new TSL SX's I see in the background... :greengrin:
Yota4life
Antenna mounted :yupyup:
Yes its it. Brand new, got from a friend :eyebrow:
Yota4life
#40
Keeping the doors off for the summer. Custome A/C 8)  Heres the quick release pins i set up. takes like a min a door to take of. Im still considering if i will put down the money and buy Shaffers Offroad tube doors  :eek: . I would really like to have those
Yota4life
Fixed the seats so they sit level now. They used to lean in like an inch and looked bad and wasent comfortible.
Yota4life
#42
My center console. A Fat 50.cal ammo can. Going to bolt it down and i ordered a ammo lock that locks the lid with a pad lock and makes it very hard to break into. I dont have to worry about anything being stolen with my doors off.
Yota4life
#43
Also moved my Hella Fog lights so they actually work good. They were too high up before. I like how they look here :greengrin:
My rock light pictures and install are here http://board.marlincrawler.com/index.php?topic=7821.0
b_ripper8
That thing is looking great. Good job.
In Progress: 3RZ-FE Swap Underway.
Currently: 87' 4Runner - SAS - 5.29's - welded rear - Dual 2.28 cases - Optima bluetop - round headlight conversion - FZJ80 grill - rattlecan paint job - trimmed fenders - Ranger hybrid springs front - Tacoma hybrid springs rear - schedule 160 drivelines 8" slip front - Marlin's crossmember - disk brake conversion
oddball
Im impressed, very bling :beer:
Yota4life
Maybe i should complete the bling with some fresh rattle can on the body... :suprised:  If i do it will be the last thing i do.
Next im thinking of doing an OBA set up but not sure on what compressor to buy. I want a really fast one but i know they cost a lot of $$.
The rear needs about another 1.5" of lift or so but that will be taken care of when i make the flex joint mounts. Ill post more pics when i get there
TrackVino
Yota4life
Been a while but i got some more things done. Made new rocker guards and cut off my old ones that bent because they were weak. Made all from .188 2x3 main and .188 2x2 legs.
Yota4life
Welded up
Yota4life
Fabbed mounts for Rubicon Express flex joints. Mig welded inside and out around the outside edge and smoothed out (thanks to tawneybuilt on this board for welding them) Used .188 wall 2x4, used a 2 5/8" hole saw then cut them down.
Yota4life
Inside shot
Yota4life
Out with the old
Yota4life
And in with the new....
Mounts welded to the frame 1/2" forword then where the buggys sat to make the shackle angle just right.
Yota4life
Assembled
Yota4life
Made mounts to lift the rear about 1 1/2 inches. Looks better. Going out to Prarie City tomarrow and will get some new flex shots.
decyfer
good idea with that rear mount. i'm buggy right now and its not so cool. i think i may have to do something like you've got
is it bad when you unplug the power wire from your stereo and it still plays
Yota4life
Yeah i didnt like the floppy rear end and uncontrollable unloading. Made for some really scary moments :yikes: , and the worst part the was axle wrap :shakehead:
decyfer
i get the worst axle wrap with almost 300hp.
Yota4life
#59
Went to prarie city to test them out on sunday. Wasent there long, hot like a desert out there. 8)  Going to make a trip to the con very soon....iv been wanting to go but havent had the time to do it. Here are some pics
trying to find stuff big enouph to flex on. I dont know what happened to the flex ramps :confused:
