My 88 pickup is back in buisness
Started by Yota4life, May 04, 2005, 09:19:51 PM
0 Members and 6 Guests are viewing this topic.
Yota4life
Quote from: GrenadedToy on November 14, 2007, 12:24:25 AM
man i love your truck. you do really clean work. that steering box frame brace is one of the cleanest ive seen. real nice brake set up too. props man.
hot girlfriend btw.
:biggthumpup: :beer:
haha thanks man! I let her know she got a comment on the MC board HE :)
Big Pap Dog
Definately good work!!  It looks like your body lift helped out a bit when moving that box forward (less trimming).  I can't wait to see this thing back together!
Yota4life
#422
Thanks, it will be back and running soon.
New StreetRV head with the 268 camshaft all together and ready. I had problems with header studs working there way out well i went to toyota and they have exhaust studs with a torx head on them like the knuckle studs so you can get them nice and tight. Little expensive 2.50$ each but nice and they come with sealer on the threads.
Spent a while cleaning up the top of the block real good. New gasket on
Head fully torqued down to 58 ft/lbs and valves adjusted. Engnbldr calls out .007" intake and .009" exhaust  valve lash
Some bling for the new 20hp look :)
Starting early tomarrow and going to get it running. I forget what its like to drive it!! Cant wait.
Sweet.  If you still need that timing light call me tomarrow.  i will be at the shop for some of the day making some brackets and stuff.
Yota4life
Sweet i might need it, my dad says we have one but i gotta find it. Ill give you a call.
damn... how much doe did ya spend on the head? and what not.
is it ported and polished?
Yota4life
Quote from: ImaPostHoToy85 on November 26, 2007, 10:29:21 AM
Head and cam shipped was 588$ . They got it to me a week earlier than expected, pretty fast.
All Head gaskets (toyota) 85$
Exhaust studs 20$
Its a brand new casting, strengthened in certain areas, and has larger intake and exhaust ports + over sized intake and exhaust valves. I compared the old to the new one and you could really see the ports were quite larger. Good head :)
I spent all day and got the entire motor together. Its ready to fire up but it got dark so i have to wait another day to do that when its light out. Sucks working out in the driveway.
lilbuddy
RIP Kyota.... you are the man
GET IT!!!
Quote from: LILBUDDY on November 26, 2007, 09:59:10 PM
Haha nathan got good head
i was justing laughing about that.
and sounds like youll have a nice setup.
DanS
Wow, been looking at my 4Runner rust away too long, need some inspiration and here I will find it...!
85 Toyota 4Runner, solid axle, 22Re, original paint and graphics and not a straight panel to be found!
Yota4life
No not running. Im not gonna fire it up till saturday. But in the mean while i got good head :)
lilbuddy
GET IT!!!
Yota4life
Acutally i worked on it from 10am till 8PM on monday ! ehhhh! ya and thats with no breaks! Its 100% together. I just dont want to start it up till its light outside so i can adjust crap, set timming and re torque the head bolts and readjust the valves after it warms up so ya im not as lazy as you think!
lilbuddy
Quote from: Yota4life on November 27, 2007, 07:55:38 PM
Oh good deal..
Yeah I think I take the cake for the laziness. Ive had kinda bad brakes and a wobbly front end for the last week so I finally pulled it in the garage today and  :shocking: :shocking: :shocking:
Jacked up the front end moved the pass tire side to side and it was tight, went to the driver side and it moved side to side over an inch  :shocking: Came to the conclusion (obviously) the wheel bearing was loose and yeah it was really lose and also the looseness made the rotor move side to side and pushed fluid from my brakes back into the master cyl and thats why i always had to pump em to get em to work.. Yeah its all good now :)
GET IT!!!
Yota4life
Quote from: LILBUDDY on November 27, 2007, 08:07:53 PM
Oh good deal..
wow that sounds scary. Good thing i dont have to dd mine or i could die. I used to have problems with the stupid wheel bearings because the lock nuts would work them selfs loose till i bought new nuts from marlin and now they stay nice and tight. i really hope it runs good and i get some power increase.  I still have to put the LC motor mounts in and i got my in-cab winch panel in the mail so i gotta wire that up.
lilbuddy
Quote from: Yota4life on November 27, 2007, 08:21:31 PM
Yeah its pretty sketch. Now that I have it good my runner sure is nice to drive around.
Yeah dood. Dont forget pics when you get that panel in.
GET IT!!!
Yota4life
Quote from: LILBUDDY on November 27, 2007, 08:23:18 PM
I will of course. 12voltguy does have nice panels but everything is way over priced i thought. So i found this place that had winch panels for a very reasonable price.
http://www.offroadcontrols.com/index.htm
lilbuddy
Quote from: Yota4life on November 27, 2007, 08:28:42 PM
Yeah he does have  cool panels for sure. Tat place you found had good prices for sure too.
GET IT!!!
lilbuddy
So there better be updates tomorrow...
GET IT!!!
Yota4life
O for sure!!! good night
Update:
Fired right up! Set the timming and broke in the new cam. Let it high idle for 30 minutes then i adjusted the valves again. Finally finally it runs good! Its like 3 times as quite as it was with the old head. Sounds nice and smooth and runs GREAT. Exhaust sounds a little deeper and the throttle response is better and smooth all the way up the rpms. Revs quick now. I really want to see how it will do going up highway 80 or 50. Has good low end power i noticed it just goes where before it would lug from a stop, and strong idle. Overall im very happy with it  8)
I still need to bleed the crap outa the brakes now because i didnt bench bleed the MC when i put it on.
86bobbedtoy
Sounds like your happy with it.
Sounds like its a good motor to me.
twistedtoy92
Its always the damn heads that go to :pokinit:!!!!! i'm debating on putting a stroker crank in my 22re and making it propane..... those damn short blocks last forever!!!!
Yota4life
Quote from: twistedtoy92 on December 01, 2007, 08:40:47 PM
X2 on that! Now i expect this motor to last a long time. The bottom end is fully reman. and now the top is all new. When i first got the motor put in i could tell they go cheap on the whole top end! The top end is the heart of the damn motor. I know they just pull a old head off another motor and throw it on or reuse the head from the previous motor and thats how they do it cheap.
lilbuddy
Good stuff dood. Your truck is all top notch right now, Nice.
GET IT!!!
Yota4life
Quote from: LILBUDDY on December 02, 2007, 01:19:37 PM
O im ready to go plow some snow! If we only had some!!!
lilbuddy
Quote from: Yota4life on December 02, 2007, 01:22:48 PM
yea too bad there is none. where we were last year its raining 33 degrees but no snow :(
GET IT!!!
Yota4life
Quote from: LILBUDDY on December 02, 2007, 01:27:36 PM
This is lameeeeeeeeeeee! How about a road trip???
unclejpl4x4
