Does any one have a source for a bolt on collar that goes on Marlins' tie rod so I can weld tabs for the ram.?
The hose's from Surplus Center come with ends on them, they only run about 8 bucks too.
So, how many of you would do this mod on a daily driver? Would it be to twitchy to drive on the freeway? Any thoughts as to how one might be able to turn the RAM off? Just throwing out ideas here, but could a valve be installed somewhere that would essentially stop fluid going to the RAM assist when you were driving on road. Then, just flip the switch and start crawling.This of course may not be practical or impossible... but I would appreciate feedback if anyone has any.
You would still have to fight the drag of the ram pushing fluid back and forth in the lines. I think that is how it would work at least. I don't know if I would do it on a daily driver after how mine turned out. I was not able to drill my restrictor so it is pretty slow. I have had a few hairy incidents with hitting curbs while hot rodding around corners and coming close to entering the neighbor's yard.
Why were you not able to drill out your restrictor?
Started by KYOTA General 4WD Discussion
Started by 4RnrRick Toyota Tacoma/4Runner/T100/Tundra/FJ Cruiser 1995+
Started by Rocksnail Engine
Started by crazykooter Engine
Started by axled89 Axle/Differential/Steering
