Diesel GOAT: The one I wish Toyota would have built
Started by helipilot77, May 20, 2015, 12:49:27 PM
0 Members and 21 Guests are viewing this topic.
helipilot77
Well my machinist called me today and said he has sleeved cylinder #3 and will bore the cylinders to 0.5mm and that will get the cylinders consistently smooth and cylindrical. So once the pistons are in hand he will do a final hone to perfect the oil clearance. Forward movement!  :hammer:
Still can't get over how huge that cam looks.
helipilot77
#242
Finally finished my valve shim compression tool!
When you don't have a lathe you are forced to run-what-you-brung.
I think it "turned" out pretty good, considering.
helipilot77
So $3500 for new rings and Pistons!
I think I'll have a complete engine for about 1/3 of the cost instead.
Rockcrawlintoy
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
helipilot77
Rockcrawlintoy
Almost a grand a piston seems excessive
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
zippo
You could have custom pistons made for under 1000.
If you see it, its for sale.
LittleSteve
Refusing to fit in or comply.
Easy is not worth anything.
redneckcustoms13
That is outrageous. A complete set of 6 pistons and rings any size you want for a 12v cummins is only $300. I don't see how a toyota piston could be of any greater quality to make them worth their weight in gold.
What's the plan now?
01 double cab hunting truck
06 tacoma street truck
helipilot77
Quote from: LittleSteve on April 15, 2016, 05:13:06 AM
Its $2400. But even then
I guess you're right. I did something wrong in my currency conversion.
Quote from: redneckcustoms13 on April 15, 2016, 05:54:37 AM
I think Steve working on getting a complete motor together for me and shipping it over.
redneckcustoms13
redneckcustoms13
He's definitely one hell of a fabricator. His bed for the blue truck is very cool.
And he gives you tea!
zippo
#255
Tea with mik though. As I'm from the south I drink sweet tea. Witch living in the PNW I can't get, so I drink coke. "Lots of coke"
Quote from: zippo on April 15, 2016, 10:05:09 AM
I thought a "Coke" in the south wasn't necessarily referring to the actual brand and was more of a general term?
zippo
Oh no. I don't drink Pepsi. Soda Vs Pop is the big difference I have notice. I'm still not sure what pop is?
Quote from: zippo on April 15, 2016, 11:19:43 AM
A slice of fresh lemon in a Coke is the best.
OTO Phil
Quote from: blackdiamond on April 15, 2016, 11:16:58 AM
This is true in the southwest... Also true in mexico.
SqWADoosh
helipilot77
Wow we are really having trouble staying on topic these days.
MuddyBuddy
Love the truck, awesome job!
Where did you get the factory looling triple stick shifter leather boot? Looks super clean. Im in the process of doing the same thing and want it to look like factory.
helipilot77
Quote from: MuddyBuddy on April 16, 2016, 07:22:24 AM
Thanks! I made a pattern for the boot then asked my Mom to sew one for me. I need to get a sewing machine of my own. Sqwadoosh has one that my Mom made too.
Isn't there some aftermarket supplier for these pistons?  The Israeli stuff seems pretty good.  I'm sure they had these engines down there.
Heck even scouring through books for something that would work inn a pinch.  If you haven't bored the block yet it seems like if we  could find something with the same wrist pin size and location and very close diameter you could use it.  What did the Isuzu diesel pistons look like?
Ae these pistons aluminum or something else?
helipilot77
#265
I think the new plan is to order some standard size Pistons for $250 from Milner Off-road (unfortunately they don't offer oversize Pistons) then have my machinist re-sleeve and bore all four cylinders to standard. Then I should be on my way.
toyodaaddict
Good to hear the project is back on track :smokin:
Quote from: helipilot77 on April 18, 2016, 10:16:43 AM
I think the new plan is to order some standard size Pistons for $200 from Milner Off-road (unfortunately they don't offer oversize Pistons) then have my machinist re-sleeve and bore all four cylinders to standard. Then I should be on my way.
Nice to have standard sized bore anyway.
helipilot77
zippo
At this point you almost have a  wet sleeve. Motor will last forever!
