Diesel GOAT: The one I wish Toyota would have built
Started by helipilot77, May 20, 2015, 12:49:27 PM
zippo
Any word if you can get the over sized pistons?
If you see it, its for sale.
helipilot77
Quote from: zippo on January 21, 2016, 02:05:07 PM
I'm sure the're out there somewhere but my search Haden't netted any results.
helipilot77
so Steve tore down that motor he had and found similar trouble with it. Scored cylinder walls in cylinders 3 & 4. So it seems that oversized pistons are available from Toyota in 0.50, 0.75, 1.00mm O/S. I'm going to take it to the machine shop to see what they think it will take to clean up the cylinders.
zippo
LittleSteve
Quote from: zippo on January 24, 2016, 11:18:43 AM
That sucks. I guess its a common problem?
Not really, head cracking is the issue.
But not on this one as its been done.
It ran strong when it was together.
Apart from a slight over heating issue due to cracked top tank in the rad.
Refusing to fit in or comply.
Easy is not worth anything.
helipilot77
#215
Pulled apart the head today using the spring compressor that I fashioned out of a large C clamp.
helipilot77
#216
Got the new head partially assembled today. New valves, guides, seals, springs and seats.
Ready for the buckets, shims and cam.
LittleSteve
You still have the washers to go under the head bolts?
Did u lap the valves?
helipilot77
#218
Quote from: LittleSteve on January 26, 2016, 12:42:07 AM
Yes I do still have the washers to go under the head bolts. I just put the bolts in their holes for storage. I didn't lap the valves because I checked them with Prussian blue and they were very good as they came. Those are the old glow plugs and caps in there too. I need to change them out also.
LittleSteve
Quote from: helipilot77 on January 28, 2016, 04:24:54 AM
The blue would have been my next suggestion.
helipilot77
#220
Here's the block all stripped down ready to go off to the machine shop.
And my bolt management system.
Rockcrawlintoy
Quote from: helipilot77 on February 19, 2016, 04:53:41 PM
Here is my bolt management seystem.
Looks better than mine lol. An old coffee can lol
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
What did you do, take a pic, blow it up, and print it, what a smart idea :clap2:
zippo
helipilot77
Quote from: ovrarok on February 19, 2016, 06:08:44 PM
Haha! Yep that's exactly what I did.
Quote from: zippo on February 19, 2016, 06:14:11 PM
Did you get the pistons?
No I have to find how much material they will have to remove before I order them.
HogCanyonHopper
helipilot77
So they are doing a rough bore right now to get rid of any pits. Then he will tell me where the cylinders are at. I'll then order the Pistons and once he has them in-hand, he will do a finish bore with proper oil clearances. They are also going to deck and hot tank it.
Quote from: helipilot77 on February 26, 2016, 09:58:15 PM
nice, hopefully it will be ready for summer wheeling
helipilot77
#228
Building an SST for setting my valve lifter shims while the motor is at the machine shop.
helipilot77
I heard from the machine shop today. Cylinder number 3 is beyond what the maximum oversized Pistons could cover. He said normally he would just sleeve it and be done with it but his tool for sleeving is broken and he thought it would be fixed and back to him a month ago. So I need to find a machine shop nearby that will sleeve cylinders.   :bricks:
minor setback  :wink2: how did your sst tool come out  :dunno:
zippo
Quote from: helipilot77 on March 09, 2016, 08:03:18 PM
I would ask him who he would recomend! Finding another shop can be hard!
helipilot77
Quote from: zippo on March 09, 2016, 08:17:14 PM
I did but he said he didn't know of anyone else in the area who does sleeving. I may have found a place, but it is just an Internet search result with decent reviews.
redneckcustoms13
Look for tractor service shops. Most all tractor engine shops can re sleeve. Also big truck shops like peterbilt and international might be able to help you in the right direction.
01 double cab hunting truck
06 tacoma street truck
helipilot77
Quote from: redneckcustoms13 on March 10, 2016, 11:06:00 AM
I saw that there was a marine place that does it.
LittleSteve
helipilot77
LittleSteve
Quote from: helipilot77 on March 11, 2016, 02:33:26 PM
Thanks Dave but Spokane is kind of far for me to go. Zippo found me a local place I'm going to try.
:ha_ha:
Whats so funny? Its the future...
helipilot77
Quote from: LittleSteve on March 11, 2016, 02:55:18 PM
Oh I know, after what I have already spent on the KZ. I can't afford to switch to KD at this point. But I would love the more efficient, newer motor and the variable geometry turbo.
