I do have a set....
Message me with what you have and what you might want for them.
Really? Cause I could honestly use new shocks in the front too.
He defected to Rancho.
Needs either a receiver or a tow bracket of some description........
fitted them dampers yet?
No but I pulled one out of storage to measure. Gonna have to built new towers.
In an attempt to fix the oil leak I made it worse. When installing the new sensor I cross threaded it into the port. Looks like I’ll be pulling it back off, welding up the port re-drilling and tapping the threads then installing everything back on the motor. Meanwhile the whole intake side of the motor is being coated in nasty black oil.
It’s cast aluminum though.
being covered in black shitty oil is about standard for a kz...if you get bored i think i have that part laying around. or did i throw it in the scrap with that block i had
Thats probably worse but not in the realms of impossible.If it was cast iron i would braze it not weld it.Either way it can be done...
I wouldn't weld on the cast. Drill it out to the next NTP size and run a reducer. Welding cast sucks, welding it after that much oil saturation would be difficult also.
I’ll try to find the alternator rebuild parts sight I found a while back. I was looking at swapping my alternator out for a hiace since the vans came with 110amp units.
Back to the hi amperage alternator search. I found that the big stereo guys like to use Denso “hairpin” alternators because they produce big amps at idle speeds. I found a 150 amp hairpin Denso alternator intended for a John Deere tractor that appears to be bolt-on. It even uses the same plug. I would just need to swap my pulley. Hopefully the double V-belt would have enough grip to turn it. $200 at Amazon means it’s worth a try and replacements would be simpler than the unavailable setup I’ve got. https://www.rareelectrical.com/i-26878565-new-12v-150-amp-alternator-fits-john-deere-tractor-104210-3920-104210-3921-1042103921.html
JB Weld? You can drill and tap that stuff.
Started by twistedtoy92 « 1 2 » Rig Gallery
Started by Yotaman80 « 1 2 3 » Project Research and Build-Ups
Started by JohnHalladay General 4WD Discussion
Started by Halladay General 4WD Discussion
Started by FjordWarrden Project Research and Build-Ups
