Diesel GOAT: The one I wish Toyota would have built
Started by helipilot77, May 20, 2015, 12:49:27 PM
helipilot77
Quote from: mudmaster on August 28, 2019, 06:04:58 AM
I do have a set....
Message me with what you have and what you might want for them.
LittleSteve
Quote from: helipilot77 on August 28, 2019, 12:14:06 PM
the ones i have are like, free.
Refusing to fit in or comply.
Easy is not worth anything.
Quote from: helipilot77 on August 27, 2019, 09:52:19 PM
Really? Cause I could honestly use new shocks in the front too.
He defected to Rancho.
LittleSteve
mudmaster
Time to go wheelin!
helipilot77
#635
New baby girl in the house so I haven't been doing much on the runner. I did do a little work toward getting some gauges for the gauge pod on the A pillar. Top gauge is EGT, middle gauge is boost, and bottom gauge is water temp.
LittleSteve
Needs either a receiver or a tow bracket of some description........
Prismo
helipilot77
Quote from: LittleSteve on September 28, 2019, 11:02:20 AM
Been having some issues with the fuel line loosing prime and getting air bubbles in it. I installed a new genuine Toyota fuel filter head. I also have a new injector return pipe to install cause the #1 injector is leaking at the return line. It got twisted when tightening the injector nut. LittleSteve is helping diagnose the fuel system. I need to try to pull vacuum with the Mityvac and see what happens.
Atlcr
Great build and excellent write up. Congrats on the new baby girl.
helipilot77
Tonight I put the awning up out in the street so I could get some repairs done in the rain. The fuel injection return pipe was the number one thing that needed to get replaced. The leak was getting to a pretty embarrassing point. I think I got it all fixed. Hopefully it's leak free now and I can clean up the mess in the street where I have been parking.
LittleSteve
helipilot77
Quote from: LittleSteve on October 21, 2019, 12:32:01 PM
fitted them dampers yet?
No but I pulled one out of storage to measure. Gonna have to built new towers.
LittleSteve
Quote from: helipilot77 on October 21, 2019, 01:47:46 PM
think of the travel....
helipilot77
now that the fuel leak is fixed, it made it clear that I also had an oil leak. Fortunately it is an easy fix. when Zippo helped me start it up for the first time the oil pressure gauge wasn't working. We installed a cheap Autozone oil pressure gauge to make sure that we had good oil pressure. The oil pressure port is where the leak is coming from. I have a new sending unit to install in the port to seal up the leak.
helipilot77
In an attempt to fix the oil leak I made it worse. When installing the new sensor I cross threaded it into the port. Looks like I'll be pulling it back off, welding up the port re-drilling and tapping the threads then installing everything back on the motor. Meanwhile the whole intake side of the motor is being coated in nasty black oil.  :smack:
LittleSteve
Quote from: helipilot77 on October 28, 2019, 09:03:41 AM
being covered in black shitty oil is about standard for a kz...
if you get bored i think i have that part laying around. or did i throw it in the scrap with that block i had :dunno:
zippo
I wouldn't weld on the cast. Drill it out to the next NTP size and run a reducer. Welding cast sucks, welding it after that much oil saturation would be difficult also.
If you see it, its for sale.
helipilot77
LittleSteve
Quote from: helipilot77 on October 28, 2019, 02:26:35 PM
It's cast aluminum though.
Thats probably worse but not in the realms of impossible.
If it was cast iron i would braze it not weld it.
Either way it can be done...
helipilot77
#650
Quote from: LittleSteve on October 28, 2019, 01:54:30 PM
I would prefer a unrepaired one if you can find it and get it on its way quick.
Quote from: LittleSteve on October 28, 2019, 02:46:12 PM
it can't hurt to try to fix it.
Rockcrawlintoy
Quote from: zippo on October 28, 2019, 02:12:10 PM
Agreed you are asking for failure trying to weld it. You are never going to get it clean enough and welding cast aluminum sucks under the best circumstances.
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
helipilot77
You're probably right. It does seem like the most straightforward fix. Zippo has never steered me wrong.
helipilot77
helipilot77
#654
Quote from: RB on February 26, 2018, 12:28:14 PM
I'll try to find the alternator rebuild parts sight I found a while back. I was looking at swapping my alternator out for a hiace since the vans came with 110amp units.
Back to the hi amperage alternator search. I found that the big stereo guys like to use Denso "hairpin" alternators because they produce big amps at idle speeds. I found a 150 amp hairpin Denso alternator intended for a John Deere tractor that appears to be bolt-on. It even uses the same plug. I would just need to swap my pulley. Hopefully the double V-belt would have enough grip to turn it. $200 at Amazon means it's worth a try and replacements would be simpler than the unavailable setup I've got.
https://www.rareelectrical.com/i-26878565-new-12v-150-amp-alternator-fits-john-deere-tractor-104210-3920-104210-3921-1042103921.html
Rockcrawlintoy
Quote from: helipilot77 on October 29, 2019, 02:52:58 PM
I have a 160 amp denso on the JK the diesel version has a 210 amp and i am sure it makes it at a lower rpm than mine.
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
:)bestgen4runner
I am 1/5th of Perfect Fit
Rockcrawlintoy
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
mudmaster
Time to go wheelin!
redneckcustoms13
Devcon is also an option. Basically job weld on steroids. We use it on hardened shafts and turn it down and polish on a lathe for sealing surfaces. The stuff is amazingly durable.
01 double cab hunting truck
06 tacoma street truck
