There's a machine shop few blocks away. But don't I need macrometers and bore gauge and other precision instruments to build it myselft? I have those (3/8 &1/2) Snap On Torque Wrenches and feeler gauge set.
Well it's nice to plasti-guage the rod and main journals before you do a final assembly but the machine shop can measure everything and put it to spec and tell you what bearings and pistons to order to fit whatever they did. Plasti-guage is like $2.00. Pick up a tube of engine assembly lube. A cheap engine stand is nice to have. You might need a piston ring compressor to get the pistons back in and maybe a set of those special pliers to install the rings on the pistons. Other than that if you have the torque wrenches you are good. I just assembled a bottom end with my 9 and 12 year old and they were both almost disappointed at how simple it was. We are building a 22r in or dining room.Not everybody likes to do engine work but it's honestly harder to get all the stuff off the engine than it is to reassemble the real meat of the engine.
I plan on rebuilding a 22RE. Just need to get a good spare block. Bleakhorizon on here lives nearby and he is willing to help me.
Hi guys. Nick from 209Toyota1 here. We do ALL of our own machine work in house, we have lots of parts in stock aftermarket and OEM. We usually have 22re's in stock, good ones! We do lots of custom builds, anything you need. port work, oversize stainless valves, ARP head and rod studs, OEM gaskets, cometic, MLS, cam gears, dual row conversions and lots more. We build great engines and WE STAND BEHIND EM!! We also build 2rz 3rz 3vz 5vz. We at 1230 11th st. In downtown Modesto. Come by anytime. We're working on our website everyday trying to get everything on there, if you need something and don't see it call us we might have it. We're not drop shippers just trying to turn a dollar, if it's on our web site then we have it! If you need machine work done we will gladly do it for you. Call us anytime. Phone number is 209-toyota1 See ya on the trail!!!!
Started by CableDawg Toyota Tacoma/4Runner/T100/Tundra/FJ Cruiser 1995+
Started by RustyToy Project Research and Build-Ups
Started by Zoomschwortz Toyota Pickup/4Runner Tech 1979-95
Started by crawlerdan « 1 2 3 » Project Research and Build-Ups
Started by Keithporter83 Axle/Differential/Steering
