you could either fix the runner with the front clip from your truck or you could part the runner out, the R150 could be bolted to your 22RE IF you have a R151 turbo tranny bellhousing, but they are hard to find
either way the parts are worth some
Thank you for the reply.
As far as his truck goes, it has a pretty bad kink in the right front frame.
It sounds like he has sold the engine, tires and wheels for $2000
(about 150,000 on the engine, nice wheels and year old tires with alot of wear from alignment problems.
Do you know if the front R&P on a 92 V-6 truck is the same diameter as used on an 89?
I was supprised to find that the gear ratio (per the vin) is 4.30 . This truck is a 5 speed and I thought that 4.30 came on trucks with automatics.
Will the rear springs and rear end from a 92 fit on an 89?
Thanks again.
Ken
