SqWADoosh's 85 Runner Build Thread
Started by SqWADoosh, December 03, 2014, 12:07:54 PM
SqWADoosh
Quote from: daniresch on April 14, 2016, 06:15:17 PM
Hope its not that trans you just took a chunk out of lol :gap:
where is the noise coming from?
Hard to tell. Sounds like its front axle area.
BigBluePile
Dang man, if it's not one thing it's another lol
Sent from my 0PJA2 using Tapatalk
'86 4Runner SR5 TRD 5VZ-FE
...slightly modified from OEM...
SqWADoosh
Quote from: BigBluePile on April 14, 2016, 07:37:46 PM
Tell me about it.  :thumbdown:
Rockcrawlintoy
How old was that gear oil in the trans?
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
SqWADoosh
Quote from: RockcrawlinJK on April 14, 2016, 07:45:26 PM
Put it in when I put the trans in last March. So a little over a year old.
Quote from: SqWADoosh on April 14, 2016, 07:52:14 PM
What is the history of the transmission?
A coworker of mine thought the chunk looked like the end of a shift fork. Mostly a guess for sure.
Rockcrawlintoy
Seems pretty dark for a year. Mike changed my old trans and he said it looks good still just super smelly after 15 years
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
jangelfire
Quote from: SqWADoosh on April 14, 2016, 06:42:10 PM
I'm always thinking I hear new noises after I work on my rig.its the perfectionist in us that makes these noises.run it like you stole it, if it breaks it needed fixed anyways.my 2cents
OTO Phil
Try it in 4hi, then 4low... See if it sounds the same...
SqWADoosh
Quote from: RockcrawlinJK on April 14, 2016, 08:25:50 PM
The color of the fluid is very likely due to the fact that I put in some cheap fluid for a week after first installing the trans. Reason I did this was it had been sitting for a while and the fluid inside of it was pretty gnarly. So I ran that cheap fluid for a week then put in MT-90. The color is likely due to this.
Quote from: emsvitil on April 14, 2016, 08:29:21 PM
Is the steering box quiet?
Steering box seems to be doing great. Don't think it is that. Besides the noise happens when holding steady and straight and goes away with clutch in so I'm confident that it is not the box.
Quote from: jangelfire on April 14, 2016, 08:32:36 PM
I'm definitely not hearing things. It is very prominent.
Why would doing a flush lead to dark fluid color now?  I am not following.
Quote from: blackdiamond on April 15, 2016, 10:58:40 AM
Maybe your flush just wasn't long enough to clean it up entirely.  Synthetics have natural detergent properties (partly why synthetic engine oil lasts longer) so the Redline MT90 is going to do some "cleaning" if given the opportunity.
1985CRAWLER
Who's to say it's the trans ? If it shifts perfect like you say I'm betting the noise is from somewhere else In the drivetrain , when my rear diff was going out it sounded like my trans/cases were gonna grenande , wasn't them at all lol , if it does everything you need it too and no major clanks or popping , run it ! Hell I ran the majority of fordyce when I lost 1st gear , 2nd gear was fun , just ask drew lol
OTO Phil
That's why I'm saying test it in 4hi, then 4low... If the sound goes away, or gets quieter, you've found it.
SqWADoosh
Quote from: liveoak on April 15, 2016, 12:05:57 PM
you didn't get a work party warranty?  :hammer: it's a new noise so don't you think is was caused during recent "upgrades"?  is it recordable so we can hear it?
you say it sounds like the front end. wheel bearings? hub not unlocking?..................They rent jeeps in moab you know  :D
I'm going to tear into it this weekend and see what I can figure out. As far the last part....eat me.  :snare:
you say it sounds like the front end. wheel bearings? hub not unlocking?.................. They rent jeeps in moab you know  :D
We had a group of really nice Jeeps pass us while doing Sevenmile Rim on the last trip.  We identified one to be a rental 4-door JK and I would have been happy to wheel that thing.  It was really well setup and was something like $300 per day which would add up, but for a day or two on a vacation wouldn't be a bad way to go.
SqWADoosh
Quote from: blackdiamond on April 15, 2016, 03:22:56 PM
I'm not that desperate to run Moab that I would do it in a rental. Taking my truck and running what I brung is a big part of it for me.
SqWADoosh
Starting to think the noise I'm hearing is the pads on the rotors. Wondering if they just need to break in enough to where it isn't doing that. I jacked each tire up and spun the tires and all I heard was the rotors on the pads. It did sound like a quieter version of the sound I am hearing. I spun them as fast as I could and it got a little louder.
When you're getting the noise, apply light pressure to the brakes and see if the noise changes.
zippo
They shouldn't touch and make noise unless you are applying the brake. Unless your spindle nut is loose. check your spindle nut.
If you see it, its for sale.
Quote from: SqWADoosh on April 15, 2016, 04:13:52 PM
I wasn't suggesting that you do this. Definitely "run what you brung" for sure. I have considered what I might do with a rental JK because it would be so much easier to just drive the Sequoia down and grab a rental for a couple of days. The one we saw was setup well enough that I'd probably do pretty much everything but Pritchett and White Knuckle.
OTO Phil
SqWADoosh
zippo
With new pads you should bed them. Drive 25 35 mph stop medium pressure. Do that again at 45. Then from about 55 stop as hard as you can.
OTO Phil
To bed the pads, make 10 stops from approximately 35 mph with moderate pressure. Then make two to three hard stops from 45 mph. After this, allow the brakes to cool completely, and you're all set.
OTO Phil
zippo
But if you didn't do it when they were new it's no point now. A s that wouldn't cause any noise unless you pressed the brake.
Quote from: zippo on April 15, 2016, 11:53:03 PM
This sounds pretty much what my coworker does to "condition" his brakes on his car before hitting the track.
redneckcustoms13
What pads are you running? Did you happen to install them with the chirpers facing the wrong direction?
01 double cab hunting truck
06 tacoma street truck
