SqWADoosh's 85 Runner Build Thread
Started by SqWADoosh, December 03, 2014, 12:07:54 PM
0 Members and 6 Guests are viewing this topic.
jangelfire
Quote from: mudmaster on June 07, 2016, 11:40:29 AM
I don't like exos. That being said, it also isn't my rig.
Wheeling with an exo is awesome! It lowers stress levels and allows you to do things you normally wouldnt do when body damage it a concern.im really glad i went exo
mdtrail-toy
Quote from: jangelfire on June 07, 2016, 05:07:39 PM
Jangelfire, saw a few pictures of your exo . Came out great  :thumbs: If you were to go with the glass bedsides I think something over that sweet new bed would be a must. Think worrying about body damage with sheet metal is tough I could only imagine the stress of a tight spot with glass :nerv:
SqWADoosh
Quote from: mdtrail-toy on June 07, 2016, 07:29:09 PM
Exactly.
EASYRYDERDANGER
Quote from: :)bestgen4runner on June 07, 2016, 04:48:00 PM
:bat: :bat: :bat: :bat:
Can't wait to go to work tomorrow.
:horseride: That's me riding a wild stallion.
Ive told you before, if you close that gate ill hop the fence and you will never see me again!
redneckcustoms13
My 85 runner had an exo. It was a good comfort knowing that when I flopped it wasn't going to have the roof hitting me in the head.
01 double cab hunting truck
06 tacoma street truck
H8PVMNT
Regarding weight and fiberglass:  The only experience I have was a set of Fenders on an '86 truck I had.  The fiberglass was definitely heavier than the steel.
Still I don't think you would be adding much weight compared to all the other crap we stick to these things.
– Steve McQueen
SqWADoosh
Quote from: H8PVMNT on June 08, 2016, 07:33:42 AM
That is interesting to hear that the glass is actually heavier. I guess I incorrectly assumed it would be lighter.
blackdiamond
Quote from: SqWADoosh on June 08, 2016, 10:10:26 AM
I am surprised as well.  I didn't expect much of a weight reduction simply because Toyota sheet metal is pretty thin, but I didn't figure that it would be heavier.
H8PVMNT
#1328
I would expect something with structure and webbing to it like hood to be lighter in fiberglass, but yeah, I was surprised too on the fenders.  These were Hannemann fenders.  The material was kind of thicker than you would expect too.  I would be curious to see how bedsides were compared to the stock skin.
– Steve McQueen
mdtrail-toy
Have you asked Slacker if he has ever done any weight comparison's on any parts? Fender to fender , hood to hood. Guess it's probably a popular question right now.  Would be interesting to know
SqWADoosh
Quote from: mdtrail-toy on June 09, 2016, 06:36:13 PM
I'm not worried about it. Its negligible.
Dingman.
SqWADoosh
Well 3rd time is the charm....almost. Put in another tapped IFS box this weekend. It is a no leaker however my steering is overly tight now. I attempted to adjust the box with the adjustment screw on the top however I could not get the screw and the locking nut to turn independently of one another. Going to soak them with some penetrating oil over the next couple days and give it another go.
OTO Phil
Kano aerokroil is the best penetrating oil I've ever used... but could it be cause by an over tightened link?
Sent from my LG-H830 using Tapatalk
SqWADoosh
Quote from: excabswap on June 19, 2016, 05:26:08 PM
What do you mean an over tightened link? Yeah kroil is what we use at work too. Can't beat it.
OTO Phil
I couldn't remember if you'd recently done anything to your axle, but what i meant was the bearing preload on your knuckles.. no idea why I said link
:)bestgen4runner
It's just the new box most likely.
Drive it for a while some times they need to break in.
I am 1/5th of Perfect Fit
Mudder
Did you double check the fluid level after running it and turning the steering wheel back and forth?
SqWADoosh
Quote from: Mudder on June 19, 2016, 07:31:05 PM
Yes I did a standard bleed procedure and burped it. Wheels on jack stands. Turned left and right with key in accessory until air stopped coming through. Then fired it and did the same.
SqWADoosh
Quote from: :)bestgen4runner on June 19, 2016, 07:03:08 PM
It isn't a new box is the thing. Though it could be a rebuilt one. Would it being rebuilt do that as well?
OTO Phil
If the box was rebuilt, the guts may have been swapped from a different box.. meaning different tolerances possibly
SqWADoosh
Hit Naches with the club this weekend. Got some redemption on the line I flopped on last year. Was a great trip overall. Had the opportunity to take two first timers to the area up with me. They both had a fantastic time and can't wait to go back.
Notice the line of Jeeps in the back doing nothing but watching. Same thing every time we go up there.  :rofl2:
OTO Phil
Lol they're watching with jaws dropped because they dropped 50k on their rigs and don't know how to drive them like you do.
Great job, saw your posts on ig
SqWADoosh
Quote from: excabswap on June 26, 2016, 04:41:31 PM
Best part was they all had stickers on their Jeeps that said "Watch This 4x4" apparently that means they watch other 4x4s.  :yupyup:
blackdiamond
Quote from: SqWADoosh on June 27, 2016, 06:56:51 AM
Someone should point out that there's a white 4Runner in the lineup.  Did anyone go rescue it?
blackdiamond
I would assume that the addition of the dual cases changed the dynamic on the "flop" line significantly?  I'm thinking that you didn't have duals on that trip?
SqWADoosh
Quote from: blackdiamond on June 27, 2016, 11:22:34 AM
Yes
SqWADoosh
havik
Damn i just rear your whole build/ story. Great rig great times
iam still building mine and getting to the point that i am almost "done" but still feel like i will never be done.
got another 85 runner. build coming soon!!
SqWADoosh
Quote from: havik on July 11, 2016, 03:51:12 PM
Thanks!  :thumbs:
