0 Members and 28 Guests are viewing this topic.
I was trying to find a specific spot on the video, but couldn't recognize anything in my bounce around attempt. There was a fun spot just down from a switchback that wasn't too far before the bridge into Rubicon springs
It sounds like your thinking of big sluice? That is on part II around 2:14:00 which is where we met Sky and his crew from Oregon coming up the opposite direction and had to shuffle around each other. Always fun to meet a legend on the trail.
Idk, mine idles at about 450 rpm for the first few minutes when cold. My iac was froze up when I got it, I at replied to clean and free it up. I don't believe I did any good at it because it isn't fix anything.
Are you sure it isn't stuck?
did you try taking a 12 point socket slightly smaller then head on bolt, tapping it on
Homedepot or lowes sells a stripped screw extractor. Using a drill it cuts a hole flip the bit over unscrew it. You can also buy new iac valves. They run about 200$
so was the tb cleaner the wrong stuff, is it labeled in small print some where don't use for iac
pics or i dont believe you
im just fawkin with ya! cool you got the motor and exhaust all fixed, whats next on the list for this turd mobile?
Glad you got it worked out. Just ordered my first 38.......
as in 38" tire?
Why is it that almost every rig I see on here guys are running the drop pitman arms? I have always asked for a flat arm when I order high steer kits because I don't want the spring to whack it on up travel. I realize for a taller rig a drop arm helps with steering geometry, but on lower rigs what's the deal with it?
Twice I've gotten sent a drop, I call and complain until I get the flat one that I asked for lol. I also had the tre in there when I mounted the ifs box kit so I could be sure it cleared the frame. It's about 1/2" of clearance. You should be fine with the 3/4 drop I'd imagine, your teuck is kind of tall so when you toss 37s on it you'll be extending bump stops I'm sure anyway
My truck isn't tall. 26" from frame to ground. Also ill be retracting bump stops to gain up travel. They are set incredibly low right now. There is pictures of them earlier in the build.
Started by trax28to Project Research and Build-Ups
Started by Dingman. « 1 2 ... 58 59 » Project Research and Build-Ups
Started by Yoat Goat General 4WD Discussion
Started by Cheesemaker Chit Chat Camp
