1k$ Ebay Find
Started by alwayzbroken, March 22, 2005, 08:42:19 PM
gotrocks
if your shackle is laying back to far it will over stress your springs and cause premature failure.  The hole point of the shackle is to allow the spring to stretch out.  If you aren't allowing it to stretch out properly if will cause the spring to find other ways to stretch (ie. S'ing of the spring). Thats why on long travel springs you sometimes need to put longer shackles on, because the spring has more arch and therefor requires a greater distance to flex out.
Hope that makes sense I'll explain it better if it didn't.
alwayzbroken
That makes sense. I don't know what else I can do though. I have Sky shackles that are a couple inches longer already. Have you heard of people using even longer shackles?
Quote from: alwayzbroken on February 27, 2008, 11:26:19 AM
move your spring hangar forward? :dunno:
gotrocks
Yeah you could use longer shackles but what you'll end up doing is just making your caster further and further off.  I'd do what DTB said.  I know it sucks but thats the proper fix.
alwayzbroken
Quote from: gotrocks on February 27, 2008, 11:48:39 AM
Unfortunately, not an option. Look at the top post on page 2 then consider that plate is what my bumper and winch mount is secured to. I would have to redo the whole bumper and spend a lot of time cutting, and grinding to get the plates off the front and back of the hanger.
gotrocks
ok well the other option is to move the rear shackle frame point further back.  OR run a shorter spring.  Other wise you will screw up another set of springs.  Not trying to rain on your parade just telling you the facts.
alwayzbroken
Quote from: gotrocks on February 27, 2008, 12:43:59 PM
Yeah, those are pretty much my only options. Are Toyota rears shorter? How much longer than stock fronts are they?
gotrocks
Toyota Leaf Springs
                                           Flat length  Front Half   Rear Half   Width   SOA / SUA
80-85 Toyota front                      45"          22.5"        22.5"       2.36"        SOA
80-85 Rancho 3" Toyota front     45.12"       22.56"      22.56"      2.36"        SOA
SkyJacker 5" Toyota front            46"            23"           23"        2.36"       SOA
80-88 Toy rear                           48"           20.5"        27.5"      2.36"        SOA
80-88 4" SkyJacker Rear              49"            21"           28"        2.36"       SOA
80-88 5" SkyJacker Rear              49.5"       21.25"      28.25"      2.36"        SOA
89-95 Toy Rear                          51"          21.5"        29.5"       2.36"        SOA
Marlins website for the front springs are supposed to be 1.5" longer than stock.
TG says there springs are 47" total length eye to eye.
Hope that helps.
So you should be able to build a custom pack with a stock rear main then whatever you want from there.
I've built a couple that I used 2 sets of rear springs like this
-1. Stock main
-2. Stock main with ears cut off
-3. Stock 2nd leaf
-4. Stock 3rd
-5. Stock 3rd cut down
-6. Stock 4th
-7. Stock 5th or a 4th cut down.
haha I just saw your mug in an old toyota 4wd owners magazine........ :haha: on the back page....the one with the sleepy truck  :laugh:
alwayzbroken
Quote from: DirToyBoy on March 05, 2008, 07:14:15 AM
Yeah that was me all right. I was just cruising and joking with my buddy in the passenger seat while not paying real close attention to where I was driving and flopped over. Of all the cool things I have made it through, the time I get in a magazine is when I am doing the most lame thing ever.
Quote from: alwayzbroken on March 05, 2008, 07:27:42 AM
yea, i could totally tell you werent paying attention! The look on your face says it all hahaha.....
alwayzbroken
Here is the page from last April or May of 4wd Toyota Owner
Ramrod
check to see if your shackle is bottoming out on your body mount
alwayzbroken
Quote from: TEAM RAMROD on March 05, 2008, 11:15:30 AM
Will do. I am tearing it apart tonight.
Gittinit
Where was that flop pic taken Cole?
my favorite places:
http://www.flatnasty.net/
http://www.orvpark.com/
alwayzbroken
I pulled the axle apart tonight and fortunately the only thing broken was the ring and pinion. The Longfields didn't have a scratch on them. I thought the welded diff exploded and took out the ring gear but the welded diff held up just fine. The ring gear is probably missing 25 teeth and there is a big chunk out of the pinion as well.  The high pinion was a dealer take out item that only had 33K on it when I got it which kinda surprises me that it broke before anything in the t-case or even my welded 4.10 4cylinder diff in the back. The more I think about it I think it was just the conditions of the hill rather than accumulated abuse.
Quote from: Gittinit on March 05, 2008, 06:26:49 PM
South of Des Moines in Knoxville Iowa.
Quote from: alwayzbroken on March 05, 2008, 08:33:18 PM
of course we wanna see carnage pics
alwayzbroken
It doesn't look like it bottomed out hard if it did. There aren't big dents or anything.
alwayzbroken
Here are the springs before I changed them. Keep in mind that was a 5" spring. There used to be 7" of shaft showing on the shock at ride height when installed. The new springs are in but I don't have pictures yet.
Jud
Damn now I know what springs not to buy.
"bout tree fiddy"
you didnt pull any leaves from that pack?
alwayzbroken
Quote from: DirToyBoy on March 10, 2008, 05:04:56 AM
Nope. I ran them unaltered.
alwayzbroken
Here are the new 5" TG springs installed compared to what it looked like with the old set of 5" TG springs. They sagged a little.
alwayzbroken
Before and After
alwayzbroken
Cracked the transfer case :dunno: It is cracked all the way through and there is another crack where the big gear sits.
Gittinit
I have that section of a tcse left from building my crawlbox. If you want it let me know, couse its yours! Did this happen becouse of your driveline bottoming out or did you bellie out hard on the crosmember or?
my favorite places:
alwayzbroken
Quote from: Gittinit on May 19, 2008, 07:33:11 PM
Thanks but it is all fixed up already. I don't know when it happened. I had the cases out and was suprised to see they were cracked.
alwayzbroken
My friend cracked his toyota t-case as well :greengrin:
