1k$ Ebay Find
Started by alwayzbroken, March 22, 2005, 08:42:19 PM
DTB
Quote from: alwayzbroken on December 17, 2006, 06:25:10 PM
It is gonna come in handy. You guys are gonna hate it in the campground. I promise
please tell me your not bringing a gas generator too? :eek:
alwayzbroken
Quote from: Dirt Toy Boy on December 17, 2006, 06:28:22 PM
Yep. That ain't even scratching the surface of what we are bringing  :laugh:
DTB
Quote from: alwayzbroken on December 17, 2006, 06:40:08 PM
oh god.....yea im definitely sleeping on the other side of the campground from you! :aaa:
alwayzbroken
Quote from: Dirt Toy Boy on December 17, 2006, 06:43:02 PM
That is entirely the wrong attitude :shake:
alwayzbroken
The winch cable showed up today. Masterpull 5/16" x 100' 14,500lb rating and weighs less than 4 lbs even with the stainless steel thimble.
sam2145871
"If it ain't broke....you aren't driving hard enough!"
"She'll Buff Out"
alwayzbroken
I busted the leaking bead down today and found the tire and bead perfectly clean in the spot the leak was coming from. Upon closer inspection I found a irregularity in the wheel that is allowing air to rush out. I applied a coat of bead sealer to the tire and rim but it has only slowed the leak. I'm sure that ain't gonna hold either when I air down for the trail. It does not look like the wheel can be repaired either which really makes me angry since I welded the inner ring on already. I would think twice about buying the cheap Crager wheels. I thought the workmanship looked sloppy on them since I opened the box. I guess you get what you pay for at 45$ per wheel.
alwayzbroken
Damage report
1 Caliper
1 Brake Hose
2 IFS hubs with sheared dowels and studs
Here is one of the broken hubs. The second had all the studs and both dowels busted clean off.
alwayzbroken
Here is the fixed version
alwayzbroken
Those dust caps are a real SOB to get on. I got frustrated and got a bigger hammer.
Gittinit
6 arp studs and six more 5/16 dowl pins, and drive flanges= :drooling:
Without the weak link at the outers, what will go next? That is one strong setup. If you were running a lower than stock gearset I would be worried about the r&p but with the 4.10s it should be almost unbreakable.  :wave:
my favorite places:
http://www.flatnasty.net/
http://www.orvpark.com/
DTB
Quote from: gittinit on March 15, 2007, 07:41:56 PM
hmmm maybe he can change his name from alwayzbroken to "neverbroken" ?? probably not lol
what drive flanges are those?  that is a slick setup!
alwayzbroken
Quote from: DirToyBoy on March 15, 2007, 07:45:57 PM
The drive flange will strip next I think.
Hey hey hey look what I still have  :sly:
alwayzbroken
Quote from: Hyena on March 15, 2007, 07:49:22 PM
They are the Marlin flanges. I was gonna do the 6 pin instead of the Arp studs to save money but I wasn't thinking and ordered the hub studs when I ordered my knuckle studs. I got the box from FROR and was confused why I had hub studs until I remembered ordering them for some damn reason. Oh well I have both. I didn't want to spend the 140$ on hub gears when I could get drive flanges and take care of two birds with one stone.
Gittinit
You are probably stronger with the flanges than with the hub gears. Do you really think they will strip? Bobby won't warrenty if marlins flanges strip out the longs will he?
my favorite places:
alwayzbroken
Quote from: gittinit on March 15, 2007, 08:06:17 PM
He said the drive flanges are softer than the birfield splines so stripped splines should not happen were his words when I talked to him. I think his hub gears are probably stronger. But how strong is really necessary? If the drive flanges can break, I am sure I will find out.
Max Heintz
Those beadlocks look sweet cole, How are those johnny joints working??
alwayzbroken
Quote from: Max Heintz on March 17, 2007, 12:54:21 PM
Thanks, they look better in person. I have made one run with the johnny joints but I don't really have an opinion yet. They seem to be working pretty well.
6.72:1
Everything is looking very sturdy there Sir!
[email protected]
Cell: (205) 919-3290
www.Kupferphotography.com
Max Heintz
did you guys ever go check that axle out?
alwayzbroken
Quote from: Max Heintz on March 18, 2007, 03:09:03 PM
No. Not yet. Are you sure it isn't a suzuki axle. They look pretty much identical except for the width.
Max Heintz
i'm not sure, i wasn't there my buddy just called me up and said that it was toyota. But most of the time he is pretty out of it
alwayzbroken
Quote from: Max Heintz on March 18, 2007, 05:51:35 PM
I am pretty sure that sammy was there last time and they knew about it. If you look at it, it isn't too hard to tell that there is a toyota axle in it so I am pretty sure they know. But I will check it out.
Max Heintz
What springs are you running?
alwayzbroken
Quote from: Max Heintz on March 19, 2007, 03:02:21 PM
Trail Gear 5". I like them a lot. They are soft and flexy.
Gittinit
Quote from: alwayzbroken on March 19, 2007, 03:05:27 PM
I will vouch for that!
my favorite places:
Max Heintz
who welded your rings on for your beadlocks?? I have a set of stock tacoma wheels off my red truck and was thinking about turning them into some beadlocks.
alwayzbroken
Quote from: Max Heintz on March 20, 2007, 05:02:07 PM
I welded them. There is a guy in town that makes rings.
Max Heintz
How much for the rings? Do you think those wheels would work? It would be kind of cool if they did
