OVRAROK. My 87 4runner
Started by OVRAROK, July 11, 2014, 04:04:18 PM
Here's is where I stopped for the day, just need to finish crawl box tomorrow
Sent from my HTC One_M8 using Tapatalk
man that is beautiful
redneckcustoms13
I really think we need a youtube link of how you clean those cases.
01 double cab hunting truck
06 tacoma street truck
OTO Phil
^^^^^ That would be a really cool video! From start to finish! I'd better send you my t case so you can rebuild it and make that video ;)
last time mocking up, checking shift rods, need a piece of 1/4 keystock, should be done tomorrow
OTO Phil
are you in the pacnw?
Wow Dave, that looks so different!!!!!!!!
redneckcustoms13
And now to ship them to alabama lol. Looks great man, I can't believe how well that case cleaned up.
OTO Phil
so, clean bill of health yet?
#370
Quote from: pgragg on February 03, 2016, 07:39:34 PM
had to run to town to get a piece of key stock, tomorrow ill get it welded on, buttoned up, may run to local 4x4 place and pick up new shifter seat, couple flange nuts
Willard
Little off subject but, just got back from a nice hike, almost 4 miles up hill one way, thought I'd share some pics
toyman2210
That's an awesome view. I definitely miss those now that I'm in Florida.
By the way nice welding cart, I might know someone who has a similar setup....i plead the 5th!
"It Happened!!"
4runner17
Are you still dd your runner Dave?
Quote from: 4runner17 on February 08, 2016, 04:22:16 PM
yeah, its been down for 2 weeks now, needs alternator, going with gm unit it looks like
4runner17
Yea gm is the way to go
Jfrank81
Looks really good man. Nice work.
OTO Phil
Building a bracket or buying?
Quote from: pgragg on February 14, 2016, 10:11:32 PM
with his fab skills..... I assume he is building one
So, I took an alternator I had lying around in to town, was able to have it thoroughly tested, found out its putting out 116 amps at 5000 rpm, kicking on at 1400 rpm of alt, which is about 700 rpm on the tachometer, problem was this alternator was a Honda nippondenso with Toyota voltage regulator installed to give correct plug, problem is Honda is reverse rotation compared to Toyota, which meant is was not letting air pass thru it properly, so I torn into a stock alternator and the hi output so, upon further inspection, the stock rotor, has a groove where brushes ride, called alternator test place, 40 bucks to replace bearing and glue new copper, where brushes ride, so for 40 bucks, I should be good to go
So, while I was waiting for rotor to be fixed I decided to pull existing alt out, notice insulator on positive stud was melted, only way it can melt is from arc, or not tightened properly, so I used insulator from stock alternator, cleaned all wiring connection points, slapped it back in... And what do know I have 14.6 volts at idle
wait. so nothing was wrong with your alternator? it was just a loose wiring connection?
Quote from: jimbo74 on February 17, 2016, 04:40:24 PM
started out as a loose connection, melted the insulator, which is used to snug the first nut, thus causing connection to get more loose, my symptom was a jumping volts on the volt gauges, I thought my internal voltage regulator was out, tomorrow my rotor should be done, ill have a 100+ amp spare alternator for the trail parts
glad it was something simple.. and heck, now you have a spare
Crocks
You should a mailed me your rotor with the mounts I could a turned it for you, I think I'm on same page :dunno: anyways got mounts today. Thanks and 200 ft of dom will be around $770
Shambs old 85 runner http://board.marlincrawler.com/index.php?topic=52566.0
Since I've added, ARP knuckle studs, MC short throw, MC dual case mount. Arb front locker. Arb twin compressor, new rear seats and carpet
200 feet?! what are you going to do with that much dom? interior and exterior cages?!
OTO Phil
I was looking at your posting history to try and find a write-up on your digital voltage gauges, but I figured you might be able to find a link for that much quicker...
My questions are: Are they for a dual battery setup, and what kind of isolator or switch do you have them wired up to?
Quote from: pgragg on February 17, 2016, 10:31:14 PM
yes, they are for dual batteries. I'm running a odyssey pc1200 fmj, and a pc1200 lfmj, for the battery selector, I'm running a painless 500 amp power manager, its a little older and not the new digital design, the two volt meters gauges where purchased off of ebay
